查看: 5684|回复: 8
[提问] 加载菜单
发表于 2013-5-21 11:44:30 | 显示全部楼层 |阅读模式
图一未加载前
图二已加载菜单
图三已加载菜单
菜单文件名为xzh.mns
//      AutoCAD 菜单文件 - C:\xzh\xzh.mns
***MENUGROUP=xzh
***POP12
               [★绘图&A]
               [绘连孔]^C^C(load "xzh");y
               [绘复孔]^C^C(load "xzh");n
               [绘圆孔]^C^C(load "xzh");c
               [两切圆]^C^C(load "xzh");2t
               [三切圆]^C^C(load "xzh");3t
               [沉头孔]^C^C(load "xzh");ah
               [正牙孔]^C^C(load "xzh");ar
               [背牙孔]^C^C(load "xzh");ab
               [合销孔]^C^C(load "xzh");al
               [长形孔]^C^C(load "xzh");at
               [基准孔]^C^C(load "xzh");ai
               [止高孔]^C^C(load "xzh");AX
               [->常用选项]
                 [绘长横线]^C^C(load "xzh");HH
                 [绘长竖线]^C^C(load "xzh");VV
                 [平行中线]^C^C(load "xzh");AM
                 [绘中心线]^C^C(load "xzh");AG
                 [绘不垂线]^C^C(load "xzh");An
                 [绘制箭头]^C^C(load "xzh");jt
                 [绘多边形]^C^C(load "xzh");AA
                 [绘制矩形]^C^C(load "xzh");AO
                 [<-快速修剪]^C^C(load "xzh");tt
               [->一般选项]
                 [绘五角星]^C^C(load "xzh");5j
                 [提取命令]^C^C(load "xzh");88
                 [提取图层]^C^C(load "xzh");ca
                 [圆穿丝孔]^C^C(load "xzh");AE
                 [方穿丝孔]^C^C(load "xzh");AS
                 [<-绘制曲线]^C^C(load "xzh");hx
               [同层复制]^C^C(load "xzh");CV
               [多层复制]^C^C(load "xzh");AD
               [旋    转]^C^C(load "xzh");AC
               [闭合图形]^C^C(load "xzh");AK
               [分等间距]^C^C(load "xzh");AV
               [圆内切线]^C^C(load "xzh");qx
               [单倒直角]^C^C(load "xzh");FF
               [单倒圆角]^C^C(load "xzh");R
               [连倒 C角]^C^C(load "xzh");CX
               [框倒圆角]^C^C(load "xzh");F
               [绘圆中线]^C^C(load "xzh");zx
               [修改 R角]^C^C(load "xzh");xr
***POP13
               [★修编&D]
               [圆弧变圆]^C^C(load "xzh");DF
               [图层变更]^C^C(load "xzh");DB
               [颜色变更]^C^C(load "xzh");DC
               [两圆重合]^C^C(load "xzh");DX
               [修改直经]^C^C(load "xzh");DD
               [大小圆变]^C^C(load "xzh");xz
               [局部放大]^C^C(load "xzh");DH
               [缩变比例]^C^C(load "xzh");DM
               [变色打印]^C^C(load "xzh");tz
               [调为整数]^C^C(load "xzh");DS
               [找重复图]^C^C(load "xzh");DQ
               [删重复图]^C^C(load "xzh");DE
               [平行取整]^C^C(load "xzh");DA
               [改线长度]^C^C(load "xzh");DG
               [单个打断]^C^C(load "xzh");BD
               [插入日期]^C^C(load "xzh");RQ
               [插入名字]^C^C(load "xzh");MZ
               [->系统变量]
                 [文字样式]^C^C(load "xzh");yw
                 [标注样式]^C^C(load "xzh");bs
                 [设系统量]^C^C(load "xzh");K
                 [清理管理]^C^C(load "xzh");qv
                 [窗口切换]^C^C(load "xzh");D
                 [调计算器]^C^C(load "xzh");js
                 [简繁转换]^C^C(load "xzh");jh
                 [<-启gif录制]^C^C(load "xzh");gi
               [->文字编辑]
                 [设置字高]^C^C(load "xzh");TS
                 [修改字高]^C^C(load "xzh");DT
                 [文字编辑]^C^C(load "xzh");GT
                 [查换文字]^C^C(load "xzh");DN
                 [改大小写]^C^C(load "xzh");CF
                 [字左对齐]^C^C(load "xzh");ZA
                 [字中对齐]^C^C(load "xzh");ZS
