查看: 2771|回复: 8
求改LEE大师的一个程序。谢谢各位大师了
发表于 2013-2-4 12:12:05 | 显示全部楼层 |阅读模式
;;---------------------=={ Area Label }==---------------------;;
;;  Allows the user to label picked areas or objects and      ;;
;;  either display the area in an ACAD Table (if available),  ;;
;;  optionally using fields to link area numbers and objects; ;;
;;  or write it to file.                                      ;;
;;  Author: Lee Mac, Copyright ?2011 - www.lee-mac.com       ;;
;;  Version 1.9    -    29-10-2011                            ;;
(defun c:AT nil (AreaLabel   t))  ;; Areas to Table
(defun c:AF nil (AreaLabel nil))  ;; Areas to File
(defun AreaLabel ( flag / *error* _startundo _endundo _centroid _text _open _select _getobjectid _isannotative
                          acdoc acspc ap ar as cf cm el fd fl fo n of om p1 pf pt sf st t1 t2 tb th ts tx ucsxang ucszdir )
  ;;                         Adjustments                        ;;
  (setq h1 "面积计算表"  ;; Heading
        t1 "编号"      ;; Number Title
        t2 "面积"        ;; Area Title
        pf ""            ;; Number Prefix (optional, "" if none)
        sf ""            ;; Number Suffix (optional, "" if none)
        ap ""            ;; Area Prefix (optional, "" if none)
        as ""            ;; Area Suffix (optional, "" if none)
        cf 1.0           ;; Area Conversion Factor (e.g. 1e-6 = mm2->m2)
        fd t             ;; Use fields to link numbers/objects to table (t=yes, nil=no)
        fo "%lu6%qf1"    ;; Area field formatting
  (defun *error* ( msg )
    (if cm (setvar 'CMDECHO cm))
    (if el (progn (entdel el) (setq el nil)))
    (if acdoc (_EndUndo acdoc))
    (if (and of (eq 'FILE (type of))) (close of))
    (if (and Shell (not (vlax-object-released-p Shell))) (vlax-release-object Shell))
    (if (null (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
        (princ (strcat "\n--> Error: " msg))
  (defun _StartUndo ( doc ) (_EndUndo doc)
    (vla-StartUndoMark doc)
  (defun _EndUndo ( doc )
    (if (= 8 (logand 8 (getvar 'UNDOCTL)))
      (vla-EndUndoMark doc)
  (defun _centroid ( space objs / reg cen )
    (setq reg (car (vlax-invoke space 'addregion objs))
          cen (vlax-get reg 'centroid)
    (vla-delete reg) (trans cen 1 0)
  (defun _text ( space point string height rotation / text )
    (setq text (vla-addtext space string (vlax-3D-point point) height))
    (vla-put-alignment text acalignmentmiddlecenter)
    (vla-put-textalignmentpoint text (vlax-3D-point point))
    (vla-put-rotation text rotation)
    text
  (defun _Open ( target / Shell result )
    (if (setq Shell (vla-getInterfaceObject (vlax-get-acad-object) "Shell.Application"))
        (setq result
          (and (or (eq 'INT (type target)) (setq target (findfile target)))
            (not
              (vl-catch-all-error-p
                (vl-catch-all-apply 'vlax-invoke (list Shell 'Open target))
    result
  (defun _Select ( msg pred func init / e ) (setq pred (eval pred))
    (while
      (progn (setvar 'ERRNO 0) (apply 'initget init) (setq e (func msg))
        (cond
          ( (= 7 (getvar 'ERRNO))
            (princ "\nMissed, try again.")
          ( (eq 'STR (type e))
            nil
          ( (vl-consp e)
            (if (and pred (not (pred (setq e (car e)))))
              (princ "\nInvalid Object Selected.")
    e
  (defun _GetObjectID ( doc obj )
    (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
      (vlax-invoke-method (vla-get-Utility doc) 'GetObjectIdString obj :vlax-false)
      (itoa (vla-get-Objectid obj))
  (defun _isAnnotative ( style / object annotx )
    (and
      (setq object (tblobjname "STYLE" style))
      (setq annotx (cadr (assoc -3 (entget object '("AcadAnnotative")))))
      (= 1 (cdr (assoc 1070 (reverse annotx))))
  (setq acdoc (vla-get-activedocument (vlax-get-acad-object))
        acspc (vlax-get-property acdoc (if (= 1 (getvar 'CVPORT)) 'Paperspace 'Modelspace))
        ucszdir (trans '(0. 0. 1.) 1 0 t)
        ucsxang (angle '(0. 0. 0.) (trans (getvar 'UCSXDIR) 0 ucszdir))
  (_StartUndo acdoc)
  (setq cm (getvar 'CMDECHO))
  (setvar 'CMDECHO 0)
  (setq om (eq "1" (cond ((getenv "LMAC_AreaLabel")) ((setenv "LMAC_AreaLabel" "0")))))
  (setq ts
    (/ (getvar 'TEXTSIZE)
      (if (_isAnnotative (getvar 'TEXTSTYLE))
        (cond ( (getvar 'CANNOSCALEVALUE) ) ( 1.0 )) 1.0
  (cond
    ( (not (vlax-method-applicable-p acspc 'addtable))
      (princ "\n--> Table Objects not Available in this Version.")
