查看: 3281|回复: 16
[LISP群(1)] 2013-07-11 明经 AutoLISP 编程(102918348) 群聊记录:(defun c:cc(/ ss ssarea p);找形心 (setq
 关闭 [复制链接]
发表于 2013-7-11 00:01:06 | 显示全部楼层 |阅读模式
[500w008]500w008 00:01:06
  (setq ss(ssget))
  (setq i 0)
  (setq len (length ss))
  (repeat len
  (setq s_x (ssname ss i))
  (command "_.region" s_x "")
  (setq p(vlax-get (vlax-ename->vla-object s_x)"centroid"))
  (command "_.explode" "L")
 (entmake
    (list (cons 0 "point") (cons 8 "temp") (cons 10 cep))
  (setq i (+ i 1))
把形心也打印出来 有错
  (setq ss(ssget))
  (setq i 0)
  (repeat len
 (entmake
    (list (cons 0 "point") (cons 8 "temp") (cons 10 p))
  (setq i (+ i 1))
[500w008]500w008 00:08:03
(defun c:cc(/ ss s_x p);找形心
  (setq ss(ssget))
  (setq i 0)
  (repeat len
  (entmake
  (setq i (+ i 1))
 楼主| 发表于 2013-7-11 07:52:14 | 显示全部楼层
[500w008]500w008 07:52:14
[qqimg]201307/{C0E7A7F8-DBF9-EC9E-235E-BE3D93915467}.jpg[/qqimg]
[pzweng][pzweng]路人 07:55:35
[qqimg]201307/{EA4B8AD7-244B-9A96-079E-C0015D1B06C6}.gif[/qqimg]咪咪?
 楼主| 发表于 2013-7-11 08:20:31 | 显示全部楼层
[500w008]500w008 08:20:31
  (setq ss(ssget))
  (setq i 0)
  (repeat len
  (setq p (car (entget )))
  (setq p_x (car p)
        p_y (cadr p)
        lpp (list p_x p_y)
  (entmake
    (list (cons 0 "point") (cons 8 "temp") (cons 10 lpp))
  (setq i (+ i 1))
[pzweng][pzweng]路人 08:20:42
晕死
[500w008]500w008 08:20:48
点不出来 怎么办哥
[pzweng][pzweng]路人 08:21:23
这句有行不行
temp有没有
[500w008]500w008 08:22:04
哦 我试试
[500w008]500w008 08:26:57
  (COMMAND "LAYER" "M" "pt" "C" "4" "pt" "LT" "continuous" "pt" "")
  (setq ss(ssget))
  (setq i 0)
  (repeat len
  (setq p_x (car p)
        p_y (cadr p)
        lpp (list p_x p_y)
  (entmake
    (list (cons 0 "point") (cons 8 "pt") (cons 10 lpp))
  (setq i (+ i 1))
[500w008]500w008 08:28:26
仍然不行
[pzweng][pzweng]路人 08:35:52
你的图层名是pt?
[pzweng][pzweng]路人 08:37:50
错误太多
[500w008]500w008 08:38:30
[仲文玉][仲文玉]wygjx 08:39:08
自己逐条调试,发了n遍
[pzweng][pzweng]路人 08:39:18
是啊。烦死人了
[仲文玉][仲文玉]wygjx 08:39:20
看看变量对不对
[pzweng][pzweng]路人 08:39:26
昨晚12点还在发
[仲文玉][仲文玉]wygjx 08:39:40
[qqimg]201307/{C800B82C-7281-8437-A617-D7415D67D960}.jpg[/qqimg]
[pzweng][pzweng]路人 08:39:51
这句没错
前面错了很多
[500w008]500w008 08:40:53
帮忙看下
[pzweng][pzweng]路人 08:41:05
你的目的是什么
[仲文玉][仲文玉]wygjx 08:41:11
论坛不是有么
形心
[pzweng][pzweng]路人 08:41:24
这肯定是论坛里找的
[500w008]500w008 08:41:28
论坛上 都是单个的
[仲文玉][仲文玉]wygjx 08:41:49
加上循环不就是了
[pzweng][pzweng]路人 08:41:50
你要选多线段
[500w008]500w008 08:42:17
选了的
[qqimg]201307/{B7B4CA93-3ECF-F23A-17FC-D9B3223B8E29}.jpg[/qqimg]
[pzweng][pzweng]路人 08:42:43
你要确定是封闭的多线段
[雨的节奏][雨的节奏] 08:42:48
局长最喜欢的一位女秘书,工作上毫无过错,却被局长炒鱿鱼了。
有朋友问是何缘由?局长说:“前几天我过生日,她邀请我去她家过,她还特别告诉我她老公出差了。进门后她让我呆在客厅,然后神秘地说她先去卧室,让我五分钟后再进去。”
朋友急切地问到“然后呢……?”
局长愤愤地说“我推开卧室门后,顿时被吓晕了,单位里的同事都挤在卧室里点着蜡烛,齐声唱起生日快乐歌”。
朋友舒了口气说 “那有什么了不得?这创意不错啊!”
局长怒火中烧,骂道:“他妈的,还不错呢,老子是光着身子进去的!”
