查看: 1479|回复: 4
[LISP群(2)] 2013-06-02 明经 AutoLISP 编程②群(177027547) 群聊记录:如何对三维点选择集按照X或Y排序
 关闭 [复制链接]
发表于 2013-6-2 00:23:53 | 显示全部楼层 |阅读模式
等你 00:23:53
如何对三维点选择集按照X或Y排序
 楼主| 发表于 2013-6-2 08:52:03 | 显示全部楼层
[kkppp123]小唐 08:52:03
请问打开了vlisp编辑器,用程序怎么关闭它呢
 楼主| 发表于 2013-6-2 10:09:04 | 显示全部楼层
等你 10:09:04
(defun sort-pt-1 (plts fun n)
  (vl-sort plts
       '(lambda (a b)
          (fun (nth n a) (nth n b))
(defun sort-pt (plst xyz / fun)
  (setq xyz (vl-string->list xyz))
  (foreach n-xyz (reverse xyz)
    (if    (< n-xyz 100)
      (setq fun      >
        n-xyz (- n-xyz 88)
        plst  (sort-pt-1 plst fun n-xyz)
      (setq fun      <
        n-xyz (- n-xyz 120)
(defun C:hdm (/ S1 S2 I)
  (setq en (entsel "选择一条直线:"))
                    ;(setq size 0.1)
  (SETQ S1 (ssget '((0 . "OINT"))))
  (SETQ n 0)
  (repeat (sslength s1)
    (setq lst (cons (ssname s1 n) lst)
      n   (1+ n)
  (setq
    x (mapcar '(lambda (x) (car (cdr (assoc 10 (entget x))))) lst)
  (setq
    y (mapcar '(lambda (x) (cadr (cdr (assoc 10 (entget x)))))
          lst
  (setq    maxx (eval (cons 'max x))
    minx (eval (cons 'min x))
  (setq    maxy (eval (cons 'max y))
    miny (eval (cons 'min y))
  (setq    dx (- maxx minx)
    dy (- maxy miny)
  (if (> dx dy)
    ;;x坐标排序:
    (setq S2 (sort-pt-1 s1 "x"))
    ;;y坐标排序:
    (setq S2 (sort-pt-1 s1 "y"))
    (setq I 0)
    (repeat (sslength S2)
      (setq pen_data (entget (ssname s2 i)))
      (setq ppt (assoc 10 pen_data))
      (setq pp (cdr ppt))
      (setq erpt (vlax-curve-getClosestPointTo (car en) pp T))
                    ;找出垂点
      (entmake (APPEND '((0 . "LINE")
             (100 . "AcDbEntity")
             (100 . "AcDbLine")
             (8 . "0")
               (LIST (CONS 10 pp) (CONS 11 perpt))
      (princ "\n")
      (princ (cdddr (assoc 10 (entget (ssname S2 I)))))
                    ;显示排序结果。
      (setq I (1+ I))
 楼主| 发表于 2013-6-2 17:37:02 | 显示全部楼层
[ZZXXQQ] 17:37:02
sort-pt-1函数要求三个参数,你只给了两个。
GMT+8, 2025-7-2 04:33 , Processed in 0.192703 second(s), 26 queries , Gzip On.
