查看: 1536|回复: 7
画正牙孔程序.lsp
发表于 2013-4-12 21:51:31 | 显示全部楼层 |阅读模式
                            图一
                              图二
(defun c:Ar (/)
  (setvar "cmdecho" 0)
  (setq M (getDIST "\n-->请输入正牙孔M?<8>:"))
  (if (= M nil) (setq M 8))
  (cond ((= M 16) (progn (SETQ c 16.0) (setq d 14.5)))
        ((= M 14) (progn (SETQ c 14.0) (setq d 12.5)))
        ((= M 12) (progn (SETQ c 12.0) (setq d 10.5)))
        ((= M 10) (progn (SETQ c 10.0) (setq d 8.5)))
        ((= M 8)  (progn (SETQ c 8.0)  (setq d 6.9)))
        ((= m 6) (progn (SETQ c 6.0)  (setq d 5.1)))
        ((= m 5) (progn (SETQ c 5.0)  (setq d 4.3)))
        ((= M 4) (progn (SETQ c 4.0)  (setq d 3.4)))
        ((= M 3) (progn (SETQ c 3.0)  (setq d 2.5))))
    (SETQ PT (GETPOINT "\n-->请选取插入点:"))
      (while pt
          (command "circle" pt (/ d 2) "")
          (command "circle" pt (/ c 2) "")
             (command "break"(entlast) "none" "@0.5,-2" "none" "@3,3")
             (command "line" "none" "@-8.5,-1" "none" "@10,0" "")
             (command "change"(entlast) "" "p" "lt" "center" "lts"1 "" "")
             (command "line" "none" "@-5,-5" "none" "@0,10" "")
     (setq pt (getpoint "\n-->请选取插入点:")))
此程序还须进一步完善一下,如何修改才能达到图二,请高手指点迷津,谢谢。
 楼主| 发表于 2013-4-12 21:56:03 | 显示全部楼层
补充附件
 楼主| 发表于 2013-4-13 21:10:37 | 显示全部楼层
有人会修改程序吗?
发表于 2013-4-15 01:04:01 | 显示全部楼层
改上面这两段
自己试试便知该如何改了
很有 显的这两段是 划 中心线的!!!
 楼主| 发表于 2013-4-15 20:20:08 | 显示全部楼层
(command "line" "none" "@-5,-5" "none" "@0,10" ...
谢谢你指点
 楼主| 发表于 2013-4-15 20:30:48 | 显示全部楼层
此程序的缺点是
     A、画M3、M4、M5、M6的十字中心线过长;
     B、画M10、M12、M14、M16的十字中心线太短。
              请高手指点迷津
发表于 2013-4-16 08:24:19 | 显示全部楼层
  1. (defun c:SAr (/)
  2. (setvar "CMDECHO" 0)
  3. (setq M (getDIST "\n-->请输入正牙孔M?<8>:"))
  4. (if (= M nil) (setq M 8))
  5. (cond
  6.   ((<= 2 M 3) (SETQ c 3.0 d 2.5))
  7.   ((<= 3.1 M 4) (SETQ c 4.0 d 3.4))
  8.   ((<= 4.1 m 5) (SETQ c 5.0 d 4.3))
  9.   ((<= 5.1 m 6) (SETQ c 6.0 d 5.1))
  10.   ((<= 6.1 M 8) (SETQ c 8.0 d 6.9))
  11.   ((<= 8.1 M 10) (SETQ c 10.0 d 8.5))
  12.   ((<= 10.1 M 12) (SETQ c 12.0 d 10.5))
  13.   ((<= 12.1 M 14) (SETQ c 14.0 d 12.5))
  14.   ((<= 14.1 M 16) (SETQ c 16.0 d 14.5))
  15. )
  16. (while (SETQ PT (GETPOINT "\n-->请选取插入点:"))
  17.   (setq p1 (polar pt (/ pi -6) (/ c 2))
  18.         p2 (polar pt (/ pi 3) (/ c 2))
  19.         p3 (polar pt 0 (+ (/ c 2) 3));比直径长6
  20.         p4 (polar pt pi (+ (/ c 2) 3))
  21.         p5 (polar pt (/ pi 2) (+ (/ c 2) 3))
  22.         p6 (polar pt (/ pi -2) (+ (/ c 2) 3)))
  23.   (command "_.CIRCLE" "none" pt (/ d 2) "_.ARC" "none" p2 "C" "none" pt "none" p1)
  24.   (command "_.LINE" "none" p3 "none" p4 "" "_.CHPROP" "L" "" "lt" "center" "lts" 1 "")
  25.   (command  "_.LINE" "none" p5 "none" p6 "" "_.CHPROP" "L" "" "lt" "center" "lts" 1 "")
  26. )
  27. (setvar "CMDECHO" 1)
  28. (princ)
  29. )
 楼主| 发表于 2013-4-16 20:16:50 | 显示全部楼层
ZZXXQQ 发表于 2013-4-16 08:24
谢谢版主的修改
GMT+8, 2025-5-31 18:36 , Processed in 0.201150 second(s), 31 queries , Gzip On.
