查看: 1770|回复: 3
[讨论] 把此贴删除
发表于 2013-4-16 00:05:37 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2013-4-16 08:46:11 | 显示全部楼层
  1. (defun c:a ()
  2. (setq lst (ssget "X" '((0 . "POINT"))))
  3. (setq i -1)
  4. (repeat (sslength lst)
  5.   (setq en (ssname lst (setq i (1+ i))))
  6.   (z6 (cdr(assoc 10 (entget en))))
  7. )
  8. (princ)
  9. )
  10. (defun Z6 (pm / )
  11. (setvar "cmdecho" 0)
  12. (graphscr)
  13. (setq xp (* (sqrt 2) (/ 600 2))
  14.        xp1 (polar pm (/ pi 4) xp)
  15.        xp2 (polar pm (/ pi -4) xp)
  16.        xp3 (polar pm (/ pi 4) (- xp))
  17.        xp4 (polar pm (/ pi -4) (- xp))
  18. )
  19. (COMMAND "LAYER" "MAKE" "colu" "COLOR" "4" "colu" "")
  20. (command "pline" xp1 "W" 0 0 xp2 xp4 xp3 "c")
  21. (setvar "CMDECHO" 1)
  22. (princ)
  23. )
500w008 + 1 很给力!
 楼主| 发表于 2013-4-16 16:23:21 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2013-4-16 17:51:19 | 显示全部楼层
500w008 发表于 2013-4-16 16:23
如果按照 lambda 形式改呢
;;;批量選點寫柱--求更正
(defun c:a4 ()
(setq lstp (mapcar '(lambda (x) (cdr x)) (qq-ss2lst lst 10)))
           (mapcar '(lambda (x) (z6 x)) lstp)
(defun Z6 (pm / )
  (graphscr)
  (setq gas (/ pi 180)
        xp1 (polar pm (* gas 45) xp)
        xp2 (polar pm (* gas -45) xp)
        xp3 (polar pm (* gas 135) xp)
        xp4 (polar pm (* gas -135) xp)
  (command "pline" xp1 xp2 xp4 xp3 "c")
  (setq jds (entlast))
  (command ".chprop" jds "" "LA" "colu" "")
  (command "PEDIT" "M" jds "" "W" 0 "")
(defun qq-ss2lst (SS S0 / lst n ssnamen)
  (setq n -1
lst '()
  (while (and
             (setq ssnamen (ssname ss (setq n (1+ n))))
             (setq ss-11 (cdr (assoc S0 (entget ssnamen))))
    (setq lst (cons (append (list ssnamen) ss-11) lst))
  (reverse lst)
500w008 + 1 很给力!
GMT+8, 2025-9-26 17:12 , Processed in 0.176654 second(s), 30 queries , Gzip On.