                 [字右对齐]^C^C(load "xzh");ZD
                 [<-动态文本]^C^C(load "xzh");HC
               [->图块选项]
                 [快速建块]^C^C(load "xzh");G
                 [图块改色]^C^C(load "xzh");KS
                 [改块名点]^C^C(load "xzh");BB
                 [分解图块]^C^C(load "xzh");DJ
                 [图块替换]^C^C(load "xzh");DP
                 [<-文字编辑]^C^C(load "xzh");gt
               [->线型选项]
                 [实改虚线]^C^C(load "xzh");DW
                 [改中心线]^C^C(load "xzh");DV
                 [改双点线]^C^C(load "xzh");XX
                 [虚改实线]^C^C(load "xzh");DI
                 [<-改变线宽]^C^C(load "xzh");DK
               [测孔距离]^C^C(load "xzh");DU
               [测量长度]^C^C(load "xzh");DL
               [算圆数量]^C^C(load "xzh");SS
               [计算面积]^C^C(load "xzh");SQ
               [算长画出]^C^C(load "xzh");SC
***POP14
               [★模具&S]
               [->展开选项]
                 [弯曲展开]^C^C(load "xzh");ZK
                 [展开计算]^C^C(load "xzh");SQ
                 [翻孔展开]^C^C(load "xzh");SF
                 [矩形展开]^C^C(load "xzh");SR
                 [<-反折压平]^C^C(load "xzh");SG
               [->计算选项]
                 [排版计算]^C^C(load "xzh");SY
                 [计算弹簧]^C^C(load "xzh");So
                 [单重计算]^C^C(load "xzh");SD
                 [算冲裁力]^C^C(load "xzh");PT
                 [抽芽高度]^C^C(load "xzh");CH
                 [算脱料力]^C^C(load "xzh");ST
                 [算线割费]^C^C(load "xzh");SX
                 [<-算利用率]^C^C(load "xzh");SE
               [入块外形]^C^C(load "xzh");AF
               [设变55号]^C^C(load "xzh");DZ
               [设计变更]^C^C(load "xzh");DY
               [设变符号]^C^C(load "xzh");sb
               [图层分离]^C^C(load "xzh");ct
               [增分模板]^C^C(load "xzh");fm
               [绘制螺杆]^C^C(load "xzh");lg
               [绘制模柄]^C^C(load "xzh");MB
               [->表框库项]
                 [模板框]^C^C(load "xzh");T1
                 [产品框]^C^C(load "xzh");T2
                 [属性库]^C^C(load "xzh");TK
                 [文字库]^C^C(load "xzh");SV
                 [上模座]^C^C(load "xzh");8a
                 [上垫板]^C^C(load "xzh");8u
                 [固定板]^C^C(load "xzh");8h
                 [止高板]^C^C(load "xzh");8k
                 [脱料板]^C^C(load "xzh");8s
                 [凹模板]^C^C(load "xzh");8d
                 [下垫板]^C^C(load "xzh");8b
                 [下模座]^C^C(load "xzh");8l
                 [冲子层]^C^C(load "xzh");8p
                 [入块层]^C^C(load "xzh");8n
                 [中空板]^C^C(load "xzh");8t
                 [内脱板]^C^C(load "xzh");8q
                 [下脱板]^C^C(load "xzh");8z
                 [下夹板]^C^C(load "xzh");8w
                 [绘表格]^C^C(load "xzh");bg
                 [<-备料单]^C^C(load "xzh");bl
               [绘连续模]^C^C(load "xzh");YXM
               [绘复合模]^C^C(load "xzh");FHM
               [绘止高柱]^C^C(load "xzh");ZG
               [螺孔视图]^C^C(load "xzh");AQ
               [沉孔视图]^C^C(load "xzh");AW
               [->标准件]
                 [标准件库]^C^C(load "xzh");V
                 [直形冲子]^C^C(load "xzh");cz1
                 [二级冲子]^C^C(load "xzh");cz2
                 [三级冲子]^C^C(load "xzh");cz3
                 [引导冲子]^C^C(load "xzh");cz4
                 [六角螺丝]^C^C(load "xzh");cb
                 [外导柱套]^C^C(load "xzh");pg
                 [绘等高套]^C^C(load "xzh");csr
                 [绘两用销]^C^C(load "xzh");gls
