查看: 1806|回复: 1
[已解答] 如何选择块内和Bylayer的各种非连续线型
发表于 2013-7-1 03:38:51 | 显示全部楼层 |阅读模式
5明经币
(setq ss (ssget  '((0 . "arc,circle,ellipse,line,*polyline"))))    ;最好只选择下面四种线型
(setq ss1(ssget ss (       ;选取center线型和Bylayer为center的线型,包含块
(setq ss2(ssget ss (       ;选取dashed线型和Bylayer为dashed的线型,包含块
(setq ss3(ssget ss (       ;选取phantom线型和Bylayer为phantom的线型,包含块
(setq ss3(ssget ss (       ;选取divide线型和Bylayer为divide的线型,包含块
谢谢!
下面附上按颜色选对象的程序,供您参考
(defun hy_leachcolorlist(en / eno color layer ccolor cord_laye layerlist
             layerlist1 layername layercolor needlis);;;;参照物体颜色
(SETQ  needlis NIL)
  (if (= (type en) 'ENAME)
  (setq eno (vlax-ename->vla-object en))
  (setq color (vla-get-color eno))
  (setq layer (vla-get-layer eno))
  (setq ccolor (cdr(assoc 62 (entget(tblobjname "layer" layer)))))
  (setq cord_layer (tblnext "layer" t))
  (setq layerlist nil layerlist1 nil)
  (while cord_layer
    (setq layername (cdr(assoc 2 cord_layer)))
    (setq layercolor (cdr(assoc 62 cord_layer)))
    (if (= layercolor color)(setq layerlist (cons (cons 8 layername) layerlist)))
    (if (= layercolor ccolor)(setq layerlist1 (cons (cons 8 layername) layerlist1)))
    (setq cord_layer (tblnext "layer"))
  (if (/= color 256)
      (setq needlis (append '((-4 . "<or"))
            (list(cons 62 color))
            '((-4 . "<and")(62 . 256)(-4 . "<or"))
            (append layerlist  (list(cons 62 color)) )
            '((-4 . "or>")(-4 . "and>")(-4 . "or>"))))
                    (list '(-4 . "<and")(cons 8 layer)'(62 . 256)'(-4 . "and>"))
                 (list(cons 62 ccolor))
                layerlist1
  (if (= (type en) 'INT) (progn
  (setq color EN)
  (setq layerlist nil)
  (while cord_layer
  (if (/= color 256)
  needlis
 楼主| 发表于 2013-7-5 15:58:41 | 显示全部楼层
已经好了~~~~~~~~~~
GMT+8, 2025-5-3 15:52 , Processed in 0.183406 second(s), 27 queries , Gzip On.
