查看: 2213|回复: 2
菜鸟求助,Database 的saveas报错
发表于 2013-3-3 16:52:41 | 显示全部楼层 |阅读模式
  1. Imports Autodesk.AutoCAD.ApplicationServices
  2. Imports Autodesk.AutoCAD.EditorInput
  3. Imports Autodesk.AutoCAD.Runtime
  4. Imports Autodesk.AutoCAD.DatabaseServices
  5. Imports Autodesk.AutoCAD.Geometry
  6. Public Class Class1
  7.      _
  8.    Public Sub DWG()
  9.         Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
  10.         Dim db As Database = HostApplicationServices.WorkingDatabase
  11.         Dim TrimEdge As New Polyline  '裁剪边界
  12.         Dim JZD As New Polyline   '界址线
  13.         Dim trans As Transaction = db.TransactionManager.StartTransaction
  14.         Dim docLock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument
  15.         Try
  16.             Dim fillist_JZD() As TypedValue = {New TypedValue(DxfCode.LayerName, "JZD"), _
  17.                                           New TypedValue(70, "1")}
  18.             Dim res_JZD As PromptSelectionResult = ed.SelectAll(New SelectionFilter(fillist_JZD))  '选择所有界址线
  19.             If res_JZD.Status = PromptStatus.OK Then
  20.                 Dim ss As SelectionSet = res_JZD.Value
  21.                 For Each ID_JZD As ObjectId In ss.GetObjectIds
  22.                     JZD = trans.GetObject(ID_JZD, OpenMode.ForRead)
  23.                     Dim minPt As Point3d = JZD.GeomExtents.MinPoint
  24.                     Dim maxPt As Point3d = JZD.GeomExtents.MaxPoint
  25.                     Dim RecPts As New Point3dCollection
  26.                     RecPts.Add(New Point3d((minPt.X + maxPt.X) / 2 - 364, (minPt.Y + maxPt.Y) / 2 - 241, 0))
  27.                     RecPts.Add(New Point3d((minPt.X + maxPt.X) / 2 - 364, (minPt.Y + maxPt.Y) / 2 + 241, 0))
  28.                     RecPts.Add(New Point3d((minPt.X + maxPt.X) / 2 + 364, (minPt.Y + maxPt.Y) / 2 - 241, 0))
  29.                     RecPts.Add(New Point3d((minPt.X + maxPt.X) / 2 + 364, (minPt.Y + maxPt.Y) / 2 + 241, 0))
  30.                     TrimEdge = CreatePolyline(RecPts, True)   '根据界址线外接矩形生成裁剪边界
  31.                     Dim res_Other As PromptSelectionResult = ed.SelectCrossingWindow(TrimEdge.GeomExtents.MinPoint, TrimEdge.GeomExtents.MaxPoint) '根据裁剪边界外接矩形选择实体
  32.                     If res_Other.Status = PromptStatus.OK Then
  33.                         Dim ss1 As SelectionSet = res_Other.Value
  34.                         Dim idColl As ObjectIdCollection = New ObjectIdCollection(ss1.GetObjectIds)
  35.                         Dim ndb As Database = New Database(True, False)  '新建数据库
  36.                         Try
  37.                             db.WblockCloneObjects(idColl, ndb.CurrentSpaceId, DuplicateRecordCloning.Replace, False)  '不同数据库之间复制实体
  38.                             '裁剪,已经实现了主要实体裁剪
  39.                             ndb.SaveAs("c:\qqqq.dwg", DwgVersion.Current)  '在这个位置报错
  40.                             '即时窗口里面出现如下信息:
  41.                             '在 System.AccessViolationException 中第一次偶然出现的“acdbmgd.dll”类型的异常
  42.                             'Forgot to call Dispose? (Autodesk.AutoCAD.DatabaseServices.Polyline): DisposableWrapper
  43.                             'Forgot to call Dispose? (Autodesk.AutoCAD.DatabaseServices.Polyline): DisposableWrapper
  44.                             '如果是从TrimEdge = CreatePolyline(RecPts, True)开始单步,这样不会出错,从这句之后单步会报错。如果是直接运行也会报错。
  45.                         Catch ex As Exception
  46.                         Finally
  47.                             ndb.Dispose()
  48.                         End Try
  49.                     End If
  50.                 Next
  51.             End If
  52.         Catch ex As Exception
  53.         Finally
  54.             '提交事务,释放资源
  55.             trans.Commit()
  56.             trans.Dispose()
  57.             TrimEdge.Dispose()
  58.             JZD.Dispose()
  59.             docLock.Dispose()
  60.             db.Dispose()
  61.         End Try
  62.     End Sub
  63.     '''
  64.     ''' 创建多段线
  65.     '''
  66.     ''' 点集
  67.     ''' 是否闭合
  68.     '''
  69.     '''
  70.     Private Function CreatePolyline(ByVal ptColl As Point3dCollection, ByVal bl As Boolean) As Polyline
  71.         Dim pline As New Polyline
  72.         For i As Integer = 0 To ptColl.Count - 1
  73.             pline.AddVertexAt(i, ptColl(i).Convert2d(New Plane()), 0, 0, 0)
  74.         Next
  75.         pline.Closed = bl
  76.         Return pline
  77.     End Function
  78. End Class
开发环境:VS2008+.NET2.0+CAD2006
代码如上,这个是一个裁剪程序里面一小段,裁剪的主题部分已差不多了,我是准备new数据库来保存的,可是保存出错了,详细描述在注释里。希望高手们指导一下
发表于 2014-4-24 23:14:42 | 显示全部楼层
请高手回答下,我也遇到!
发表于 2014-4-27 23:42:56 | 显示全部楼层
已经搞定,原来是新建的DataBase没有BlockTable,需要先载入一个模板文件!
GMT+8, 2025-5-21 02:33 , Processed in 0.254138 second(s), 28 queries , Gzip On.
