- 积分
- 11947
- 明经币
- 个
- 注册时间
- 2009-3-11
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2013-7-5 16:47:13
显示全部楼层
我2011的上面有,copy出来给你看下:
;; Overkill.lsp - Overlaping object checker/fixer.
;; Copyright ?1999 by Autodesk, Inc.
;; Your use of this software is governed by the terms and conditions
;; of the License Agreement you accepted prior to installation of this
;; software. Please note that pursuant to the License Agreement for this
;; software, "[c]opying of this computer program or its documentation
;; except as permitted by this License is copyright infringement under
;; the laws of your country. If you copy this computer program without
;; permission of Autodesk, you are violating the law."
;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;; UNINTERRUPTED OR ERROR FREE.
Overlaping vector checker/fixer.
The idea is to find overlapping objects and:
1. remove the un-needed/hidden objects.
2. modify partially overlapping objects such that they no longer overlap.
Supported objects will include:
LINES, POLYLINES, LWPOLYLINES, ARCS, and CIRCLES.
All objects will be broken down into simple line and arc representations
nd placed in a master list.
The master list will contain sublists of the form:
((type gen-data) otherData ename)
Line data Example:
(0 (m b) (p1 p2) ename)
- Type is 0 for a line.
- The general data consists of 'm' and 'b' which are the
slope and y-intersection respectively. The 'm' and 'b'
elements are found in the equation of a line: y=mx+b
- The specific data for a line is the two endpoints.
- Finally an ename
NOTE: If the line is vertical (undefined slope) then 'm' will be nil
and 'b' will actually be the x-axis intersection value.
i.e. (nil 1.0) is the equation of the line x=1.0
Arc Data Example:
(1 (cent radius) (startAng endAng) ename)
- Type is 1 for an arc (includes circles)
- General data is center point and radius
- specific data is comprised of start and end angles respectively.
- ename
Using the (type gen-data) element of each sublist we can m-assoc to
extract a list of all objects that have the potential to overlap.
From here we can loop through the set checking each object against
the others to determine which objects overlap with others.
compare
object1 and object2
... and object3
... and object4
... and object5
If object1 completely contains object2 then delete object2
If object1 partially overlaps with object2 modify object2
acet-ss-remove-dups
0 type
8 layer
6 linetype
62 color
370 lineweight
390 plotstyle
(defun c:overkill ( / lst )
(acet-error-init
(list '("cmdecho" 0)
T
(if (setq lst (acet-overkill-ui nil))
(acet-overkill2 lst)
);if
(acet-error-restore)
);defun c:overkill
(defun c:-overkill ( / lst )
(acet-error-init
T
(if (setq lst (acet-overkill-ui T)) ;force command line
);if
);defun c:-overkill
;If the cmdline arg is true then command will be command line line driven.
(defun acet-overkill-ui ( cmdline / ss lst )
(if (and (setq ss (ssget "_:l"))
(setq ss (car (acet-ss-filter (list ss nil T))))
);and
(princ "\n")
(if (or cmdline
(= 4 (logand 4 (getvar "cmdactive")))
(= 0 (getvar "cmddia"))
);or
(setq lst (acet-overkill-ui-cmd))
(setq lst (acet-overkill-ui-dlg))
);if
(if lst
(setq lst (cons ss lst))
);if
);progn then
);if
);defun acet-overkill-ui
(defun acet-overkill-ui-cmd ( / ans )
(setq ans T)
(while ans
(acet-overkill-print-modes)
(initget "Ignore Fuzz Plines parTial Endtoend") ;; force non-negative entry 4+128
(setq ans (getkword "\nEnter an option to change [Ignore/Fuzz/Plines/parTial/Endtoend] <done>: "))
(cond
((= ans "Ignore") (acet-overkill-ui-cmd-ignore))
((= ans "Fuzz") (acet-overkill-ui-cmd-fuz))
((= ans "Plines") (acet-overkill-ui-cmd-plines))
((= ans "parTial") (acet-overkill-ui-cmd-partial))
((= ans "Endtoend") (acet-overkill-ui-cmd-endtoend))
);cond close
);while
(list
(max (acet-overkill-fuz-get) 1.0e-08)
(acet-overkill-ignore-get)
(acet-overkill-no-plines-get)
(acet-overkill-no-partial-get)
(acet-overkill-no-endtoend-get)
);list
);defun acet-overkill-ui-cmd
;prompts for fuz value and returns the fuz as a floating point number.
