查看: 4882|回复: 10
[已解答] 求助:自动加载pat填充文件(已经解决)。
发表于 2013-6-9 11:12:19 | 显示全部楼层 |阅读模式
用lisp编写的pat填充文件,定义完成后如何让cad自动加载pat文件并应用pat文件定义的填充图案?
 楼主| 发表于 2013-6-10 20:19:38 | 显示全部楼层
(defun c:tt (/      X      Y      _A      PATNAME INDEX   PATH
      DIMZIN      OX      OY      F      FILENAME
      STR     cmdecho *error*
  (defun *error* (s)
    (setvar 'dimzin dimzin)
    (setvar 'cmdecho cmdecho)
    (pronc s)
  (setq x (getreal "\nX间距:<10.0>"))
  (if (null x)
    (setq x 10)
  (setq y (getreal "\nY间距:<10.0>"))
  (if (null y)
    (setq y 10)
  (setq _a (getangle "\n旋转角度<0>:"))
  (if (null _a)
    (setq _a "0")
    (setq _a (angtos _a))
  (setq patname "TEMPPA_"
index 0
  (while
    (ssget "x"
    (list '(0 . "hatch") (cons 2 (strcat patname (itoa index))))
     (setq index (1+ index))
  (setq patname (strcat patname (itoa index)))
  (setq path (GETVAR (QUOTE ROAMABLEROOTPREFIX))
dimzin (getvar (quote dimzin))
cmdecho (getvar 'cmdecho)
  (setvar 'dimzin 8)
  (setvar 'cmdecho 0)
  (or (eq "\\" (substr path (strlen path)))
      (setq path (strcat path "\\"))
  (setq path (strcat path "Support\\"))
  (setq f (open (setq filename (strcat path patname ".pat")) "w"))
  (write-line
    (setq str (strcat "*" patname ",临时填充图案 " patname))
    f
  (write-line (strcat "0,0,0,0," (rtos x 2 10)) f)
  (write-line (strcat "90,0,0,0," (rtos y 2 10)) f)
  (close f)
  (setq endent (entlast))
  (if (>= (atoi (getvar 'acadver)) 17)
      (command "_Bhatch" "p" patname "1" _a "o" "d" "l" "n")
      (princ "\n**选择区域点**")
      (while (= 1 (getvar 'cmdactive))
(command pause)
      (command "_Bhatch" "p" patname "1" _a)
(command pause)
  (setq hatch (entlast))
  (if (not (equal endent hatch))
    (command "_explode" hatch)
  (vl-file-delete filename)
 楼主| 发表于 2013-6-10 20:21:02 | 显示全部楼层
以上程序由Gu_xl 编写。由于本程序在某个帖子里埋的太深,转至此,请Gu_xl 谅解。
发表于 2013-7-10 23:24:40 | 显示全部楼层
关键是有源代码,谢谢楼主分享
发表于 2014-6-16 20:16:48 | 显示全部楼层
感谢感谢
发表于 2016-4-13 20:45:37 | 显示全部楼层
感谢感谢
发表于 2018-10-23 21:41:31 | 显示全部楼层
感謝樓主分享
发表于 2019-4-28 01:21:16 | 显示全部楼层
G版是伟大的,是无私的
发表于 2019-4-28 08:53:10 | 显示全部楼层
G版是伟大的,是无私的
GMT+8, 2025-5-16 11:49 , Processed in 0.187653 second(s), 25 queries , Gzip On.
