- 积分
- 7156
- 明经币
- 个
- 注册时间
- 2010-11-21
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2013-6-13 11:06:48
显示全部楼层
;批量连线(相连的线成一条)
(defun c:jj()
(setq cm (getvar "cmdecho"))
(setvar "cmdecho" 0)
(setvar "peditaccept" 1) ;加入这个系统变量的代码
(if (setq KX (ssget '((0 . "LINE,ARC,LWPOLYLINE,POLYLINE"))))
(command "_pedit" "m" KX "" "j" "0.1" ""))
(setvar "cmdecho" cm)
(princ))
;直线line → 多段线xline(多选)(idljb)
;(defun c:(/ ss alts pt gr s1 lt newscale)
;(setq ss (ssget '((8 . "~3中心线")))
;alts (getvar "LTSCALE") pt (getpoint "\n请指定一个点: "))
;(while (= (car (setq gr (grread nil 5 0))) 5)
;(redraw)(grdraw (cadr gr) pt 1 1)(setq i -1)
;(while (setq s1 (ssname ss (setq i (1+ i))))
;(if (setq lt (cdr (assoc 6 (entget s1))))(progn
;(setq zq (cdr (assoc 40 (tblsearch "ltype" lt))))
;(if (/= zq 0)
;(setq newscale (/ (distance (cadr gr) pt) zq alts 1.))
;(setq newscale 1)))
;(progn (setq zq (cdr (assoc 40 (tblsearch "ltype"
;(cdr (assoc 6
;(tblsearch "layer" (cdr (assoc 8 (entget s1))))))))))
;(if (/= zq 0)(setq newscale (/ (distance (cadr gr) pt) zq alts 1.))
;(setq newscale 1))))
;(vla-put-LinetypeScale (vlax-ename->vla-object s1) newscale)))
;(redraw)
;(command "pedit" "m" ss "" "j" "0.1" "" "")
;(princ))
;连线pedit(yoyoho 2011-1-15 21:55:35)
;(defun c:(/ kst sset i pp d1 yn f1)
;(setvar "cmdecho" 0)
;(princ "\n请选择要连接的直线,多义线,圆弧:")
;(setq sset (ssget '((-4 . "<OR") (0 . "LWPOLYLINE")(0 . "LINE")(0 . "ARC") (-4 . "OR>"))) i 1 entt (ssname sset 0))
;(while (< i (sslength sset))(if (entget (setq ent (ssname sset i)))
;(if (= (cdr (assoc 0 (entget ent))) "LWPOLYLINE") (vl-cmdf "_PEDIT" entt "J" ent "" "") (vl-cmdf "_PEDIT" entt "J" sset "" "")))
;(setq i (1+ i)))
;(princ))
;(defun fsxm-silenceexit (/ *error*) ;无声退出 ;by fsxm
;(t (setq *error* strcat)))
;(defun c:(/ ss *error*) ;连接多义线
;(defun *error* (msg) (princ))
;(princ "\n连接多义线")
;(setq ss (ssget '((8 . "~3中心线")(8 . "~0")(-4 . "<or")
;(-4 . "<AND") (0 . "LWPOLYLINE") (70 . 0) (-4 . "AND>")
;(0 . "LINE")
;(0 . "ARC")
;(-4 . "or>"))))
;(or ss (fsxm-silenceexit))
;(setvar "PEDITACCEPT" 1)
;(if (= (sslength ss) 1)
;(vl-cmdf "PEDIT" (ssname ss 0) "j" "all" "" "")
;(command "PEDIT" "m" "P" "" "j" "0.1" "" ""))
;(setvar "PEDITACCEPT" 0)
;(princ))
;(princ "\n连接多义线")
;(setq ss (ssget '((8 . "~3中心线")(-4 . "<or")
;(0 . "LINE")
;(0 . "ARC")
;(-4 . "or>"))))
;(princ)) |
