查看: 3787|回复: 11
[已解答] 两条线之间画等分线的代码需修正
发表于 2013-6-25 15:31:43 | 显示全部楼层 |阅读模式
这是在两条线之间画等分线的代码。我在使用时发现,它时而有效,时而得到混乱的结果,有请大师找出原因并改正
发表于 2018-9-29 09:15:51 | 显示全部楼层
;;两曲线等分
(defun c:tt (/ dis L1 L2 P1 P2 A1 D1 P3 P4 A2 D2 PL1 PL2 PTS)
        (princ "\n两曲线等分:")
  (while (and
                                         (setq l1 (car (entsel "\r选择曲线1:")))
                                         (setq l2 (car (entsel "\r选择曲线2:")))
                                         (setq dis (getint "\r请输入等分份数(≥1):"))
    (setq
                        p1  (vlax-curve-getStartPoint l1)
                        p2  (vlax-curve-getEndPoint l1)
                        d1 (* (/ 1.0 dis) (vlax-curve-getDistAtParam l1 (vlax-curve-getEndParam l1)))
                        p3  (vlax-curve-getStartPoint l2)
                        p4  (vlax-curve-getEndPoint l2)
                        d2 (* (/ 1.0 dis)  (vlax-curve-getDistAtParam l2 (vlax-curve-getEndParam l2)))
                        pl1 (list p1)
                        pl2 (list p3)
                        i 0
    (repeat dis
      (setq i (1+ i)
                                pl1 (cons (vlax-curve-getpointatdist l1 (* d1 i)) pl1)
                                pl2 (cons (vlax-curve-getpointatdist l2 (* d2 i)) pl2)
    (setq pl1 (cons p2 pl1)
                        pl2 (cons p4 pl2)
    (if (inters (car pl1) (car pl2) (last pl1) (last pl2))
      (setq pl2 (reverse pl2))
    (setq pts (mapcar 'list pl1 pl2))
    (mapcar
      '(lambda (x)
         (entmake
           (list '(0 . "line") (cons 10 (car x)) (cons 11 (cadr x)))
      pts
发表于 2018-9-28 16:44:04 | 显示全部楼层
bai2000 发表于 2014-12-16 21:28
怎么改改,可以输入等分的个数?
要是能实现这个功能,那就太完美了
发表于 2013-6-25 17:22:31 | 显示全部楼层
...(command "line"...
得考量 补捉效应...
 楼主| 发表于 2013-6-25 19:10:20 | 显示全部楼层
有可能是啊!但短期无法证明,只有等用多了看是不是会出问题。等于这个代码使用时我要设为不捕捉
发表于 2013-6-26 07:52:46 | 显示全部楼层
确实有问题
发表于 2013-6-26 08:57:54 | 显示全部楼层
以下代码不用考虑捕捉和ucs
  1. (defun c:tt (/ L1 L2 P1 P2 A1 D1 P3 P4 A2 D2 PL1 PL2 PTS)
  2.   (while(and
  3.           (setq l1 (car(entsel "\n选择直线1:")))
  4.           (= "LINE" (cdr (assoc 0 (setq l1 (entget l1)))))
  5.           (setq l2 (car(entsel "\n选择直线2:")))
  6.           (= "LINE" (cdr (assoc 0 (setq l2 (entget l2)))))
  7.           )
  8.     (setq p1 (cdr (assoc 10 l1))
  9.           p2 (cdr (assoc 11 l1))
  10.           a1 (angle p1 p2)
  11.           d1 (* 0.1 (distance p1 p2))
  12.           p3 (cdr (assoc 10 l2))
  13.           p4 (cdr (assoc 11 l2))
  14.           a2 (angle p3 p4)
  15.           d2 (* 0.1 (distance p3 p4))
  16.           pl1 (list p1)
  17.           pl2 (list p3)
  18.           )
  19.     (repeat 9
  20.       (setq pl1 (cons (setq p1 (polar p1 a1 d1)) pl1)
  21.             pl2 (cons (setq p3 (polar p3 a2 d2)) pl2)
  22.             )
  23.       )
  24.     (setq pl1 (cons p2 pl1)
  25.           pl2 (cons p4 pl2)
  26.           )
  27.     (if (inters (car pl1) (car pl2) (last pl1) (last pl2))
  28.       (setq pl2 (reverse pl2))
  29.       )
  30.     (setq pts (mapcar 'list pl1 pl2))
  31.     (mapcar
  32.       '(lambda (x)
  33.          (entmake
  34.            (list
  35.              '(0 . "line")
  36.              (cons 10 (car x))
  37.              (cons 11 (cadr x))
  38.              )
  39.            )
  40.          )
  41.       pts
  42.       )
  43.     )
  44. (princ)
  45.   )
 楼主| 发表于 2013-6-26 09:55:20 | 显示全部楼层
5楼的与原意不符。原意是针对任意两条线(LINE\SPLIN\多义线等),算出二者N的等分点,再将这些等分点相连(最好用两种可能都提供,一种是顺向相连,一种是反向相连)。
5楼的只对直线有效,适用 范围窄了。
谢谢5楼的回复!