(defun acet-overkill-ui-cmd-fuz ( / def fuz ans )
(setq def (acet-overkill-fuz-get))
(if (not def)
(setq def 0.000001)
);if
(initget 4) ;; no negative fuz
(setq ans (getdist
(acet-str-format "\nSpecify Fuzz for numeric comparisons <%1>: "
(acet-rtos2 def)
);getdist
);setq
(if (not ans)
(setq ans def)
);if
(acet-overkill-fuz-set ans)
ans
);defun acet-overkill-ui-cmd-fuz
;prompts for properties to ignore and returns the ignore list (list of common group codes to ignore
;during object comparisons)
(defun acet-overkill-ui-cmd-ignore ( / def fuz ans lst a x anslst lst2 lst3 n ignore )
(setq ignore (acet-overkill-ignore-get))
(acet-overkill-print-ignore)
(setq lst '((8 "LAYER")
(6 "LTYPE")
(62 "COLOR")
(370 "LWEIGHT")
(390 "PLOTSTYLE")
);setq
;; build a list of strings
(foreach x lst
(setq lst2 (cons (cadr x) lst2));setq then
);foreach
(setq lst2 (cons "." lst2)
lst2 (reverse lst2)
) ;add a dot as valid entry (used to specify none)
(princ "\nSpecify properties to ignore when comparing objects... ")
(setq ans (acet-ui-m-get-names
(list nil ;; no spaces
"\n[layer,ltype,color,lweight,plotstyle, * (for all)] or \".\" for none <default>: "
lst2 ;; valid entries
);list
);acet-ui-m-get-names
);setq
(if ans
;; now convert back to a list of group codes and save it.
(setq lst (mapcar 'reverse lst)
lst2 nil
);setq
(foreach x ans
(if (setq a (assoc x lst))
(setq lst2 (cons (cadr a) lst2));setq then
);if
);foreach
(setq lst2 (reverse lst2))
(acet-overkill-ignore-set lst2)
);progn then
);if
);defun acet-overkill-ui-cmd-ignore
(defun acet-overkill-ui-cmd-plines (/ def ans a )
(setq def (acet-overkill-no-plines-get))
(if (= def 1)
(setq def "No")
(setq def "Yes")
);if
(initget "Yes No")
(setq ans (getkword (acet-str-format "\nOptimize segments within plines <%1>: " def)))
(if (not ans)
(setq ans def)
);if
(if (= ans "No")
(acet-overkill-no-plines-set T)
(setq a T)
);progn
(acet-overkill-no-plines-set nil)
);if
a
);defun acet-overkill-ui-cmd-plines
(defun acet-overkill-ui-cmd-partial (/ def ans a )
(setq def (acet-overkill-no-partial-get))
(if (= def 1)
(setq def "No")
(setq def "Yes")
);if
(initget "Yes No")
(setq ans (getkword (acet-str-format "\nCombine co-linear objects that partially overlap <%1>: " def)))
(if (not ans)
(setq ans def)
);if
(if (= ans "No")
(acet-overkill-no-partial-set T)
(setq a T)
);progn
(acet-overkill-no-partial-set nil)
);if
a
);defun acet-overkill-ui-cmd-partial
(defun acet-overkill-ui-cmd-endtoend (/ def ans a )
(setq def (acet-overkill-no-endtoend-get))
(if (= def 1)
(setq def "No")
(setq def "Yes")
);if
(initget "Yes No")
(setq ans (getkword (acet-str-format "\nCombine co-linear objects when aligned end to end <%1>: " def)))
(if (not ans)
(setq ans def)
);if
(if (= ans "No")
(acet-overkill-no-endtoend-set T)
(setq a T)
);progn
(acet-overkill-no-endtoend-set nil)
);if
a
);defun acet-overkill-ui-cmd-endtoend
(defun acet-overkill-print-ignore ( / ignore lst a x )
(setq lst '((8 "Layer")
(6 "Linetype")
(62 "Color")
(370 "Lineweight")
(390 "Plotstyle")
);setq
(if ignore
(princ "\nIGNORE=")
(princ "\nIGNORE=none")
);if
(foreach x ignore
(if a
(princ ",")
);if
(princ (cadr a))
);if
);foreach
);defun acet-overkill-print-ignore
(defun acet-overkill-print-modes ( / fuz ignore no-plines no-partial no-endtoend x a lst )
(setq fuz (acet-overkill-fuz-get)
no-plines (acet-overkill-no-plines-get)
no-partial (acet-overkill-no-partial-get)
no-endtoend (acet-overkill-no-endtoend-get)
);setq
(princ "\n")
(princ (strcat "Fuzz=" (acet-rtos2 fuz)))
(if (not no-plines) ;; "aint got no back-eyed peas neither!"
