查看: 2941|回复: 5
[基础] 删除单个复合线顶点
发表于 2013-4-18 16:55:02 | 显示全部楼层 |阅读模式
;;;;删除单个复合线顶点(不是本人编写,只是想跟大家分享)
(defun c:xs1()
(setvar "cmdecho" 0)
(princ "\n删除单个复合线顶点")
(setq a (entsel "\n选择要删除的顶点:"))
;;第一层if开始
(if a (progn
;;第一层progn开始
(setq p1 (cadr a))
(setq p1 (reverse p1))
(setq p1 (cdr p1))
(setq xylt (car a))
(setq a2 (entget xylt))
;;第二层if开始
(if (or (= (cdr (ASSOC '0 a2)) "POLYLINE") (= (cdr (ASSOC '0 a2)) "LWPOLYLINE")) (progn
;;第二层progn开始
(setq osvar (getvar "osmode"))
(setvar "osmode" 0)
(setq ss1 (ssget "I"))
(if (and ss1 (= (sslength ss1) 1)) (progn
(setq mmm (cdr (assoc '0 (entget (ssname ss1 0)))))
(if (or (= mmm "POLYLINE") (= mmm "LWPOLYLINE"))
(command "pedit" "")
);if
(if (or (= mmm "ARC") (= mmm "LINE"))
(command)
);if
);progn
);if
(setq ss1 nil)
(xy_lt)
(setq pp1 p1)
(dd_shu)
;;第三层if开始
(if (> (length po_all) 2) (progn
;;第三层progn开始
(if (> ped 129) (command "pedit" xylt "D" ""))
(setq tyname (cdr (ASSOC '0 a2)))
(cond ((= tyname "LWPOLYLINE")
       (dd_lw)
       (if (and (> len 3) (or (= ped 132) (= ped 133))) (command "pedit" xylt "S" ""))
      ((= tyname "POLYLINE")
       (dd_po)
);cond
(if (and (> len 3) (or (= ped 130) (= ped 131))) (command "pedit" xylt "F" ""))
(if (and (= len 3) (or (= ped 129) (= ped 131) (= ped 133))) (command "pedit" xylt "O" ""))
);progn
;;第三层progn结束
(princ "\n复合线只剩2个顶点,无法删除!")
);if
;;第三层if结束
(setvar "osmode" osvar)
);progn
;;第二层progn结束
(princ "\n选择的不是复合线!")
);if
;;第二层if结束
);progn
;;第一层progn结束
(princ "\n没有选中目标!")
);if
;;第一层if结束
);defun
;;删简单复合线函数
(defun dd_lw()
(setq tylist nil len (length a2) tyn (cons 90 (- (cdr (assoc '90 a2)) 1)) n 0 n1 0)
(while (< n len)
(setq tylist1 (nth n a2))
(if (/= (type (cdr tylist1)) (type (list 1 1)))
(if (= tylist nil)
(setq tylist (list tylist1))
(setq tylist (cons tylist1 tylist))
);if
(if (= n1 nn)
(setq n (+ n 3) n1 (+ n1 1))
(setq tylist (cons tylist1 tylist) n1 (+ n1 1))
);if
);if
(setq n (+ n 1))
);while
(setq tylist (subst tyn (assoc '90 tylist) tylist))
(setq n 0 len (length po_all))
(setq tylist (reverse tylist))
(entmod tylist)
);defun
;;删复杂复合线函数
(defun dd_po()
(sh_ch)
(setq n nn len (length po_all))
(if (and (/= n 0) (/= n (- (length po_all) 1))) (setq nn1 (- n 1)  nn2 (+ n 1)))
(if (= n 0) (setq nn1 0  nn2 (+ n 2) pp (nth (+ n 1) po_all)))
(if (= n (- (length po_all) 1)) (setq nn1 (- n 2)  nn2 n pp (nth (- n 1) po_all)))
(command "pedit" xylt "e")
(setq nn 0)
(while (< nn nn1)
(command "")
(setq nn (+ nn 1))
);while
(command "s")
(while (< nn nn2)
(command "")
(setq nn (+ nn 1))
);while
(command "g")
(if (= n 0) (command "m" pp))
