查看: 1388|回复: 3
一个用短直线画圆的问题
发表于 2013-1-29 17:48:00 | 显示全部楼层 |阅读模式
(defun c:qqq()
   (setq r 50 pt '(0 0))
(command "layer" "m" "ArtLine" "C" 1 "" "")
  (command "color" "bylayer")
  (command "LINE" )
   (setq n 1)
  (repeat 360
    (setq ang (/ (* 2 n pi ) 360))
     (setq pp (polar pt ang r))
       (command pp)
    (setq n(1+ n))
(command "")
[img]file:///C:\Documents and Settings\Administrator\Application Data\Tencent\Users\294406496\QQ\WinTemp\RichOle\~6ERAXR{{7K0}_BPUK$HO[K.jpg[/img]
我想利用短直线近似画一个圆。我将圆分成了360段,那么每一段的偏转角为1°,但是我画出来的图形怎么偏转角不是1°,谁能告诉我怎么回事
发表于 2013-1-29 20:37:36 | 显示全部楼层
(defun c:qqq()
  (setq aa (/ Pi 180)
         n 1
  (command "LINE" )
  (repeat 360
     (setq pp (polar pt (* aa n) r))
     (command pp)
     (setq n (1+ n))
  (command "C")
建议考虑捕捉
 楼主| 发表于 2013-1-29 20:48:42 | 显示全部楼层
明白了,谢谢了,需要添加一句(setvar "osmode" 0)
发表于 2013-1-29 23:48:45 来自手机 | 显示全部楼层
学习了,还能这样用语句
GMT+8, 2025-7-20 12:54 , Processed in 0.163047 second(s), 27 queries , Gzip On.
