查看: 11137|回复: 25
[已解答] lisp,dcl编译成VLX不能显示DCL
发表于 2013-1-25 17:02:48 | 显示全部楼层 |阅读模式
LISP与DCL合编成VLX后不能显示DCL,请教高手,这问题出在哪里?
一:我的LISP文件:LL.LSP
(defun sset ()
  (setvar "CMDECHO" 0)
  (setvar "TEXTEVAL" 1)
(defun sset1 ()
  (setvar "CMDECHO" 1)
(defun c:ll (/ s p n a pt0 pt00 pt1 pt2 pt3 pt4 pt5 pt6 ang x1 x2 y1 y2 p1
        dis ang1 nam e pt10 pt11 f bl ptp0 pt01
  (sset)
  (if (or
(not dcl_id)
(< (setq dcl_id (load_dialog "ll-b.dcl"))
    0
  (if (not (new_dialog "ll1" dcl_id))
    (exit)
  (action_tile "tile0" "(setq pt1 $value)")
  (action_tile "tile00" "(setq pt1 $value)(set_tile \"tile0\" $value)")
  (action_tile "tile1"
        "(setq pt1 100)(set_tile \"tile0\" \"100\")(done_dialog 1)"
  (action_tile "tile2"
        "(setq pt1 150)(set_tile \"tile0\" \"150\")(done_dialog 1)"
  (action_tile "tile3"
        "(setq pt1 200)(set_tile \"tile0\" \"200\")(done_dialog 1)"
  (action_tile "tile4"
        "(setq pt1 50)(set_tile \"tile0\" \"50\")(done_dialog 1)"
  (action_tile "tile5"
        "(setq pt1 40)(set_tile \"tile0\" \"40\")(done_dialog 1)"
  (action_tile "tile6"
        "(setq pt1 30)(set_tile \"tile0\" \"30\")(done_dialog 1)"
  (action_tile "tile7"
        "(setq pt1 20)(set_tile \"tile0\" \"20\")(done_dialog 1)"
  (action_tile "tile8"
        "(setq pt1 10)(set_tile \"tile0\" \"10\")(done_dialog 1)"
  (action_tile "tile9"
        "(setq pt1 5)(set_tile \"tile0\" \"5\")(done_dialog 1)"
  (action_tile "accept" "(setq pt1 100)(done_dialog 1)")
  (start_dialog)
  (unload_dialog dcl_id)
  (setvar "DIMLFAC" pt1)
  (setq s (ssget))
  (while (/= s nil)
    (setq p (- (sslength s) 1))
    (setq n 0)
    (setq a (ssadd))
    (while (<= n p)
      (setq pt1 (entget (ssname s n)))
      (if (or
     (= "LINE" (cdr (assoc 0 pt1)))
     (= "LWPOLYLINE" (cdr (assoc 0 pt1)))
(ssadd (ssname s n) a)
      (setq n (+ n 1))
    (setq p (- (sslength a) 1))
    (setq n 0)
    (while (<= n p)
      (setq pt1 (entget (setq nam (ssname a n))))
      (if (= n 0)
   (if (= "LINE" (cdr (assoc 0 pt1)))
       (setq pt2 (cdr (assoc 10 pt1)))
       (setq pt3 (cdr (assoc 11 pt1)))
   (if (= "LWPOLYLINE" (cdr (assoc 0 pt1)))
       (setq pt2 (entnext nam))
       (setq pt3 (entnext pt2))
       (setq pt2 (entget pt2))
       (setq pt3 (entget pt3))
       (setq pt2 (cdr (assoc 10 pt2)))
       (setq pt3 (cdr (assoc 10 pt3)))
   (setq ang1 (angle pt2 pt3))
   (setvar "SNAPANG" ang1)
   (setq ang (+ ang1 (/ pi 2)))
   (setq pt4 (polar pt2 ang 3))
   (setq e (list pt2))
      (if (> n 0)
       (setq pt10 (cdr (assoc 10 pt1)))
       (setq pt11 (cdr (assoc 11 pt1)))
       (setq pt10 (entnext nam))
       (setq pt11 (entnext pt10))
       (setq pt10 (entget pt10))
       (setq pt11 (entget pt11))
       (setq pt10 (cdr (assoc 10 pt10)))
       (setq pt11 (cdr (assoc 10 pt11)))
   (setq ang1 (angle pt10 pt11))
   (if (and