(if (= n (- (length po_all) 1)) (command "" "m" pp))
(command "x" "")
(command "zoom" "p")
);defun
;;复合线视窗函数
(defun sh_ch()
(setq p 0)
(while (< p (length po_all))
(setq x (car (nth p po_all)) y (cadr (nth p po_all)))
(if (= p 0) (setq xx x yx y xm x ym y)
(if (< x xx) (setq xx x))
(if (> x xm) (setq xm x))
(if (< y yx) (setq yx y))
(if (> y ym) (setq ym y))
);progn
);if
(setq p (+ p 1))
);while
(command "zoom" "w" (list (- xx 1) (- yx 1)) (list (+ xm 1) (+ ym 1)))
);defun
;;;函数,顶点数
(defun dd_shu()
(setq n 0)
(setq nn 0)
(setq pp (nth 0 po_all))
(setq d0 (distance pp pp1))
(while (< n (length po_all))
(setq pp (nth n po_all))
(setq d1 (distance pp pp1))
(if (< d1 d0) (progn
(setq nn n)
(setq d0 d1)
);progn
);if
(setq n (+ n 1))
);while
);defun
(defun xy_lt()
(setq po_all nil)
(setq nst2 (entget xylt))
(setq mmm (cdr (assoc '0 nst2)))
(if (or (= mmm "POLYLINE") (= mmm "LWPOLYLINE")) (progn
(setq ped (cdr (ASSOC '70 nst2)))
(if (< ped 6) (progn
(command "pedit" xylt "l" "on" "")
);progn
);if
(cond ((= mmm "LWPOLYLINE")
(while (> (length nst2) 0)
(setq pp (nth 0 nst2))
(if (and (= (type (cdr pp)) (type (list 10.0 10.0))) (= (nth 0 pp) 10)) (progn
(setq pp (cdr pp))
(setq po_all (reverse po_all))
(setq po_all (cons pp po_all))
)progn
);if
(setq nst2 (cdr nst2))
);while
((= mmm "POLYLINE")
(setq nst1 xylt)
(while (and (setq nst1 (entnext nst1)) (/= (cdr (assoc '0 (setq nst2 (ENTGET NST1)))) "SEQEND"))
(if (= (cdr (assoc '70 nst2)) (cdr (assoc '70 (entget (entnext xylt))))) (progn
(setq pp (cdr (assoc '10 nst2)))
(setq pp (reverse pp))
(setq pp (cdr pp))
);progn
);if
);while
);cond
);progn
);if
);defun
tryhi + 1
发表于 2013-10-29 12:20:29 | 显示全部楼层
缺少自定义函数
 楼主| 发表于 2013-11-2 13:08:23 | 显示全部楼层
hehoubin 发表于 2013-10-29 12:20
缺少自定义函数
已补上欠缺的自定义函数
发表于 2013-11-2 14:15:42 | 显示全部楼层
觉得太复杂了
黄老师,那你能不能简化一下呢?  发表于 2013-11-2 14:49
发表于 2013-11-2 14:55:05 | 显示全部楼层
仅供参考
;;示例(HH:delLwpolyPt1 (car(setq en(entsel))) (cadr en))
(defun HH:delLwpolyPt1 (en p / ENT L1 L2 P1)
  (setq ENT (entget en))
  (setq p (vlax-curve-getclosestpointto en (trans p 1 0)))
  (setq p1 (HH:PickClosePt en p))                            ;离p最近的顶点
  (setq p1 (list 10 (car p1) (cadr p1)))
  (setq L2 (cdr (member p1 ent)))                            ;后段
  (setq L1 (reverse (cdr (member p1 (reverse ent)))))            ;前段
  (entmod (append L1 L2))
http://bbs.mjtd.com/thread-108149-1-1.html见HH:PickClosePt
老师,HH:PickClosePt这个函数我没有  发表于 2013-11-2 15:02
谢谢,学习了!向老师学习,呵呵  发表于 2013-11-2 14:58
发表于 2016-3-18 22:14:28 | 显示全部楼层
HH:PickClosePt这个函数没有啊
GMT+8, 2025-8-23 09:39 , Processed in 0.179996 second(s), 28 queries , Gzip On.
