查看: 1073|回复: 1
[VBA群] 2013-06-15 明经AutoCAD.VBA编程(45054712) 群聊记录:API的右键菜单回调函数,老出错,帮忙看一下,函数如下: Public Fu
 关闭 [复制链接]
发表于 2013-6-15 12:16:10 | 显示全部楼层 |阅读模式
罗哲兴 12:16:10
Public Function AddCallBack(ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Long, ByVal lParam As Long) As Long
    Select Case wMsg
        Case WM_COMMAND '消息
            Select Case wParam
                Case WM_USER + IDM_CUT
                   Call cmd剪切
                Case WM_USER + IDM_CREAT
                   Call Cmd添加
                Case WM_USER + IDM_PASTE
                  Call cmd粘贴
            End Select
    End Select
    AddCallBack = CallWindowProc(OldProc, hwnd, wMsg, wParam, lParam)
End Function
GMT+8, 2025-7-22 19:53 , Processed in 0.165823 second(s), 26 queries , Gzip On.
