查看: 1023|回复: 2
求助,请高手帮看看程序哪出了问题
发表于 2013-4-27 10:46:07 | 显示全部楼层 |阅读模式
写了个小程序自己用,一直都没有问题,但刚碰到个图就不行了,请高手帮忙分析下哪出问题了,非常感谢
;处理建筑图<0,Defpoints层移动至建筑临时层>
(defun c:clJZ ( / YY_QIANZ *doc* LAY LAYERS OLDMING ss)
(Setvar "Cmdecho" 0)
(vl-load-com)
(if (= (tblsearch "layer" "ZZ-Wall") nil)
(setq ss (ssget "X" '((8 . "0,Defpoints"))))
  (if (/= ss nil)
        (if (not (tblsearch "layer" "建筑临时层"))
            (command ".layer" "m" "建筑临时层" "")
        (command "chprop" ss "" "la" "建筑临时层" "")
  (setq YY_QIANZ "ZZ-")
  (if YY_QIANZ
  (setq *doc* (vla-get-activedocument (vlax-get-acad-object))
    layers (vla-get-layers *doc*)
  (vlax-for lay layers (setq OLDMING (vla-get-name lay))
        (if (not (member OLDMING '("0" "Defpoints")))
          (vla-put-Name lay (strcat YY_QIANZ OLDMING))
  (princ "已将建筑全部图层加前缀“ZZ-”<0,Defpoints层移动至建筑临时层>")
(alert "您已经处理过建筑图,请不要重复处理")
(Setvar "Cmdecho" 1)
发表于 2013-4-27 11:19:36 | 显示全部楼层
對別人的圖檔處理,有時找不出程序錯誤的原因,可以先試試將圖檔內容複製,再開新檔案貼上
 楼主| 发表于 2013-4-27 11:20:40 | 显示全部楼层
谢谢。这个方法我试过了
GMT+8, 2025-5-23 12:00 , Processed in 0.190466 second(s), 30 queries , Gzip On.
