查看: 2350|回复: 4
看到这样了一个工具,感觉非常不好,能不能指定它只排列几个常用的图层,因为做图时层多
发表于 2013-2-3 00:38:21 | 显示全部楼层 |阅读模式
看到这样了一个工具,感觉非常不好,能不能指定它只排列几个常用的图层,因为做图时层多了就麻烦了,而我们做图时通常只用到几个图层,我想想把这几个常用的图层这样排在下方,以便切换就行,看看看能不能,
 楼主| 发表于 2013-2-3 01:02:18 | 显示全部楼层
就是它了,它图层多了,如果有引用文件它还直接退出CAD,不行太不好了,看看大家有没有没LSP版的,因这样样切换图层非常方便,直观嘛,
发表于 2013-2-3 10:01:13 | 显示全部楼层
这个工具不错!
发表于 2013-2-8 22:13:28 | 显示全部楼层
不一样的思路。
发表于 2013-4-5 23:33:20 | 显示全部楼层
;设当前图层为layer1层
(defun c:MX_1 ()
     (setvar "cmdecho" 0) ;指令执行过程不响应
(setq layer "layer1")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer1" "s" "layer1" "C" 1 "" "L" "Continuous" "" "LW" 0 "" "")
     (setvar  "CLAYER" layer)
     (PRINC "\n欢迎使用--《模型工具箱》--  当前图层已切换为layer1层")(princ))
;设当前图层为layer2层
(defun c:MX_2 ()
(setq layer "layer2")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer2" "s" "layer2" "C" 2 "" "L" "Continuous" "" "LW" 0 "" "")
;设当前图层为layer3层
(defun c:MX_3 ()
(setq layer "layer3")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer3" "s" "layer3" "C"3 "" "L" "Continuous" "" "LW" 0 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为layer3层")(princ))
;设当前图层为layer4层
(defun c:MX_4 ()
(setq layer "layer4")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer4" "s" "layer4" "C" 4 "" "L" "Continuous" "" "LW" 0 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为layer4层")(princ))
;设当前图层为layer5层
(defun c:MX_5 ()
(setq layer "layer5")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer5" "s" "layer5" "C" 5 "" "L" "Continuous" "" "LW" 0 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为layer5层")(princ))
;设当前图层为layer6层
(defun c:MX_6 ()
(setq layer "layer6")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer6" "s" "layer6" "C" 6 "" "L" "Continuous" "" "LW" 0 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为layer6层")(princ))
;设当前图层为layer7层
(defun c:MX_7 ()
(setq layer "layer7")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer7" "s" "layer7" "C" 7 "" "L" "Continuous" "" "LW" 0 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为layer7层")(princ))
;设当前图层为layer8层
(defun c:MX_8 ()
(setq layer "layer8")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer8" "s" "layer8" "C" 8 "" "L" "Continuous" "" "LW" 0 "" "")
))     (setvar  "CLAYER" layer)
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为layer8层")(princ))
;设当前图层为layer9层
(defun c:MX_9 ()
(setq layer "layer9")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer9" "s" "layer9" "C" 171 "" "L" "Continuous" "" "LW" 0 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为layer9层")(princ))
;设当前图层为layer0层
(defun c:MX_0 ()
(setq layer "layer0")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "layer0" "s" "layer0" "C" 42 "" "L" "Continuous" "" "LW" 0 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为layer0层")(princ))
;设当前图层为临时层
(defun c:MX_LS ()
(setq layer "临时")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "临时" "s" "临时" "C" 7 "" "L" "Continuous" "" "LW" 0.2 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为临时层")(princ))
;设当前图层为文字层
(defun c:MX_WZ ()
(setq layer "文字")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "文字" "s" "文字" "C" 212 "" "L" "Continuous" "" "LW" 0.2 "" "")
     (PRINC "\n欢迎使用--《模型工具箱》--   当前图层已切换为文字层")(princ))
;设当前图层为标注层
(defun c:MX_BZ ()
(setq layer "标注")(if (not (tblsearch "layer" layer ))
  (progn (command "layer" "new" "标注" "s" "标注" "C" 212 "" "L" "Continuous" "" "LW" 0.2 "" "")
     (PRINC "\n欢迎使用《模型工具箱》   当前图层已切换为标注层")(princ))
;将所有标注改为标注层
(defun C:MX_BZC (/ ss)
(setq ss (ssget "X" '((0 . "DIMENSION"))))
(command "Chprop" ss "" "LA" "标注     dim" "")
     (PRINC "\n欢迎使用--《模型工具箱》--     将所有标注改为标注层完成!")(PRINC))
----------------------------------------选择对象到图层
(DEFUN C:MX_00 ()
        (princ "\n 选择对象到layer0层:)")
              (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer0" "")
     (PRINC "\n欢迎使用--《模型工具箱》--  选择对象到layer0层完成!")(PRINC))
(DEFUN C:MX_11 ()
        (princ "\n 选择对象到layer1层:)")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer1" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到layer1层完成!")(PRINC))
(DEFUN C:MX_22 ()
        (princ "\n 选择对象到layer2层 :)")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer2" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到layer2层完成!")(PRINC))
(DEFUN C:MX_33 ()
        (princ "\n 选择对象到layer3层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer3" "")
     (PRINC "\n欢迎使用--《模型工具箱》--  选择对象到layer3层完成!")(PRINC))
(DEFUN C:MX_44 ()
        (princ "\n 选择对象到 layer4层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer4" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到layer4层完成!")(PRINC))
(DEFUN C:MX_55 ()
        (princ "\n 选择对象到 layer5层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer5" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到layer5层完成!")(PRINC))
(DEFUN C:MX_66()
        (princ "\n 选择对象到 layer6层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer6" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到layer6层完成!")(PRINC))
(DEFUN C:MX_77()
        (princ "\n 选择对象到 layer7层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer7" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到layer7层完成!")(PRINC))
(DEFUN C:MX_88()
        (princ "\n 选择对象到 layer8层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer8" "")
     (PRINC "\n欢迎使用--《模型工具箱》--选择对象到layer8层完成!")(PRINC))
(DEFUN C:MX_99()
        (princ "\n 选择对象到 layer9层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer9" "")
     (PRINC "\n欢迎使用--《模型工具箱》--     选择对象到layer9层完成!")(PRINC))
(DEFUN C:MX_001 ()
        (princ "\n 选择对象到 layer10层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "layer10" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到layer10层完成!")(PRINC))
(DEFUN C:MX_LSS ()
        (princ "\n 选择对象到临时层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "临时" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到临时层完成!")(PRINC))
(DEFUN C:MX_WZZ ()
        (princ "\n 选择对象到文字层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "文字" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到文字层完成!")(PRINC))
(DEFUN C:MX_BZZ ()
        (princ "\n 选择对象到标注层:")
        (SETQ SS(SSGET))
        (COMMAND "CHANGE" SS "" "PROPERTIES" "la" "标注" "")
     (PRINC "\n欢迎使用--《模型工具箱》-- 选择对象到标注层完成!")(PRINC))
GMT+8, 2025-7-20 08:40 , Processed in 0.174930 second(s), 29 queries , Gzip On.