    ( (= 4 (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (getvar 'CLAYER))))))
      (princ "\n--> Current Layer Locked.")
    ( (not
        (setq *al:num
          (cond
              (getint
                (strcat "\n批定起始编号 <"
                  (itoa (setq *al:num (1+ (cond ( *al:num ) ( 0 ))))) ">: "
            ( *al:num )
    ( flag
      (setq th
        (* 2.
          (if
            (zerop
              (setq th
                (vla-gettextheight
                  (setq st
                    (vla-item
                      (vla-item
                        (vla-get-dictionaries acdoc) "ACAD_TABLESTYLE"
                      (getvar 'CTABLESTYLE)
                  acdatarow
            ts
            (/ th
              (if (_isAnnotative (vla-gettextstyle st acdatarow))
      (if
        (cond
            (progn (initget "Add")
              (vl-consp (setq pt (getpoint "\n指定表格插入点: ")))
            (setq tb
              (vla-addtable acspc
                (vlax-3D-point (trans pt 1 0)) 2 2 th (* 4 th (max (strlen t1) (strlen t2)))
            (vla-put-direction tb (vlax-3D-point (getvar 'UCSXDIR)))
            (vla-settext tb 0 0 h1)
            (vla-settext tb 1 0 t1)
            (vla-settext tb 1 1 t2)
            (while
                (if om
                  (setq p1
                    (_Select (strcat "\nSelect Object [Pick] <Exit>: ")
                     '(lambda ( x )
                        (and
                          (vlax-property-available-p (vlax-ename->vla-object x) 'area)
                          (not (eq "HATCH" (cdr (assoc 0 (entget x)))))
                          (or (eq "REGION" (cdr (assoc 0 (entget x)))) (vlax-curve-isclosed x))
                      entsel '("Pick")
                  (progn (initget "Object") (setq p1 (getpoint "\n点选面积<Exit>: ")))
                (cond
                  ( (null p1)
                    (vla-delete tb)
                  ( (eq "Pick" p1)
                    (setq om nil) t
                  ( (eq "Object" p1)
                    (setq om t)
                  ( (eq 'ENAME (type p1))
                    (setq tx
                      (cons
                        (_text acspc
                          (_centroid acspc (list (setq p1 (vlax-ename->vla-object p1))))
                          (strcat pf (itoa *al:num) sf)
                          ts
                          ucsxang
                        tx
                    (vla-insertrows tb (setq n 2) th 1)
                    (vla-settext tb n 1
                      (if fd
                        (strcat "%<\\AcObjProp Object(%<\\_ObjId "
                          (_GetObjectID acdoc p1) ">%).Area \\f \"" fo "\">%"
                        (strcat ap (rtos (* cf (vla-get-area p1)) 2) as)
                    (vla-settext tb n 0
                      (if fd
                          (_GetObjectID acdoc (car tx)) ">%).TextString>%"
                    nil
                  ( (vl-consp p1)
                    (setq el (entlast))
                    (vl-cmdf "_.-boundary" "_A" "_I" "_N" "" "_O" "_P" "" "_non" p1 "")
                    (if (not (equal el (setq el (entlast))))
                        (setq tx
                          (cons
                            (_text acspc
                              (_centroid acspc (list (vlax-ename->vla-object el)))
                              ts
                              ucsxang
                            tx
                        (vla-settext tb n 1 (strcat ap (rtos (* cf (vlax-curve-getarea el)) 2) as))
                        (vla-settext tb n 0
                          (if fd
                        (redraw el 3)
                        nil
                      (vla-delete tb)
            (not (vlax-erased-p tb))
            (and
              (setq tb
                (_Select "\nSelect Table to Add to: "
                 '(lambda ( x ) (eq "ACAD_TABLE" (cdr (assoc 0 (entget x))))) entsel nil
              (< 1 (vla-get-columns (setq tb (vlax-ename->vla-object tb))))
            (setq n (1- (vla-get-rows tb)) *al:num (1- *al:num))
          (while
            (if om
              (setq p1
                (_Select (strcat "\nSelect Object [" (if tx "Undo/" "") "Pick] <Exit>: ")
                 '(lambda ( x )
                    (and
                  entsel (list (if tx "Undo Pick" "Pick"))
              (progn (initget (if tx "Undo Object" "Object"))
                (setq p1 (getpoint (strcat "\n点选面积 [" (if tx "Undo/" "") "Object] <Exit>: ")))
            (cond
              ( (and tx (eq "Undo" p1))
                (vla-deleterows tb n 1)
                (vla-delete (car tx))
                (setq n (1- n) tx (cdr tx) *al:num (1- *al:num))
              ( (eq "Undo" p1)
                (princ "\n--> Nothing to Undo.")
