- 积分
- 52288
- 明经币
- 个
- 注册时间
- 2006-5-28
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2013-6-25 08:13:41
显示全部楼层
;;; jdx2 画截断双线
(defun C:jdx2 (/ lay pt1 pt2 dis x1 pt3 pt4 pt5 pt6 ss ptt scale)
(command "osnap" "endp,mid,int,cen") ;;;设定抓端点,中点,交点,圆中心
(setvar "CMDECHO" 0)
(setq lay (getvar "clayer"))
(command "color" "bylayer")
(command "layer" "m" "jdx" "c" "m" "jdx" "")
(setq scale (getreal "\nScale<300>:"))
(if (= scale nil)
(setq scale 300)
(setq pt1 (getpoint "\nFirst point:"))
(setq pt2 (getpoint pt1 "\nSecond point:"))
(setq ang (angle pt1 pt2))
(setq dis (distance pt1 pt2))
(setq x1 (/ (- dis (* 2 scale)) 2))
(setq pt3 (polar pt1 ang x1))
(setq pt4 (polar pt1 ang (+ x1 (* 2 scale))))
(setq pt5 (polar pt3 (+ ang 1.32582) (* 2.0616 scale)))
(setq pt6 (polar pt4 (- ang 1.81577) (* 2.0616 scale)))
(setq ptt (polar pt1 (- ang (/ pi 2)) (* 1 scale)))
(setq osd (getvar "osmode"))
(setvar "osmode" 0 )
(command "pline" pt1 "w" "0" "0" pt3 pt5 pt6 pt4 pt2 "")
(setq ss (entlast))
(command "copy" ss "" pt1 ptt)
(command "layer" "s" lay "")
(setvar "osmode" osd)
