高手帮帮我,现有一段Lisp代码,功能是按颜色移动对象。我想改为按颜色选择对象,且可以框选。 - ;;http://bbs.mjtd.com/thread-61591-1-1.html
- ;;如果是随块,则是按7号色选择对象
- (defun c:x1 (/ *laysel* cor en lay-lst lay-str obj pt ss)
- (setq *laysel* (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
- (if (and (setq en (car (entsel "\n选择目标对象:")))
- (setq obj (vlax-ename->vla-object en))
- (setq cor (vla-get-color obj))
- (setq pt (getpoint "\n基点:"))
- (progn
- ;; 分辨颜色
- (cond ((= cor 256) ;_ 随层
- (setq cor (vla-get-color (vla-item *laysel* (vla-get-layer obj))))
- ((= cor 0) ;_ 随块
- (setq cor 7)
- ;; 筛选图层
- (vlax-for lay *laysel*
- (if (= (vla-get-color lay) cor)
- (setq lay-lst (cons (vla-get-name lay) lay-lst))
- (if lay-lst
- (foreach lay lay-lst
- (if lay-str
- (setq lay-str (strcat lay-str "," lay))
- (setq lay-str lay)
- ;; 形成选择集
- (if lay-str
- (setq ss (ssget "x" (list '(-4 . "<OR") (cons 0 lay-str) (cons 62 cor) '(-4 . "OR>"))))
- (setq ss (ssget "x" (list (cons 62 cor))))
- (vl-cmdf "move" ss "" pt)
- (vl-cmdf pause)