              ( (eq "Object" p1)
                (setq om t)
              ( (eq "Pick" p1)
                (setq om nil)
              ( (and om (eq 'ENAME (type p1)))
                (setq tx
                  (cons
                    (_text acspc
                      (strcat pf (itoa (setq *al:num (1+ *al:num))) sf)
                      ts
                      ucsxang
                    tx
                (vla-insertrows tb (setq n (1+ n)) th 1)
                (vla-settext tb n 1
                  (if fd
                (vla-settext tb n 0
                  (if fd
              ( (vl-consp p1)
                (setq el (entlast))
                    (setq tx
                      (cons
                        (_text acspc
                          ts
                          ucsxang
                        tx
                    (vla-settext tb n 0
                      (if fd
                    (redraw el 3)
                  (princ "\n--> Error Retrieving Area.")
      (and
        (setq fl (getfiled "Create Output File" (cond ( *file* ) ( "" )) "txt;csv;xls" 1))
        (setq of (open fl "w"))
      (setq *file*  (vl-filename-directory fl)
            de      (cdr (assoc (strcase (vl-filename-extension fl) t) '((".txt" . "\t") (".csv" . ",") (".xls" . "\t"))))
      (write-line h1 of)
      (write-line (strcat t1 de t2) of)
      (while
        (if om
          (setq p1
             '(lambda ( x )
                (and
              entsel '("Pick")
          (progn (initget "Object") (setq p1 (getpoint (strcat "\n点选面积: "))))
        (cond
          ( (eq "Object" p1)
            (setq om t)
          ( (eq "Pick" p1)
            (setq om nil)
            (_text acspc
              ts
              ucsxang
            (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vla-get-area p1)) 2) as) of)
          ( (vl-consp p1)
            (setq el (entlast))
                (_text acspc
                  ts
                  ucsxang
                (write-line (strcat pf (itoa *al:num) sf de ap (rtos (* cf (vlax-curve-getarea el)) 2) as) of)
                (redraw el 3)
      (setq of (close of))
      (_Open (findfile fl))
  (setenv "LMAC_AreaLabel" (if om "1" "0"))
  (_EndUndo acdoc)
(vl-load-com)
(princ "\n:: AreaLabel.lsp | Version 1.9 | ?Lee Mac 2011 www.lee-mac.com ::")
(princ "\n:: Commands: \"AT\" for ACAD Table, \"AF\" for File ::")
;;                         End of File                        ;;
要求
1、修改mm单位为m保留小数点后三位
2、要求增加一个功能,对形成表格中的文字进行字高设置。。。。。
3、已提取面积的地方生成一个红色线框(这一点有难度就算了哈)
想知道生成的表格高度在哪修改啊。。。还有那个宽度改下两例一起变长变短。能一例一例改长短吗。。。
麻烦各位路过的大师瞧下。。谢谢。。
发表于 2013-2-4 13:51:00 | 显示全部楼层
这么长,看都要好久呢!
1.修改mm单位为m保留小数点后三位
答:除以1000就好了,小数位数用RTOS
答:用程序选到文字,更改高度组码40
答:不知道你要什么样的框,框哪里?
