查看: 1332|回复: 0
[基础] 麻烦各位高手帮忙
发表于 2013-4-23 11:31:40 | 显示全部楼层 |阅读模式
麻烦各位高手帮忙,把下面的程序修改一下,改为螺钉,现在是螺纹孔,我想改为图片所示的样子,见图片:
(defun c:TT(/)
(setvar "CMDECHO" 0)
(setq M (getDIST "\n 请输入螺纹规格 M8输入8"))
(if (= M nil) (setq M 8))
(cond
  ((<= 1.1 M 2) (SETQ c 2 d 1.6))
  ((<= 2.1 M 2.5) (SETQ c 2.5 d 2))
  ((<= 2.6 M 3) (SETQ c 3.0 d 2.4))
  ((<= 3.1 M 4) (SETQ c 4.0 d 3.2))
  ((<= 4.1 m 5) (SETQ c 5.0 d 4))
  ((<= 5.1 m 6) (SETQ c 6.0 d 4.8))
  ((<= 6.1 M 8) (SETQ c 8.0 d 6.4))
  ((<= 8.1 M 10) (SETQ c 10.0 d 8))
  ((<= 10.1 M 12) (SETQ c 12.0 d 9.6))
  ((<= 12.1 M 14) (SETQ c 14.0 d 11.2))
  ((<= 14.1 M 16) (SETQ c 16.0 d 12.8))
(while (SETQ PT (GETPOINT "\n请选取插入点:"))
  (setq p1 (polar pt (/ pi -6) (/ c 2))
        p2 (polar pt (/ pi 3) (/ c 2))
        p3 (polar pt 0 (+ (/ c 2) 0.5));比直径长1
        p4 (polar pt pi (+ (/ c 2) 0.5))
        p5 (polar pt (/ pi 2) (+ (/ c 2) 0.5))
        p6 (polar pt (/ pi -2) (+ (/ c 2) 0.5)))
  (command "_.CIRCLE" "none" pt (/ d 2) p1)
  (command "change" "l" "" "p" "la" "0" "")
  (command "_.ARC" "none" p2 "C" "none" pt "none" p1)
  (command "change" "l" "" "p" "la" "细实线" "")
  (command "_.LINE" "none" p3 "none" p4 "" "_.CHPROP" "L" "" "lt" "bylayer" "lts" 1 "")
  (command "change" "l" "" "p" "la" "点划线" "")
  (command  "_.LINE" "none" p5 "none" p6 "" "_.CHPROP" "L" "" "lt" "bylayer" "lts" 1 "")
(setvar "CMDECHO" 1)
GMT+8, 2025-9-26 17:12 , Processed in 0.184978 second(s), 30 queries , Gzip On.
