- (defun C:E1()(setvar "cmdecho" 0)(setq tol (getvar "dimtol"))(setq tp (getvar "dimtp"))(setq tm (getvar "dimtm"))(setq tdec (getvar "dimtdec"))(setq tfac (getvar "dimtfac"))(setq tzin (getvar "dimtzin"))(Prin1"砞竚夹猔そ畉,0,-0.005")(ssget)(command "dimoverride" "dimtol" "on" "dimtp" "0.01" "dimtm" "0" "dimtdec" "2" "dimtfac" "0.5" "dimtzin" "8" "" "P" "")(setvar "dimtol" tol)(setvar "dimtp" tp)(setvar "dimtm" tm)(setvar "dimtfac" tfac)(setvar "dimtdec" tdec)(setvar "dimtzin" tzin)(princ))
这是以个为标注文字添加偏差值得代码
运行 E1 选取需要添加偏差值的坐标
空格 会出现偏差值
当改动标注样式时 偏差值会消失
ISO-25 改为 副本 ISO-25 偏差值消失
???有什么办法能让添加的偏差值 就算更改标注样式 偏差值任然会存在
也就是 使公差固定在你添加的地方
