查看: 2342|回复: 3
如何将textbox中的文本按行写出到一个文本文件中?
发表于 2003-9-9 13:58:00 | 显示全部楼层 |阅读模式
发表于 2003-9-9 18:14:00 | 显示全部楼层
打开文本文件,VB好像有
writeline,命令,试试。
发表于 2003-9-9 22:13:00 | 显示全部楼层
给你两个函数,一个写入,一个读出,一次完成:
  1. '将文本文件读到字符串中
  2. Function ReadFromFile(FileName As String) As String
  3.     Dim objFSO
  4.     Dim fdata
  5.     Dim objCountFile
  6.     Err.Clear
  7.     On Error Resume Next
  8.     Set objFSO = Server.CreateObject("Scripting.FileSystemObject")
  9.     Set objCountFile = objFSO.OpenTextFile(FileName, 1, True)
  10.     If Not objCountFile.AtEndOfStream Then fdata = objCountFile.ReadAll
  11.     objCountFile.Close
  12.     Set objCountFile = Nothing
  13.     Set objFSO = Nothing
  14.     If Err.Number <> 0 Then
  15.         ReadText = fdata
  16.     Else
  17.         ReadText = fdata
  18.     End If
  19. End Function
  20. '将字符串写入到文本文件中
  21. Function WriteToFile(FileName As String, fdata As String) As Boolean
  22.     Dim objFSO
  23.     Dim objCountFile
  24.     Err.Clear
  25.     On Error Resume Next
  26.     Set objFSO = Server.CreateObject("Scripting.FileSystemObject")
  27.     Set objCountFile = objFSO.CreateTextFile(FileName, True)
  28.     objCountFile.Write fdata
  29.     objCountFile.Close
  30.     Set objCountFile = Nothing
  31.     Set objFSO = Nothing
  32.     If Err.Number <> 0 Then
  33.         WriteText = False
  34.     Else
  35.         WriteText = True
  36.     End If
  37. End Function
 楼主| 发表于 2003-9-10 12:05:00 | 显示全部楼层
让我说声谢谢你!
GMT+8, 2025-5-24 15:10 , Processed in 0.163008 second(s), 23 queries , Gzip On.