                 [绘顶料销]^C^C(load "xzh");lps
                 [绘内导柱]^C^C(load "xzh");gp
                 [绘圆柱销]^C^C(load "xzh");lp
                 [绘制弹簧]^C^C(load "xzh");sp2
                 [<-画抽牙冲]^C^C(load "xzh");fb
***POP15
               [★标注&W]
               [标孔代号]^C^C(load "xzh");Zn
               [制加工表]^C^C(load "xzh");CD
               [调批孔号]^C^C(load "xzh");MC
               [调注尺文]^C^C(load "xzh");TC
               [->常用标注]
                 [直线标注]^C^C(load "xzh");1
                 [直径标注]^C^C(load "xzh");2
                 [半径标注]^C^C(load "xzh");3
                 [角度标注]^C^C(load "xzh");4
                 [斜线标注]^C^C(load "xzh");5
                 [弧长标注]^C^C(load "xzh");6
                 [线径标注]^C^C(load "xzh");WD
                 [标注RC角]^C^C(load "xzh");WA
                 [<-引线标注]^C^C(load "xzh");WV
               [->坐标标注]
                 [原点标注]^C^C(load "xzh");OI
                 [水平标注]^C^C(load "xzh");WY
                 [垂直标注]^C^C(load "xzh");WH
                 [坐标标注]^C^C(load "xzh");WZ
                 [<-局部标注]^C^C(load "xzh");JB
               [->普通标注]
                 [标注C角]^C^C(load "xzh");CJ
                 [标注序号]^C^C(load "xzh");WQ
                 [修改比例]^C^C(load "xzh");WG
                 [尺寸颜色]^C^C(load "xzh");WC
                 [显修精度]^C^C(load "xzh");WS
                 [<-尺改文本]^C^C(load "xzh");WK
               [形位公差]^C^C(load "xzh");xw
               [标改公差]^C^C(load "xzh");GC
               [标修公差]^C^C(load "xzh");WT
               [删除尺寸]^C^C(load "xzh");WX
               [删除文尺]^C^C(load "xzh");EE
               [删除文字]^C^C(load "xzh");ER
               [删除标注]^C^C(load "xzh");WB
               [删层文字]^C^C(load "xzh");WE
***POP16
               [★图层&Q]
               [单开模板层]^C^C(load"xzh");B
               [设为当前层]^C^C(load "xzh");qs
               [单开选输层]^C^C(load "xzh");qg
               [冻结选输层]^C^C(load "xzh");qf
               [锁住选输层]^C^C(load "xzh");qL
               [加开输入层]^C^C(load "xzh");qt
               [关闭选重层]^C^C(load "xzh");qz
               [解锁所有层]^C^C(load "xzh");QU
               [全开所有层]^C^C(load "xzh");qd
               [单开上模图]^C^C(load "xzh");sm
               [单开下模图]^C^C(load "xzh");xm
               [开复上模图]^C^C(load "xzh");FS
               [开复下模图]^C^C(load "xzh");FX
               [单开组立图]^C^C(load "xzh");qc
               [单开料带图]^C^C(load "xzh");qa
               [单开产料图]^C^C(load "xzh");qq
               [关闭标注层]^C^C(load "xzh");qm
***TOOLBARS
**TB_XZH_BZ
**标准
               [_Toolbar("标准", _Top, _Show, 0, 0, 1)]
               [_Button("新建", "RCDATA_16_NEW", "RCDATA_16_NEW")]^C^C_qnew
               [_Button("打开", "RCDATA_16_OPEN", "RCDATA_16_OPEN")]^C^C_open
               [_Button("保存", "RCDATA_16_SAVE", "RCDATA_16_SAVE")]^C^C_qsave
               [_Button("打印", "RCDATA_16_PRINT", "RCDATA_16_PRINT")]^C^C_plot
               [_Button("预览", "RCDATA_16_PREVIEW", "RCDATA_16_PREVIEW")]^C^C_preview
               [_Button("变色打印", "tz.BMP", "tz.BMP")]^C^C(load "v");tz
               [_Button("调计算器", "jsq.BMP", "jsq.BMP")]^C^C(load "xzh");JSQ
               [_Control(_Undo)]
               [_Control(_Redo)]
               [_Button("标注样式管理器", "样式.BMP", "样式.BMP")]'_dimstyle
               [_Control(_DimStyle)]
               [_Button("文字样式管理器", "RCDATA_16_TXTSTYLE", "RCDATA_16_TXTSTYLE")]'_style