(princ ", Optimize PLINES=Y")
(princ ", Optimize PLINES=N")
);if
(if (not no-partial)
(princ ", combine PARTIAL overlap=Y")
(princ ", combine PARTIAL overlap=N")
);if
(if (not no-endtoend)
(princ ", combine ENDTOEND=Y")
(princ ", combine ENDTOEND=N")
);if
);defun acet-overkill-print-modes
(defun acet-overkill-ui-dlg ( / ignore checkit lst flag iv fuz )
(if (> (setq iv (load_dialog "overkill"));setq
0
);test
(if (new_dialog "overkill" iv)
;; local function validates and returns the list of group codes to ignore and the fuz
;; if no errors are found.
(defun checkit ( / ignore fuz lst no-plines no-partial no-endtoend)
(if (= (get_tile "layer") "1")
(setq ignore (cons 8 ignore))
);if
(if (= (get_tile "linetype") "1")
(setq ignore (cons 6 ignore))
);if
(if (= (get_tile "color") "1")
(setq ignore (cons 62 ignore))
);if
(if (= (get_tile "lineweight") "1")
(setq ignore (cons 370 ignore))
(if (= (get_tile "plotstyle") "1")
(setq ignore (cons 390 ignore))
(if (= (get_tile "plines") "0")
(setq no-plines T)
(if (= (get_tile "partial") "0")
(setq no-partial T)
(if (= (get_tile "endtoend") "0")
(setq no-endtoend T)
(setq fuz (get_tile "fuz"))
(if (or (not (distof fuz))
(< (distof fuz) 0.0)
);or
(set_tile "error" "Invalid. Fuzz value must be numeric and non-negative.")
(setq lst (list (distof fuz)
ignore
no-plines
no-partial
no-endtoend
);list
);setq else
);if
lst
);defun checkit
;; initialize the tiles
(if (member 8 ignore)
(set_tile "layer" "1")
(set_tile "layer" "0")
);if
(if (member 6 ignore)
(set_tile "linetype" "1")
(set_tile "linetype" "0")
);if
(if (member 62 ignore)
(set_tile "color" "1")
(set_tile "color" "0")
);if
(if (member 370 ignore)
(set_tile "lineweight" "1")
(set_tile "lineweight" "0")
);if
(if (member 390 ignore)
(set_tile "plotstyle" "1")
(set_tile "plotstyle" "0")
);if
(set_tile "fuz" (acet-rtos2 (acet-overkill-fuz-get)))
(if (acet-overkill-no-plines-get)
(set_tile "plines" "0")
(set_tile "plines" "1")
);if
(if (acet-overkill-no-partial-get)
(set_tile "partial" "0")
(set_tile "partial" "1")
);if
(if (acet-overkill-no-endtoend-get)
(set_tile "endtoend" "0")
(set_tile "endtoend" "1")
);if
(action_tile "accept" "(if (setq lst (checkit)) (done_dialog 1))")
(action_tile "cancel" "(done_dialog 0)")
(action_tile "help" "(acet-help \"OVERKILL\")")
(setq flag (start_dialog));setq
(if (= flag 1)
(acet-overkill-fuz-set (nth 0 lst))
(acet-overkill-ignore-set (nth 1 lst))
(acet-overkill-no-plines-set (nth 2 lst))
(acet-overkill-no-partial-set (nth 3 lst))
(acet-overkill-no-endtoend-set (nth 4 lst))
(setq lst (list (max (nth 0 lst) 1.0e-08) ;min uz value of 1.0e-08
(nth 1 lst)
(nth 2 lst)
(nth 3 lst)
(nth 4 lst)
);list
);setq
);progn then
);if
);progn then initialize the tiles and activate the dialog box
(alert "Unable to display dialog box")
);if new dialog
(unload_dialog iv);unload it when done
);progn then
(alert "Unable to load dialog box");else
);if load
(if (= flag 1)
(acet-acad-refresh) ;force AutoCAD to refresh it's window.
);if
lst
);defun acet-overkill-ui-dlg
;Returns a list of group codes that corispond to properties that overkill will ignore
;when comparing objects.
(defun acet-overkill-ignore-get ( / lst )
(setq lst (acet-getvar (list "ACET-OVERKILL-IGNORE" 6))) ;; 2+4=look in current profile then in fixed profile
(if (and lst
(/= lst "")
);and
(setq lst (acet-str-to-list "," lst)
lst (mapcar 'atoi lst)
);setq
(setq lst nil)
);if
lst
);defun acet-overkill-ignore-get
;Takes a list of group codes that corispond to properties that overkill will ignore
;and saves the data in the current profile as well as the fixed profile.