图框就是计算面积部份的~  发表于 2013-2-4 14:33
开心哥这个高度组码40哪改~  发表于 2013-2-4 14:07
发表于 2013-2-4 14:25:19 | 显示全部楼层
(XX-PUT-DXF (SSGET) 40 (GETDIST));改文字高度
对于表格,建议用中心缩放文字
  1. (defun c:xx ( / i lts s1 ss)
  2.   (setq lts (getdist "缩放比例")
  3. ss (ssget ":s" '((0 . "*TEXT")))
  4. i -1
  5.   )
  6.   (while (setq s1 (ssname ss (setq i (1+ i))))
  7.     (xx-sc s1 (xx-get-s1-9pt s1 5) lts)
  8.   )
  9. )
  10. ;缩放实体或选择集
  11. ;(XX-Sc s1 PO lts) S1为图元名或选择集  PO lts基点与比例
  12. (DEFUN XX-Sc (S1 PO LTS / TP PT I NAME)
  13.     (setq tp (type s1) ;提取类型
  14.           pt (vlax-3D-point (trans PO 1 0));转成基点
  15.     )
  16. (cond
  17.    ((= tp 'ENAME) (vla-scaleentity (XX-E2O s1) pt lts));XX-E2O 转换为 VLA 对象
  18.    ((= tp 'PICKSET)
  19.       (setq i -1)
  20.     (while (setq NAME (ssname s1 (setq i (1+ i))))
  21.       (vla-scaleentity (XX-E2O NAME) pt lts);XX-E2O 转换为 VLA 对象
  22.     )
  23.    )
  24.    ((= tp 'LIST) (foreach NAME S1 (XX-Sc NAME PO lts)));函数遍历表,将其中每一个元素依次赋给变量,并对每一个表达式求值
  25.    (T
  26.     (alert "缩放 通用函数错了!");都不成立,就打印输入通用函数错了信息
  27.    )
  28. )
  29.   s1
  30. )
  31. (defun XX-Get-S1-9pt (s1 mode / dx dy point pointmax pointmin x1 x2 y1 y2)
  32. (IF(and (= (type s1) 'ENAME)(= (type mode) 'INT))
  33.   (progn
  34.     (vla-getboundingbox(XX-E2O s1) 'minpoint 'maxpoint);XX-E2O转为VLA对象
  35.    (setq pointmax (vlax-safearray->list maxpoint);取得第9点
  36.          pointmin (vlax-safearray->list minpoint);取得第1点
  37.               x1  (car pointmin)
  38.               x2  (car pointmax)
  39.               y1  (cadr pointmin)
  40.               y2  (cadr pointmax)
  41.               dx  (/ (- x2 x1) 2.0)
  42.               dy  (/ (- y2 y1) 2.0)
  43.    )
  44.    (cond ((= mode 1) (setq point pointmin))
  45.          ((= mode 2) (setq point (list (+ x1 dx) y1)))
  46.          ((= mode 3) (setq point (list x2 y1)))
  47.          ((= mode 4) (setq point (list x1 (+ y1 dy))))
  48.          ((= mode 5) (setq point (list (+ x1 dx) (+ y1 dy))))
  49.          ((= mode 6) (setq point (list x2 (+ y1 dy))))
  50.          ((= mode 7) (setq point (list x1 y2)))
  51.          ((= mode 8) (setq point (list (+ x1 dx) y2)))
  52.          ((= mode 9) (setq point pointmax))
  53.          (t (setq point pointmin))
  54.    )
  55.    point
  56.   )
  57.   (alert "指定图元最小外接矩形的九点坐标,通用函数错了!")
  58. )
  59. )
flytoday + 1 那段代码是没这些内容啊~
发表于 2013-2-4 16:43:20 | 显示全部楼层
版本太低,调试不了这个程序,粗略看了一下。你试试
1 面积 (strcat ap (rtos (* cf (vla-get-area p1)) 2) as)改前面  cf 0.001
2 ts 字的高度  (setq ts
这个地方是改标注编号的字高哦兄弟。。非画于图上表格中的字高  发表于 2013-2-4 16:55
 楼主| 发表于 2013-2-4 17:09:20 | 显示全部楼层
只要把两边的例设置成不一样宽度就好了。。。
麻烦哪位大师瞧下谢谢~
发表于 2013-2-4 18:01:37 | 显示全部楼层
我的cad版本太低,调试不了,你自己试试吧!
(setq tb
              (vla-addtable acspc
                (vlax-3D-point (trans pt 1 0)) 2 2 th (* 0.8 th (max (strlen t1) (strlen t2)))
表格的高 th 宽 (* 0.8 th (max (strlen t1) (strlen t2)))
求BOX点就好。
flytoday + 1 谢谢宽知道改哪里。要改两例不一样宽不懂~
 楼主| 发表于 2013-2-5 10:09:20 来自手机 | 显示全部楼层
哇沉滴好快…………顶起来
 楼主| 发表于 2013-2-5 17:11:20 来自手机 | 显示全部楼层
哇沉滴好快…………顶起来
回复 编辑
 楼主| 发表于 2013-2-6 16:22:15 来自手机 | 显示全部楼层
各位大师…麻烦改下嘛谢谢啦
GMT+8, 2025-8-27 04:13 , Processed in 0.191303 second(s), 32 queries , Gzip On.