  (/= (abs (- ang ang1)) 0.0)
  (/= (abs (- ang ang1)) pi)
       (setq pt10 (inters
      pt2
      pt4
      pt10
      pt11
      nil
       (setq e (append
   (list pt10)
   e
      (setq n (+ n 1))
    (setq p (- (length e) 1))
    (setq n 0)
    (setq f (ssadd))
    (while (< n p)
      (setq pt0 (nth n e))
      (setq pt1 (nth (+ n 1) e))
      (setq pt5 (polar pt0 (- ang1 (* 0.25 pi)) 0.71))
      (setq pt6 (polar pt0 (+ ang1 (* 0.75 pi)) 0.71))
      (command "PLINE" pt5 "W" 0.45 "" pt6 "")
      (ssadd (entlast) f)
      (setq pt5 (polar pt0 ang1 10))
      (setq pt6 (polar pt0 (+ ang1 pi) 4))
      (command "PLINE" pt5 "W" 0 "" pt6 "")
      (ssadd (entlast) f)
      (if (= n 0)
(setq pt00 pt0)
      (if (= n (- p 1))
   (setq pt1 (nth p e))
   (setq pt5 (polar pt1 (- ang1 (* 0.25 pi)) 0.71))
   (setq pt6 (polar pt1 (+ ang1 (* 0.75 pi)) 0.71))
   (ssadd (entlast) f)
   (setq pt5 (polar pt1 ang1 10))
   (setq pt6 (polar pt1 (+ ang1 pi) 4))
   (ssadd (entlast) f)
   (setq ptp0 pt1)
   (command "PLINE" pt00 "W" 0 "" ptp0 "")
   (ssadd (entlast) f)
      (setq dis (distance pt1 pt0))
      (setq y1 (nth 1 pt0))
      (setq y2 (nth 1 pt1))
      (setq x1 (nth 0 pt0))
      (setq x2 (nth 0 pt1))
      (if (> y1 y2)
   (setq ang (angle pt1 pt0))
   (setq pt01 (polar pt1 ang (/ dis 2)))
      (if (< y1 y2)
   (setq ang (angle pt0 pt1))
   (setq pt01 (polar pt0 ang (/ dis 2)))
      (if (= y1 y2)
   (if (> x1 x2)
   (if (< x1 x2)
      (setq pt01 (polar pt01 (+ ang (/ pi 2)) 1))
      (setq bl (getvar "DIMLFAC"))
      (setq dis (rtos (* bl dis)))
      (setq p1 (strlen dis))
      (setq pt4 (polar pt01 ang p1))
      (setq pt3 (polar pt01 (+ ang pi) p1))
      (setvar "TEXTSTYLE" "STANDARD")
      (command "TEXT" "J" "F" pt3 pt4 3.0 dis)
      (ssadd (entlast) f)
      (setq n (+ n 1))
    (setvar "ORTHOMODE" 1)
    (command "MOVE" f "" pt00 pause "")
    (setvar "ORTHOMODE" 0)
    (setvar "SNAPANG" 0)
    (sset1)
    (setq s (ssget))
二:我的DCL文件:LL-B.DCL
ll1:dialog {
label="Please give the scale num:?";
initial_focus=tile0;
:boxed_row {
   label="The num = :";
    :edit_box {
      key="tile0";
      value="100";
      allow_accept=true;
    :slider {
      key="tile00";
      fixed_widht=true;
      width=16;
      max_value=100;
      min_value=1;
:boxed_radio_row {
  label="Select";
   :radio_button {
   label="100";
   key="tile1";
   :radio_button {
   label="150";
   key="tile2";
   :radio_button {
   label="200";
   key="tile3";
   :radio_button {
   label="50";
   key="tile4";
:boxed_radio_row {
   :radio_button {
   label="40";
   key="tile5";
   :radio_button {
   label="30";
   key="tile6";
   :radio_button {
   label="20";
   key="tile7";
   :radio_button {
   label="10";
   key="tile8";
   :radio_button {
   label="5";
   key="tile9";
  ok_only;
希望高手加我QQ:15290049  我有一大堆LISP,DCL,目前想整合VLX,遇到困难!!!
