查看: 1844|回复: 2
求助:关于创建AutoCAD菜单的疑问
发表于 2003-9-6 16:39:00 | 显示全部楼层 |阅读模式
第一次运行时没有问题,但后来再运行时不知道为什么“Public Sub DeleteMenu()”段就运行不了,说是方法“Item"作用于"IAcadPopupmenus"失败。我将菜单名改为中文时也会出现错误。
Public Sub CreateMenu()
    Dim curMenuGroup As AcadMenuGroup
    Set curMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    Dim newMenu As AcadPopupMenu
    Set newMenu = curMenuGroup.Menus.Add("Te" + Chr(Asc("&")) + "stMenu1")
    Dim openMacro As String
    Dim saveMacro As String
    Dim editMacro As String
    openMacro = Chr(3) + Chr(3) + Chr(95) + "open" + Chr(32) '即VBA中的ESC ESC _Open
    saveMacro = Chr(3) + Chr(3) + Chr(95) + "save" + Chr(32) '即VBA中的ESC ESC _Save
    editMacro = Chr(3) + Chr(3) + Chr(95) + "edit" + Chr(32) '即VBA中的ESC ESC _Edit
    Dim openMenuItem As AcadPopupMenuItem
    Dim saveMenuItem As AcadPopupMenuItem
    Dim editMenuItem As AcadPopupMenuItem
    Dim sepaMenuItem As AcadPopupMenuItem
    Set openMenuItem = newMenu.AddMenuItem _
         (newMenu.Count + 1, Chr(Asc("&")) + "Open", openMacro)
    Set sepaMenuItem = newMenu.AddSeparator(newMenu.Count + 1)
    Set saveMenuItem = newMenu.AddMenuItem _
         (newMenu.Count + 1, Chr(Asc("&")) + "Save", saveMacro)
    Set editMenuItem = newMenu.AddMenuItem _
         (newMenu.Count + 1, Chr(Asc("&")) + "Edit", editMacro)
        Dim saveasSubMenu As AcadPopupMenu
        Set saveasSubMenu = newMenu.AddSubMenu(newMenu.Count + 1, "SaveAsFile")
        Dim subMenuItem As AcadPopupMenuItem
        Dim subMacro As String
        subMacro = Chr(3) + Chr(3) + Chr(95) + "SaveAs" + Chr(32)
        Set subMenuItem = saveasSubMenu.AddMenuItem _
                  (saveasSubMenu.Count + 1, "SaveAs", subMacro)
    editMenuItem.Enable = False
    newMenu.InsertInMenuBar (ThisDrawing.Application.MenuBar.Count + 1)
End Sub
Public Sub CreateShortCutMenu()
    Dim scMenu As AcadPopupMenu
    Dim entMenu As AcadPopupMenu
    For Each entMenu In curMenuGroup.Menus
      If entMenu.ShortcutMenu = True Then
        Set scMenu = entMenu
      Else
        Exit Sub
      End If
    Next entMenu
    Dim scMenuItem As AcadPopupMenuItem
    Set scMenuItem = scMenu.AddMenuItem _
               (scMenu.Count + 1, Chr(Asc("&")) + "OpenDWG", openMacro)
End Sub
    Dim oldMenu As AcadPopupMenu
    Set oldMenu = curMenuGroup.Menus.Item("Te" + Chr(Asc("&")) + "stMenu")
     oldMenu.RemoveFromMenuBar
End Sub
 楼主| 发表于 2003-9-6 16:44:00 | 显示全部楼层
这也许是个非常简单的问题,不过我实在是刚开始学,什么也不懂,还是要指高人指点^_^
发表于 2003-9-6 17:50:00 | 显示全部楼层
你少了一个1怎么能删除呢。
    Set oldMenu = curMenuGroup.Menus.Item("Te" + Chr(Asc("&")) + "stMenu1")
GMT+8, 2025-5-24 15:20 , Processed in 0.160670 second(s), 23 queries , Gzip On.
