查看: 9267|回复: 14
[公告] 求修改某大师的改块名代码。。谢谢
发表于 2013-5-22 03:22:30 | 显示全部楼层 |阅读模式
3明经币
;;;修改块名
(defun c:XGGM (/ ent name name1 dclname tempname filen stream dcl_re dlg new)
  (if (and (setq ent (car (entsel "\n选择需要改名的块: "))) (or (eq "INSERT" (cdr (assoc 0 (entget ent)))) (alert "没有选择块!")))
      (setq name (cdr (assoc 2 (entget ent))))
(setq dclname
  (cond
      (setq tempname (vl-filename-mktemp "re-dcl-tmp.dcl") filen (open tempname "w"))
      (foreach stream '(
"\n"
"RENAME:dialog {\n"
"    label = \"修改块名\" ;\n"
"    :row {\n"
"        :edit_box {\n"
"            key = \"dcl_edit_name\" ;\n"
"            width = 30 ;\n"
"        }\n"
"    }\n"
"    :row {\n"
"        :button {\n"
"            key = \"btn_ok\" ;\n"
"            label = \"确认\" ;\n"
"        }\n"
"        :button {\n"
"            is_cancel = true ;\n"
"            key = \"btn_cancle\" ;\n"
"            label = \"取消\" ;\n"
"        }\n"
"    }\n"
"}\n"
      (princ stream filen)
      (close filen)
      tempname
      (setq dcl_re (load_dialog dclname))
      (if (not (new_dialog "RENAME" dcl_re)) (exit))
      (set_tile "dcl_edit_name" name)
      (mode_tile "dcl_edit_name" 2)
      (action_tile "dcl_edit_name" "(setq name1 $value)")
      (action_tile "btn_ok" "(if (tblsearch \"block\" name1)
                               (alert (strcat \"块名: \" name1 \" 已经存在.\"))
                               (if (not (snvalid name1))
                                 (alert (strcat \"错误的块名: \" name1))
                                 (done_dialog 1)
      (setq dlg (start_dialog))
      (if (= dlg 1)
          (command "_.rename" "_block" name name1)
          (princ (strcat "\n图块 \"" name "\" 重命名为 \"" name1 "\""))
      (unload_dialog dcl_re)
      (vl-file-delete dclname)
明经下载的忘了出自哪位大师之手了~
本功能在更改块名的时候,手动输入重命名的块名称。。
增加个功能直接图中选择单行文字作为重命名的块名。。。。免得手工再去输入。
谢谢哪位大师能出手帮忙谢谢~~
最佳答案
查看完整内容
改了一下,可以输入也可以选择。如果无选择那么要求输入块名称 (defun c:gkm (/ NAME NEW-NAME) (setq name (Vlax-Get (Vlax-Ename->Vla-Object (car (entsel "\n选择要改块名的块:")) ) 'Name ) ) (setq ss-text (entsel "\n选择新块名称文字:")) (if (= ss-text nil) (setq new-name (getstring "\输入新的块名:")) (setq new-name (Vlax-Get (Vlax-Ename->Vla-Object ...
发表于 2013-5-22 03:22:31 | 显示全部楼层
                       'Name
  (if (= ss-text nil)
                               (car ss-text)
                             'TextString
  (command "_.rename" "_block" name new-name)
flytoday + 1 很给力!
发表于 2013-5-22 08:06:35 | 显示全部楼层
看到了给你一个简单的。
  (setq name (Vlax-Get (Vlax-Ename->Vla-Object (car (entsel))) 'Name))
                             (car (entsel "选择新块名称文字:"))
                           'TextString
发表于 2013-5-22 08:15:52 | 显示全部楼层
加一个已存在提示,重复后停止执行。
                       'Name
  (if (= ss-text nil)
                               (car ss-text)
                             'TextString
  (if (tblsearch "block" new-name)
    (princ (strcat "\n新块名" new-name "已经存在请重试!"))
发表于 2013-5-22 10:05:31 | 显示全部楼层
我也发一个以前搜集的,不知道能不能帮到你
发表于 2013-5-22 10:09:39 | 显示全部楼层
;;;;;改块名程序
(defun C:km (/ *APP *DOC EntNam NewNam)
    (vl-load-com)
    (setq *APP (vlax-get-acad-object))
    (setq *DOC (vla-get-activeDocument *APP))
    (if (setq EntNam (car (entsel "\n请选择块: ")))
      (if (setq NewNam (getstring "\n请输入新块名<字符规范,不要重名>: "))
        (change-block-name EntNam NewNam)
        (princ "\n你没有输入新块名!")
      (princ "\n你没有选择物体!")
;;;改块名程序
(defun change-block-name (EntNam NewNam / obj blocks BlkNam block)
    (setq obj (vlax-ename->vla-object EntNam))
    (setq blocks (vla-get-blocks *DOC))
    (if (=(vla-get-objectname obj) "AcDbBlockReference")
      (if (tblsearch "block" NewNam)
        (princ "\n和已有块名重复!")
          (setq BlkNam (vla-get-name obj))
          (setq block  (vla-item blocks BlkNam))
          (vla-put-name block NewNam)
          (if (= (substr BlkNam 1 2) "*U")
              (princ "\n这是一个匿名块.")
              (vla-auditinfo *Doc :vlax-true)
          (princ "\n块名已经更改成\"")
          (princ NewNam)
          (princ "\"")
      (princ "\n所选物体不是块!")
flytoday + 1 谢谢~~
 楼主| 发表于 2013-5-22 12:47:44 | 显示全部楼层
最好提示能显示原来的块名~~~~~~~~~~~~~~~~~~~
发表于 2013-5-22 13:10:08 | 显示全部楼层
原块名在“[  ]”中显示
                       'Name
  (setq ss-text (entsel (strcat "\n选择新块名称文字[" name "]:")))
  (if (= ss-text nil)
    (setq new-name (getstring (strcat "\输入新的块名[" name "]:")))
                               (car ss-text)
                             'TextString
请问为为什么我的提示 命令: ; 错误: 读入的 (八进制) 字符不正确: 0  发表于 2013-9-5 11:26
求改单一块名的办法  发表于 2013-5-22 21:58
大师重出江湖。所向无敌。。。谢谢~~  发表于 2013-5-22 14:17
发表于 2013-6-25 17:11:35 | 显示全部楼层
路过,学习一下
发表于 2013-6-28 19:58:30 | 显示全部楼层
楼主能不能只改图中同名的部分图块的图名,其余的相同的图块名字不变?
GMT+8, 2025-5-1 10:57 , Processed in 0.296737 second(s), 31 queries , Gzip On.
