查看: 1971|回复: 4
[提问] 麻烦大神看看,框选填充
发表于 2022-8-23 09:42:39 | 显示全部楼层 |阅读模式
框选填充,
B为我要的结果,能够框选填充,麻烦大神看看,谢谢
发表于 2022-8-23 14:34:20 | 显示全部楼层
麻烦大佬改一下,要求重命名前 ,可以定义块名,然后可以框选而非全部
(defun C:BN ( / blist bl b n)
(setq blist '() bl nil b 0 n "BK111-")
(while (setq bl (tblnext "block" (not bl)))
(and (zerop (logand 53 (cdr (assoc 70 bl))))
(not (wcmatch "`**" (setq bl (cdr (assoc 2 bl)))))
(or (member bl blist) (setq blist (cons bl blist)))
(while (and (car blist) (setq b (1+ b)))
(command "_.-rename" "_b" (car blist)
(strcat n (if (< b 10) "0" "") (itoa b)))
(setq blist (cdr blist))
发表于 2022-8-24 14:30:59 | 显示全部楼层
看一看是怎么回事
 楼主| 发表于 2022-8-26 09:43:04 | 显示全部楼层
;                    bth--块替换
;****************************************************块替换
(defun C:bth ()
  (setvar "osmode" 0)
  (princ "\n请选择作为源块的图块:")
  (setq a1 (ssget (list (cons 0 "insert"))))
  (setq stent (ssname a1 0))
  (setq stent (entget stent))
  (setq insname (assoc 2 stent))
  (setq insname (cdr insname))
  (princ insname)
  (princ "\n请选择将替换的图块:")
  (setq a (ssget (list (cons 0 "insert"))))
  (if (/= a nil)
      (setq n (sslength a))
      (setq index 0)
      (repeat n
        (setq foent (ssname a index))
        (setq ent1 (entget foent))
        (setq index (+ index 1))
        (setq inspt (assoc 10 ent1))
        (setq inspt (list (nth 1 inspt) (nth 2 inspt)))
        (setq insang1 (assoc 50 ent1))
        (setq insang (cdr insang1))
        (if (/= insang 0)
          (setq insang (/ (* insang 180) pi))
        (command "erase" foent "")
        (command "insert" insname inspt 1 1 insang "")
  (setvar "osmode" 687)
发表于 2022-8-26 09:51:37 | 显示全部楼层
song宋_74729 发表于 2022-8-26 09:43
;                    bth--块替换
支持动态块保留属性的替换吗?
GMT+8, 2025-5-15 14:07 , Processed in 0.189735 second(s), 35 queries , Gzip On.