 楼主| 发表于 2013-6-26 10:53:33 | 显示全部楼层
不知道是不是我只要设定不捕捉,即加上如下代码,就可以改正它的BUG
“; 关闭捕捉的代码,不关闭捕捉本插件会出错.如果再有错误,则很可能是因为没有设定为世界坐标系
   (setvar "osmode" 0)”
我加了之后还没有出现过问题
发表于 2013-6-26 12:15:32 | 显示全部楼层
清风明月名字 发表于 2013-6-26 09:55
5楼的与原意不符。原意是针对任意两条线(LINE\SPLIN\多义线等),算出二者N的等分点,再将这些等分点相连( ...
是你自己描述题意不准确!以下代码适用任意曲线!
请准确的描述一下何谓顺向相连,反向相连?是连线要交叉吗?如要交叉相连,只需将下面的代码pl2表reverse一下即可!
  2.   (while (and (setq l1 (car (entsel "\n选择曲线1:")))
  3.               (setq l2 (car (entsel "\n选择曲线2:")))
  4.               )
  5.     (setq p1  (vlax-curve-getStartPoint l1)
  6.           p2  (vlax-curve-getEndPoint l1)
  7.           d1 (* 0.1 (vlax-curve-getDistAtParam l1 (vlax-curve-getEndParam l1)))
  8.           p3  (vlax-curve-getStartPoint l2)
  9.           p4  (vlax-curve-getEndPoint l2)
  10.           d2 (* 0.1 (vlax-curve-getDistAtParam l2 (vlax-curve-getEndParam l2)))
  11.           pl1 (list p1)
  12.           pl2 (list p3)
  13.           i 0
  14.           )
  15.     (repeat 9
  16.       (setq i (1+ i)
  17.             pl1 (cons (vlax-curve-getpointatdist l1 (* d1 i)) pl1)
  18.             pl2 (cons (vlax-curve-getpointatdist l2 (* d2 i)) pl2)
  19.             )
  20.       )
  21.     (setq pl1 (cons p2 pl1)
  22.           pl2 (cons p4 pl2)
  23.           )
  24.     (if (inters (car pl1) (car pl2) (last pl1) (last pl2))
  25.       (setq pl2 (reverse pl2))
  26.       )
  27.     (setq pts (mapcar 'list pl1 pl2))
  28.     (mapcar
  29.       '(lambda (x)
  30.          (entmake
  31.            (list '(0 . "line") (cons 10 (car x)) (cons 11 (cadr x)))
  32.            )
  33.          )
  34.       pts
  35.       )
  36.     )
  37.   (princ)
  38.   )
发表于 2013-6-26 15:19:27 | 显示全部楼层
G版写的完美。支持一下!
楼主的那个码我记得之前看过,记得有讨论在连线前指定每根线的起点,这样连起来的线就是按你指定的起点连了,所以你想顺连还是反向连就按你指定的起点,不过就是操作上多了要多点几下。
建议直接用G版的,如需反连,G版说代码pl2表reverse,加一下判断是反连或顺连就可以,如:输入F就反连,默认顺连.
发表于 2014-12-16 21:28:43 | 显示全部楼层
怎么改改,可以输入等分的个数?
GMT+8, 2025-5-19 05:05 , Processed in 0.200587 second(s), 28 queries , Gzip On.
