查看: 3632|回复: 18
[LISP群(1)] 2013-07-03 明经 AutoLISP 编程(102918348) 群聊记录:(vl-load-com) (defun C:zx( / np1 np2 n
 关闭 [复制链接]
发表于 2013-7-3 09:40:02 | 显示全部楼层 |阅读模式
[天财]天财 09:40:02
(vl-load-com)
(defun C:zx( / np1 np2 np3 np4 e1 e2 i ii mindis obj1 obj2 pt1 pt2 pt3 pt4 ss ssn)
(setq SS (ssget '((0 . "ARC,*LINE,CIRCLE"))))
  (setq i 1)
  (setq ssn (sslength ss))
  (repeat (1- ssn)
    (setq E1 (ssname SS i))
    (setq ii (1+ i))
      (setq E2 (ssname SS ii))
  (if (and
      E1
      E2
     (setq OBJ1 (vlax-ename->vla-object E1))
     (setq OBJ2 (vlax-ename->vla-object E2))
     (setq pt1 (vlax-curve-getstartpoint E1))
     (setq pt2 (vlax-curve-getEndPoint E1))
     (setq pt3 (vlax-curve-getstartpoint E2))
     (setq pt4 (vlax-curve-getEndPoint E2))
     (setq np1 (th-per pt1 obj2))
     (setq np2 (th-per pt2 obj2))
     (setq np3 (th-per pt3 obj1))
     (setq np4 (th-per pt4 obj1))
     (< (max np1 np2 np3 np4) 8000)
     (> (setq mindis (min np1 np2 np3 np4)) 0)
    (command "._OFFSET" (/ mindis 2) e1 pt3 "")
     (setq cl_x (entlast))
     (command "change" cl_x "" "" "c" "2" "")
    (setq i (1+ i))
;;; 返回(距离  垂足) 点pt到直线的距离和垂足.
(defun th-per (pt obj / pt2 dist)
  (if (and
        pt
        obj
    (setq dist (distance pt (setq pt2 (vlax-curve-getclosestpointto obj pt t))))
 楼主| 发表于 2013-7-3 09:55:24 | 显示全部楼层
[天财]天财 09:55:24
[qqimg]201307/{3E51A856-2DE1-422B-14A6-B57473609B44}.gif[/qqimg]
[lisp-study]jun 10:03:46
偏心能搞么
[天财]天财 10:04:08
偏心能 但是 这个容易出错
[lisp-study]jun 10:04:32
[天财]天财 10:04:40
偏移轴线 然后再写梁 [qqimg]201307/{91AE7D65-5E97-C37F-47D1-1C543EFD8A1D}.gif[/qqimg]
当然 梁线那段码我么发出来
[lisp-study]jun 10:05:29
怎么确定梁宽?
[天财]天财 10:13:11
主次梁还是可以的
[天财]天财 10:18:55
轴线计算时候发生错误
[qqimg]201307/{3131F809-4353-D80C-8619-70E32518B2F5}.gif[/qqimg]
[天财]天财 10:24:41
[qqimg]201307/{91AE7D65-5E97-C37F-47D1-1C543EFD8A1D}.gif[/qqimg] 最后再加个 外框线剪除就完美了 一键建地下室模板
[lisp-study]jun 10:34:41
是啊 你这样手动打断还不如用探索者的画梁呢
 楼主| 发表于 2013-7-3 10:45:12 | 显示全部楼层
[mitenickevin]kevin 10:45:12
[qqimg]201307/{DCD55E74-3A9E-2CD6-2074-EE836DC816EB}.gif[/qqimg]
谁有这个的源码呀,没有币下载不了。
http://bbs.mjtd.com/forum.php?mod=viewthread&tid=99628  [求多边形内相对中心点] 源码
[【KAIXIN】] [【KAIXIN】]炫翔 10:46:44
接收
[天财]天财 10:46:58
我有打断程序 和删除小于某长度距程序
[【KAIXIN】] [【KAIXIN】]炫翔 10:47:17
可以合并成一个
过滤掉图层等...
 楼主| 发表于 2013-7-3 11:01:55 | 显示全部楼层
[天财]天财 11:01:55
快速画图 都是多功能 多命令组合 要不软件优越性体现不出来
[tryhi]大海 11:05:29
请问在移动跟复制的时候,没有显示出那个影像要怎么设置
[tryhi]大海 11:05:59
[qqimg]201307/{DA1A0ADB-BA60-1DC5-6961-901ACCDABDE0}.jpg[/qqimg]
[mmh1][mmh1]漫步地球 11:06:17
额,我还以为是排料程序呢,把这些排在一起呢
 楼主| 发表于 2013-7-3 11:25:12 | 显示全部楼层
[xieling888] 11:25:12
[qqimg]201307/{025522AC-E25A-4783-669E-244AF05346C4}.jpg[/qqimg]
CAD有没有 这样的画笔功能啊
[xieling888] 11:27:33
能直接随意画固定直径的槽,
 楼主| 发表于 2013-7-3 11:50:24 | 显示全部楼层
[开1心]开心就好 11:50:24
不是extrim么
 楼主| 发表于 2013-7-3 13:50:03 | 显示全部楼层
[yifei]绝然 13:50:03
怎么打开一个WINDOWS 程序?
[mmh1][mmh1]漫步地球 13:51:49
startapp ??
[yifei]绝然 13:53:03
不打开文件呢
"C:Program FilesDicad rodpfedit.exe"
只想打开这个 EXE
 楼主| 发表于 2013-7-3 14:04:50 | 显示全部楼层
[csc123456]顽强 14:04:50
半夜,酒劲还未下去的丈夫把妻子推醒:"喂,咱们家闹鬼了~"妻子:"你怎么知道?""刚才我上厕所.刚打开门,厕所灯就自己亮了,等我上完厕所关上门,厕所灯又自己灭了.""你是不是还感到一阵阴风吹来?"妻子关切的问."对,是一阵寒风.""你这个混蛋!"妻子怒吼道:"你又朝冰箱里撒尿了!"!
[yifei]绝然 14:11:26
(command "shell" "C:Program FilesDicad rodpfedit.exe")
这个不对!!
 楼主| 发表于 2013-7-3 14:22:31 | 显示全部楼层
[偏爱云~小吴] 14:22:31
各位大侠如何用commond实现快速选择
[yifei]绝然 14:29:32
33 是什么 意思
[qqimg]201307/{97719392-F200-DF3F-98A7-AF62C204833A}.jpg[/qqimg]
[死者不舞] 14:32:04
哪位朋友有?按指定点的切线方向进行圆滑连接,
有这个程序
两条曲线按指定点的切线方向进行圆滑连接,
[冷面修罗] 14:38:17
组码?
[死者不舞] 14:40:02
程序
[yifei]绝然 14:40:05
不知道
[qqimg]201307/{58151D8E-140D-34C1-CA7B-666B4762F2FC}.jpg[/qqimg]
加个路径是不是能快点
 楼主| 发表于 2013-7-3 14:51:12 | 显示全部楼层
[野狼谷]笨鸟 14:51:12
(apply (read(strcat
GMT+8, 2025-10-18 07:21 , Processed in 0.183796 second(s), 28 queries , Gzip On.
