查看: 1239|回复: 7
[LISP群(2)] 2013-06-25 明经 AutoLISP 编程②群(177027547) 群聊记录:充值 f97b82f9-a3d2-4a52-8f37-531d5666e
 关闭 [复制链接]
发表于 2013-6-25 11:31:37 | 显示全部楼层 |阅读模式
[mccad][mccad] 11:31:37
充值 f97b82f9-a3d2-4a52-8f37-531d5666e1cf
 楼主| 发表于 2013-6-25 11:47:08 | 显示全部楼层
等你 11:47:08
(setq en (car (entsel "选择直线L:")))
      (setq dis2line (getreal "\n输入点范围:"))
      (if (and en dis2line)
      (setq pt1 (cdr (assoc 10 (entget en))))
      (setq pt2 (cdr (assoc 11 (entget en))))
      ;;(princ (angle pt1 pt2))
      (setq
        ranlst (list
             (polar pt1 (- (angle pt1 pt2) (/ I 2)) dis2line)
             (polar pt1 (+ (angle pt1 pt2) (/ I 2)) dis2line)
             (polar pt2 (- (angle pt2 pt1) (/ I 2)) dis2line)
             (polar pt2 (+ (angle pt2 pt1) (/ I 2)) dis2line)
      (setq s1 (ssget "wP" ranlst '((0 . "point"))))
      ;;(setq s1 (ssget "CP" ranlst '((0 . "INSERT") (8 . "GCD"))))
  (SETQ n 0)
  (setq size 0.1)
;;;-------------------分配点表 --------
  (repeat (sslength s1)
    (setq lst (cons (ssname s1 n) lst)
      n   (1+ n)
;;;---进行XY值比较计算后对列表排序----------------
  (setq
    x (mapcar '(lambda (x) (car (cdr (assoc 10 (entget x))))) lst)
  (setq
    y (mapcar '(lambda (x) (cadr (cdr (assoc 10 (entget x)))))
          lst
  (setq    maxx (eval (cons 'max x))
    minx (eval (cons 'min x))
  (setq    maxy (eval (cons 'max y))
    miny (eval (cons 'min y))
  (setq    dx (- maxx minx)
    dy (- maxy miny)
  (princ dy)
  (if (> dx dy)
    ;;x坐标排序:
    (setq S2 (SORT-SE S1 10 0 (* 0.1 SIZE) nil))
    ;;y坐标排序:
    (setq S2 (SORT-SE S1 10 1 (* 0.1 SIZE) t))
;;;-----------投影各点到断面线上-------------
    (setq I 0)
    (repeat (sslength S2)
      (setq pen_data (entget (ssname s2 i)))
      (setq ppt (assoc 10 pen_data))
      (setq pp (cdr ppt))
      (setq erpt (vlax-curve-getClosestPointTo (car en) pp T))
      ;;找出垂点
      (entmake (APPEND '((0 . "LINE")
             (100 . "AcDbEntity")
             (100 . "AcDbLine")
             (8 . "0")
             (62 . 2)
               (LIST (CONS 10 pp) (CONS 11 perpt))
      (princ "\n")
      (princ (cadddr (assoc 10 (entget (ssname S2 I)))))
      ;;显示排序结果。
为何提示参数错误
 楼主| 发表于 2013-6-25 12:05:36 | 显示全部楼层
[yxh1202]等你 12:05:36
88
 楼主| 发表于 2013-6-25 13:00:55 | 显示全部楼层
[机械工程师]陈 13:00:55
这个充值是什么
 楼主| 发表于 2013-6-25 13:29:49 | 显示全部楼层
[pzweng][pzweng]天蝎 13:29:49
充值 f97b82f9-a3d2-4a52-8f37-531d5666e1cd
 楼主| 发表于 2013-6-25 13:54:27 | 显示全部楼层
[天津]-地形-fly 13:54:27
[qqimg]oldimg/{8EA379BA-6442-4713-41AD-8D293C10756E}.jpg[/qqimg]
线形删不掉
咋办
[yxh1202]等你 14:00:41
什么意思
改备注名吗
不好意思
 楼主| 发表于 2013-6-25 22:05:09 | 显示全部楼层
[kkppp123]小唐 22:05:09
请问电脑所有的文件夹属性变成只读,手动却改不回来,是怎么回事?
[ZZXXQQ] 22:05:43
权限不够
[kkppp123]小唐 22:07:29
权限不够?是家用电脑,怎么会是权限不够呢
[vormittag]桔子 22:08:18
[kkppp123]小唐 22:08:58
重装系统也不行
[ZZXXQQ] 22:10:23
砸了它
再买新的
[kkppp123]小唐 22:11:03
[alwtyp][alwtyp] 22:11:10
周老师也会讲冷笑话?
[ZZXXQQ] 22:12:01
要不对硬盘进行低格,然后再装系统。
[kkppp123]小唐 22:13:07
有好一点的办法吗
[mccad][mccad] 22:14:57
只是只读,那就把文件拷贝出来,普通格式化应该可以
[vormittag]桔子 22:16:48
用户权限是 system > trustedinstaller >adiministrator
并不会因为你用的是家用电脑就有windows的最高权限。
[kkppp123]小唐 22:19:21
我的用户就是adiministrator
[vormittag]桔子 22:19:54
administrator 不是最高权限。
[kkppp123]小唐 22:20:44
普通格式化还是不行,我试过将一个D盘格式化后,新建的文件夹还是只读
[434939575]模型 22:24:28
请教:LISP空表的用途是?对这个不理解?
[ZZXXQQ] 22:25:15
为向表内放数据做准备
[434939575]模型 22:28:51
意思就是后面的表内容可以放到空表里面去。
[434939575]模型 22:29:58
谢谢指导
GMT+8, 2025-4-29 00:38 , Processed in 0.239576 second(s), 26 queries , Gzip On.