程序写的太烂  发表于 2013-1-25 22:36
 楼主| 发表于 2013-1-25 21:29:06 | 显示全部楼层
我是在CAD2004下整合的,难道版本低吗?
发表于 2013-1-25 22:17:16 | 显示全部楼层
应该没有问题才对
发表于 2013-1-25 22:28:48 | 显示全部楼层
1、对话框错误。
  1. dcl_settings:default_dcl_settings{audit_level=3;}
  2. ll1:dialog{
  3. label="Please give the scale num:?";
  4. initial_focus="tile0";
  5. :boxed_row{
  6.   label="The num=:";
  7.   :edit_box{key="tile0";value="100";allow_accept=true;}
  8.   :slider{key="tile00";fixed_widht=true;width=16;max_value=100;min_value=1;}
  9. }
  10. :boxed_radio_row{
  11.   label="Select";
  12.   :radio_button{label="100";key="tile1";}
  13.   :radio_button{label="150";key="tile2";}
  14.   :radio_button{label="200";key="tile3";}
  15.   :radio_button{label="50";key="tile4";}
  16. }
  17. :boxed_radio_row{
  18.   :radio_button{label="40";key="tile5";}
  19.   :radio_button{label="30";key="tile6";}
  20.   :radio_button{label="20";key="tile7";}
  21.   :radio_button{label="10";key="tile8";}
  22.   :radio_button{label="5";key="tile9";}
  23. }
  24. ok_only;
  25. }
 楼主| 发表于 2013-1-25 22:44:28 | 显示全部楼层
ZZXXQQ 发表于 2013-1-25 22:28
1、对话框错误。
对话框哪里错?,缺少最上面一句话是吗?原先运行正常的;
编译整合后 ,DCL文件不能删除,保留运行正常,删除就缺少DCL。
在2004下调试报错。4楼是改过的代码。  发表于 2013-1-25 22:55
 楼主| 发表于 2013-1-25 23:08:53 | 显示全部楼层
编译整合后 ,DCL文件不能删除,保留运行正 ...
我用改过的代码,编译仍然不成功。DCL文件加上绝对路径,可以编译成功运行,但是不能删除DCL文件LL.VLX独立运行。奇怪个事!!!!
第一行代码是调试时加上的。这样可以生成错误文件。  发表于 2013-1-26 08:08
发表于 2013-1-25 23:14:40 | 显示全部楼层
这程序做嘛用的?看得我眼花
 楼主| 发表于 2013-1-25 23:17:43 | 显示全部楼层
yjr111 发表于 2013-1-25 23:14
这程序做嘛用的?看得我眼花
干嘛用?
看了一下是【标注平行线之间间距尺寸】的:
             1:对话框输入标注的尺寸数值。
             2:选择平行的2根或多根线。
             3:拉动到旁边,自动出来标注,带着你输入的数值。
把DCL直接写进lsp不就可以了?  发表于 2013-1-25 23:28
发表于 2013-1-25 23:35:58 | 显示全部楼层
这是编译好的,试下看
 楼主| 发表于 2013-1-25 23:45:51 | 显示全部楼层
ZZXXQQ 发表于 2013-1-25 23:35
这是编译好的,试下看
感谢:
很成功,哪么你是在CAD哪个版本下整合的呢?
可是问题来啦:
    1:我怎么就编译不成功!DCL直接写进LISP也正在学,我也需要学会,再说,我很多啊,
         这工作大了去啦。我用的CAD是自己开发的一套系统。
    2:自己写过很多LISP,DCL程序,我都使用19年,是与PKPM配合严密的,最近要整合VLX。
    3:问题之所在到底在哪里?我不能一直麻烦大家吧?
    4:如果是CAD2004版本的VLISP不行,哪么我要升级,关键是这个问题吗?
偶用的就是2004编译的。用专业模式,将DCL打包进去。一编译有向导……  发表于 2013-1-26 08:04
GMT+8, 2025-5-26 09:08 , Processed in 0.197557 second(s), 29 queries , Gzip On.