               [_Control(_TxtStyle)]
**TB_XZH_Q
**图层
               [_Toolbar("图层", _Top, _Show, 1, 0, 1)]
               [_Button("设为当前层", "qs.bmp", "qs.BMP")]^C^C(load "xzh");qs
               [_Button("单开选输层", "qg.BMP", "qg.BMP")]^C^C(load "xzh");qg
               [_Button("冻结选输层", "qf.BMP", "qf.BMP")]^C^C(load "xzh");qf
               [_Button("锁住选输层", "ql.BMP", "ql.BMP")]^C^C(load "xzh");ql
               [_Button("加开输入层", "qt.BMP", "qt.BMP")]^C^C(load "xzh");qt
               [_Button("关闭选重层", "qz.BMP", "qz.BMP")]^C^C(load "xzh");qz
               [_Button("解锁所有层", "QU.BMP", "QU.BMP")]^C^C(load "xzh");qu
               [_Button("全开所有层", "qd.BMP", "qd.BMP")]^C^C(load "xzh");qd
               [_Button("单开上模图", "sm.BMP", "sm.BMP")]^C^C(load "xzh");sm
               [_Button("单开下模图", "xm.BMP", "xm.BMP")]^C^C(load "xzh");xm
               [_Button("开复上模图", "FS.BMP", "FS.BMP")]^C^C(load "xzh");fs
               [_Button("开复下模图", "FX.BMP", "FX.BMP")]^C^C(load "xzh");fx
               [_Button("单开组立图", "qc.BMP", "qc.BMP")]^C^C(load "xzh");qc
               [_Button("单开料带图", "qa.BMP", "qa.BMP")]^C^C(load "xzh");qa
               [_Button("单开产料图", "qq.BMP", "qq.BMP")]^C^C(load "xzh");qq
               [_Button("关闭标注层", "qm.BMP", "qm.BMP")]^C^C(load "xzh");qm
**TB_XZH_B
**单层
               [_Toolbar("单层", _Top, _Show, 2, 0, 1)]
               [_Button("上模座", "A.BMP", "A.BMP")]^C^C(load "xzh");A8
               [_Button("上垫板", "U.BMP", "U.BMP")]^C^C(load "xzh");U8
               [_Button("固定板", "H.BMP", "H.BMP")]^C^C(load "xzh");H8
               [_Button("止高板", "K.BMP", "K.BMP")]^C^C(load "xzh");K8
               [_Button("脱料板", "S.BMP", "S.BMP")]^C^C(load "xzh");S8
               [_Button("凹模板", "D.BMP", "D.BMP")]^C^C(load "xzh");D8
               [_Button("下垫板", "B.BMP", "B.BMP")]^C^C(load "xzh");B8
               [_Button("下模座", "L.BMP", "L.BMP")]^C^C(load "xzh");L8
               [_Button("冲头层", "P.BMP", "P.BMP")]^C^C(load "xzh");P8
               [_Button("入块层", "N.BMP", "N.BMP")]^C^C(load "xzh");N8
               [_Button("中空板", "t.BMP", "T.BMP")]^C^C(load "xzh");T8
               [_Button("内脱板", "Q.BMP", "Q.BMP")]^C^C(load "xzh");Q8
               [_Button("下脱板", "Z.BMP", "Z.BMP")]^C^C(load "xzh");Z8
               [_Button("下夹板", "w.BMP", "W.BMP")]^C^C(load "xzh");W8
**TB_XZH_LAYER
**图管
               [_Toolbar("图管", _Top, _Show, 1, 1, 1)]
               [_Button("图层管理器", "layer.BMP", "layer.BMP")]'_layer
               [_Control(_Layer)]
               [_Control(_Color)]
               [_Control(_Lineweight)]
               [_Control(_Linetype)]
//      AutoCAD 菜单文件结尾 - C:\xzh\xzh.mns
我是用menu命令加载的
   请问如何才能实现图三效果,请高手们指点,谢谢
发表于 2013-5-21 12:48:17 | 显示全部楼层
用MenuLoad命令!
发表于 2013-5-21 14:46:17 | 显示全部楼层
menu是替换,是图二的形式
按斑竹说的
 楼主| 发表于 2013-5-21 17:02:56 | 显示全部楼层
Gu_xl 发表于 2013-5-21 12:48
用MenuLoad命令!
用menuload命令加载
成了如下:
呵呵! 你多试几次看看能不能正常  发表于 2013-5-21 18:09
发表于 2013-5-21 18:43:52 | 显示全部楼层
?表示图标未找到,你只要指明图标的路径就能显示。
 楼主| 发表于 2013-5-22 08:22:47 | 显示全部楼层
位图路径已经在啊
请问这是为何呢?请指点
 楼主| 发表于 2013-5-22 08:45:30 | 显示全部楼层
位图标出来了,但是下拉菜单还没出来
请手指点
发表于 2013-5-22 09:01:53 | 显示全部楼层
手动的话,还是menuload,不过是其中的菜单栏项。
如果程序加载,则用menucmd函数。
发表于 2013-9-5 09:57:13 | 显示全部楼层
写到“acad.mns"里加载就可以啦!
GMT+8, 2025-5-20 10:41 , Processed in 0.205944 second(s), 30 queries , Gzip On.
