查看: 2159|回复: 1
[提问] 修改机械版CAD过程中如何快速修改焊接符号和粗糙度
发表于 2013-5-22 11:21:22 | 显示全部楼层 |阅读模式
现使用软件Mechnical cad 2007
在实际的设计过程中经常会遇到类似情况
一些图画好了,包括标注,粗糙度,焊接符号都完成之后
又要对该图的比例作调整,
标注是没什么问题,修改一下标注样式就可以了
可其它的一些内容,如粗糙度,焊接符号,还有说明文字就不太好办了
要一个一个的挪开,待图的比例调整好之后再逐一挪回来
这样做相当麻烦
广大设计者们的效率将会迈上一个台阶
下面有段快速修改尺寸标注和文字修改,期待高手能否把粗糙度和焊接符号添进去!!!!!!!!!!!
(defun ax:getboundingbox (entname / entpl entpr ptlist)
       (vla-getboundingbox (vlax-ename->vla-object entname) 'entpl 'entpr)
       (setq ptlist (mapcar 'vlax-safearray->list (list entpl entpr)))
       (mapcar '(lambda (x) (trans x 0 1)) ptlist)
);end defun
(defun getentdxf (ent dxf)
       (cond
              ((= (type ent) 'ename)
                     (cdr (assoc dxf (entget ent '( "*" ))))
              );end "("
              ((= (type ent) 'vla-object)
                     (cdr (assoc dxf (entget (vlax-vla-object->ename ent) '( "*" ))))
              );end "("
       );end cond
);end defun
(setq *en2obj* vlax-ename->vla-object)
(defun c:ds (/ entdata entgrp entname n ptlist scale)
       (prompt "根据图框比例自动改变图框内所有标注全局比例" )
       (if (setq entname (entsel "\n请选择图框" ))
              (if (= "INSERT" (getentdxf (car entname) 0))
                            (command "zoom" "o" (car entname) "" )
                              (setq ptlist (ax:getboundingbox (car entname)))
                              (setq entgrp (ssget "W" (car ptlist) (cadr ptlist) '((0 . "DIMENSION,*TEXT,*LINE,HATCH" ))))
                              (setq scale (vla-get-XScaleFactor (*en2obj* (car entname))))
                              (repeat (setq n (sslength entgrp))
                                     (setq entname (ssname entgrp (setq n (1- n))))
                                     (cond
                                              ((= "DIMENSION" (getentdxf entname 0))
                                                   (vla-put-ScaleFactor (*en2obj* entname) scale)
                                           );end "("
                                            ((wcmatch (getentdxf entname 0) "*TEXT" )
                                                   (vla-put-Height (*en2obj* entname) (* (getvar "textsize" ) scale))
                                           );end "("
                                     );end cond
                             );end repeat
                     );end progn
              );end if
       );end if
);end defun
);end defun
 楼主| 发表于 2013-5-23 10:02:49 | 显示全部楼层
看来还是没有找到突破点啊
GMT+8, 2025-5-22 22:22 , Processed in 0.220277 second(s), 29 queries , Gzip On.
