试试 - (defun c:ttt (/ a p1 p2 ang pt pta ptt r)
- (setvar "cmdecho" 0)
- (setvar "osmode" 1023)
- (princ "画长圆孔")
- (if (= ctk_d nil) (setq ctk_d 13))
- (princ (strcat "\n请设定长圆孔直径 <" (rtos ctk_d 2 3) ">: "))
- (setq a (getdist))
- (if (= a nil) (setq a ctk_d))
- (setq ctk_d a)
- (setq r (/ ctk_d 2))
- (while (and
- (setq pt (getpoint "\n指定插入点:"))
- (setq pta (getpoint pt "\n指定另一点:"))
- );and
- (setq ang (angle pt pta)
- di (distance pt pta)
- ptb (polar pt ang r)
- pt1 (polar ptb (+ ang (/ pi 2)) r)
- pt2 (polar pt1 ang (- di (* r 2)))
- pt3 (polar ptb (+ ang (/ pi -2)) r)
- pt4 (polar pt3 ang (- di (* r 2)))
- ptt(mapcar '(lambda(x)(/ x 2))(mapcar '+ pt pta))
- );set
- (command "_.PLINE" "non" pt1 "non" pt2 "A" "non" pt4 "L" "non" pt3 "A" "CL")
- (command "line" (polar pt (+ ang pi) 50) (polar pta ang 50) "")
- (command "change" (entlast) "" "p" "c" 1 "")
- (command "line" (polar ptt (+ ang (/ pi 2)) (+ r 50)) (polar ptt (- ang (/ pi 2)) (+ r 50)) "")
- (command "redrawall")
- (princ "\n**继续输入**")
- );while
- (princ)
- );defun
