查看: 1499|回复: 7
请教选择扩展属性问题,急急!!!
发表于 2013-1-11 21:37:50 | 显示全部楼层 |阅读模式
((-1 . <图元名: 7d4641d8>) (0 . "LWPOLYLINE") (5 . "32D36B") (102 . "{ACAD_REACTORS") (330 . <图元名: 7d464208>) (102 . "}") (330 . <图元名: 7e2d4cc0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "DMTZ") (6 . "Continuous") (100 . "AcDbPolyline") (90 . 11) (70 . 128) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 426763.0 3.13265e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 426761.0 3.13266e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 426758.0 3.13267e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 426755.0 3.13267e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 426750.0 3.13268e+006) (40 . 0.0) (41 . 0.0) (42
. 0.0) (10 426745.0 3.13268e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 426743.0 3.13268e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 426743.0 3.13268e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 426742.0 3.13269e+006) (40 . 0.0) (41 . 0.0) (42
. 0.0) (10 426743.0 3.1327e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 426743.0 3.1327e+006) (40 . 0.0) (41 . 0.0) (42 . 0.0) (210 0.0 0.0 1.0) (-3 ("SOUTH" (1000 . "204421") (1070 . 1))))
用(setq a (ssget "x" '((8 . "DMTZ") (-3 ("SOUTH"(1000 . "204421"))))))可以选择到
((-1 . <图元名: 7d32ede8>) (0 . "LINE") (5 . "366D75") (102 . "{ACAD_REACTORS") (330 . <图元名: 7d464208>) (102 . "}") (330 . <图元名: 7e2d4cc0>) (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "DMTZ") (6 . "Continuous") (100 . "AcDbLine") (10 426763.0 3.13265e+006 0.0) (11 426747.0 3.13265e+006 0.0) (210 0.0 0.0 1.0) (-3 ("SOUTH" (1000 . "204420-1"))))
用(setq a (ssget "x" '((8 . "DMTZ") (-3 ("SOUTH"(1000 . "204420-1"))))))为什么选择不到呢???
发表于 2013-1-11 22:31:05 | 显示全部楼层
-3只能选择第一个后面的没有反应,
 楼主| 发表于 2013-1-11 22:40:19 | 显示全部楼层
选择类似204420-1编码的就选择不到
选择类似204420编码的就可以
不知道为什么
发表于 2013-1-11 23:22:40 | 显示全部楼层
  1. (defun C:ent()
  2.   (While (Not (SetQ a (EntSel "\n指定一个对象: ")))
  3.               (PrinC "\n没选中任何目标, 请再试...")
  4.
  5.        )
  6.        (SetQ a (Car a)
  7.              b (EntGet a '("*"))
  8.              c (Cdr (Assoc 0 b))
  9.              d (List b)
  10.        )
  11.   (princ    b)
  12.   (while (not (= "SEQEND" c))
  13.       (setq a (entnext a)
  14.             d (cons (entget a '("*")) d)
  15.             c (cdr (assoc 0 (entget a)))
  16.             )
  17.     (princ d)
  18.   );;;    (setq pel (entget pen))
  19.   (princ  )
  20.   )
这个程序你试下。我试了下 凡是能SSGET能选到的都会报错,选不到的都不会报错,我研究半天没弄动什么原因,希望你能有什么启示,貌似跟块或者线形有关
发表于 2013-8-16 10:14:41 | 显示全部楼层
我也是遇到相关的问题,帮顶下。
发表于 2016-10-8 13:27:30 | 显示全部楼层
我用这个也选不到啊
发表于 2016-10-8 13:46:09 来自手机 | 显示全部楼层
只有lwployline能选择1000码 其他的只能按扩展应用名选择 这是规定
发表于 2016-10-8 15:43:49 | 显示全部楼层
好的,谢谢你啊
GMT+8, 2025-8-24 04:28 , Processed in 0.150400 second(s), 25 queries , Gzip On.