(defun acet-overkill-ignore-set ( ignore / gcode a )
(setq a "")
(foreach gcode ignore
(setq a (strcat a "," (itoa gcode)))
);foreach
(if (/= a "")
(setq a (substr a 2))
);if
(acet-setvar (list "ACET-OVERKILL-IGNORE" a 6)) ;; 2+4=place it in current and fixed profiles
);defun acet-overkill-ignore-set
;; default get and set functions
(defun acet-overkill-fuz-get ( / fuz )
(setq fuz (acet-getvar '("ACET-OVERKILL-FUZZ" 1)))
(if (not fuz)
(setq fuz 0.000001)
);if
fuz
);defun acet-overkill-fuz-get
(defun acet-overkill-fuz-set ( fuz / )
(acet-setvar (list "ACET-OVERKILL-FUZZ" fuz 1))
);defun acet-overkill-fuz-set
(defun acet-overkill-no-plines-get ( / no-pline )
(setq no-pline (acet-getvar '("ACET-OVERKILL-NO-PLINES")))
(if (/= no-pline 1)
(setq no-pline nil)
);if
no-pline
);defun acet-overkill-no-plines-get
(defun acet-overkill-no-plines-set ( no-pline / )
(if no-pline
(acet-setvar (list "ACET-OVERKILL-NO-PLINES" 1 3))
(acet-setvar (list "ACET-OVERKILL-NO-PLINES" 0 3))
);if
);defun acet-overkill-no-plines-set
(defun acet-overkill-no-partial-get ( / no-partial )
(setq no-partial (acet-getvar '("ACET-OVERKILL-NO-PARTIAL")))
(if (/= no-partial 1)
(setq no-partial nil)
);if
no-partial
);defun acet-overkill-no-partial-get
(defun acet-overkill-no-partial-set ( no-partial / )
(if no-partial
(acet-setvar (list "ACET-OVERKILL-NO-PARTIAL" 1 3))
(acet-setvar (list "ACET-OVERKILL-NO-PARTIAL" 0 3))
);if
);defun acet-overkill-no-partial-set
(defun acet-overkill-no-endtoend-get ( / no-endtoend )
(setq no-endtoend (acet-getvar '("ACET-OVERKILL-NO-ENDTOEND")))
(if (/= no-endtoend 1)
(setq no-endtoend nil)
);if
no-endtoend
);defun acet-overkill-no-endtoend-get
(defun acet-overkill-no-endtoend-set ( no-endtoend / )
(if no-endtoend
(acet-setvar (list "ACET-OVERKILL-NO-ENDTOEND" 1 3))
(acet-setvar (list "ACET-OVERKILL-NO-ENDTOEND" 0 3))
);if
);defun acet-overkill-no-endtoend-set
;;;functions below are maintained for backward compatibility...
(defun acet-overkill (alst)
(acet-overkill2 alst)
(defun acet-overkill-resolve-lines ( lst ss2 fuz no-partial no-endtoend / )
(acet-overkill-resolve-arcs2 lst ss2 fuz no-partial no-endtoend)
(defun acet-overkill-resolve-arcs ( lst ss2 fuz no-partial no-endtoend / )
(defun acet-overkill-line-data ( e1 fuz genprops / )
(acet-overkill-line-data2 e1 fuz genprops)
(defun acet-overkill-gen-prop-get ( e1 genprops / )
(acet-overkill-gen-prop-get2 e1 genprops)
(defun acet-rtos (val)
(acet-rtos2 val)
(defun acet-overkill-ss->primitives ( ss fuz ignore )
(acet-overkill-ss->primitives2 ss fuz ignore)
(acet-autoload2 '("OVERKILLSUP.LSP" (acet-overkill2 alst)))
(acet-autoload2 '("OVERKILLSUP.LSP" (acet-overkill-gen-prop-get2 e1 genprops)))
(acet-autoload2 '("OVERKILLSUP.LSP" (acet-overkill-line-data2 e1 fuz genprops)))
(acet-autoload2 '("OVERKILLSUP.LSP" (acet-overkill-resolve-arcs2 lst ss2 fuz no-partial no-endtoend)))
(acet-autoload2 '("OVERKILLSUP.LSP" (acet-overkill-ss->primitives2 ss fuz ignore)))
(acet-autoload2 '("OVERKILLSUP.LSP" (acet-rtos2 val)))