[500w008]500w008 08:43:41
[qqimg]201307/{740CAECF-D919-B89F-F026-2AEC60436832}.GIF[/qqimg]
[pzweng][pzweng]路人 08:44:21
(defun c:test (/ ss s_x p)        ;找形心
  (setq ss (ssget))
  (setq i 0)
  (setq len (sslength ss))
  (repeat len
      (setq p (vlax-get (vlax-ename->vla-object (entlast)) "centroid"))
      (entmake
    (list (cons 0 "point") (cons 8 "pt") (cons 10 p))
      (setq i (+ i 1))
[onandoff] 08:44:34
海天盛筵啊
[500w008]500w008 08:46:41
可以了
[pzweng][pzweng]路人 08:47:09
在论坛混这么久了,这种简单的都不会
[500w008]500w008 08:47:39
我一般是凑起来的 没有怎么思考 用脑 太伤神经
[pzweng][pzweng]路人 08:47:42
下次有问题在论坛里发,别在群里无止尽的发
[500w008]500w008 08:47:43
[qqimg]201307/{91AE7D65-5E97-C37F-47D1-1C543EFD8A1D}.gif[/qqimg]
[pzweng][pzweng]路人 08:48:03
再这样找T
[500w008]500w008 08:48:22
差不多可以T掉我了
[pzweng][pzweng]路人 08:49:03
呵呵,那不止,要封论坛帐号的
[500w008]500w008 08:55:36
[qqimg]201307/{91AE7D65-5E97-C37F-47D1-1C543EFD8A1D}.gif[/qqimg]准备凑个一键出地下室
[pzweng][pzweng]路人 08:59:33
你这水平凑毛线
别来烦大家就行
[500w008]500w008 09:00:02
我凑了几个好用的 共享了
[500w008]500w008 09:01:06
我们这个专业 只要会凑就行了 不像机械 模具
[pzweng][pzweng]路人 09:01:21
你连凑都不会
[vormittag]桔子 09:01:32
胶水的本事谁都有,有什么可共享的。
[pzweng][pzweng]路人 09:02:22
就知道使劲在群里发来发去
[500w008]500w008 09:03:33
[qqimg]201307/{B0665973-2E4D-0A15-254E-CFC74BB22072}.gif[/qqimg]
[pzweng][pzweng]路人 09:04:53
这有何难
雕虫小技
[csc123456]顽强 09:06:01
会则不难,隔行如隔山
[500w008]500w008 09:06:43
洗洗睡
[pzweng][pzweng]路人 09:07:18
发了几遍了
[onandoff] 09:07:26
[lisp-study]jun 09:07:32
这个没啥用处
[csc123456]顽强 09:07:44
[lisp-study]jun 09:08:14
一般都用生成的图纸修改 生成的都是画好了的
[pzweng][pzweng]路人 09:08:18
我看这个也不是他自己凑的
也是别人给他弄好的
[500w008]500w008 09:09:27
好咯 都是你们贡献
[500w008]500w008 09:12:58
 楼主| 发表于 2013-7-11 09:28:30 | 显示全部楼层
[500w008]500w008 09:28:30
路人 帮我纠正一个错误 就以导师自居 [qqimg]201307/{91AE7D65-5E97-C37F-47D1-1C543EFD8A1D}.gif[/qqimg]
[pzweng][pzweng]路人 09:28:50
你不止一两次
你自己知道
[500w008]500w008 09:30:03
我个脑都没你们发达 所以得请教你们
 你们有一个机器般的脑袋
[onandoff] 09:32:55
  人家也是学出来的 熟能生巧
[kwok][ww5w]行舟月下 09:33:29
每次看到帮助那些car就眼困,汗
还是要多写,光看没用,一会就忘了
[雨的节奏][雨的节奏] 09:34:34
[qqimg]201307/{DB849334-E3C3-0FD0-41CA-615D0522D0ED}.GIF[/qqimg]
[VBALISPER]恐龙 09:41:49
各位高手,麻烦帮我看一下这个进位的程序.怎么总是进位不全.
[VBALISPER]恐龙 09:42:22
结果中还有某位数为10的(3 1 3 8 2 5 9 3 2 9 5 1 5 5 9 0 5 6 7 9 2 3 3 8 8 1 10 8 3 4 10)
[500w008]500w008 09:44:51
[qqimg]201307/{9E344B5C-E11E-60D0-CB02-A306142436B3}.jpg[/qqimg]
[500w008]500w008 09:45:44
[qqimg]201307/{4395DECD-3E51-0EA4-5DE2-1415901EA0B9}.jpg[/qqimg]
[tiyi8888]永远D痛 09:51:41
什么东东
他不逃吗
这么巧
[pzweng][pzweng]路人 09:58:27
他不信别人会压他
[夏生生][x_s_s_1]生无可恋 10:02:07
[qqimg]201307/{E691469D-7DE6-955E-1C95-EABA3130B74B}.jpg[/qqimg]不要侮辱结构专业
[冷面修罗][冷面修罗] 10:02:32
这个是那里的?这么强悍
[VBALISPER]恐龙 10:04:29
XSSL,有空没有,帮我看看进位的问题好吗
[夏生生][x_s_s_1]生无可恋 10:04:47
我看看,不一定会
[500w008]500w008 10:05:03
[qqimg]201307/{740CAECF-D919-B89F-F026-2AEC60436832}.GIF[/qqimg] 你也有不会时候
[VBALISPER]恐龙 10:05:18
代码就在前面.修改表中某一位值,用的你昨天写的函数.
[pzweng][pzweng]路人 10:06:01
是我的吧
[VBALISPER]恐龙 10:07:03
你的和XSSL类似,但确是他的
[x_s_s_1]生无可恋(381164857) 22:08:33
()(defun change_n(lst n change / lst1)
  (repeat (1- n)(setq lst1(cons (car lst)lst1)lst(cdr lst)))
  (append(reverse lst1)(cons change(cdr lst)))
[pzweng][pzweng]路人 10:07:23
他用的是mapcar
[pzweng][pzweng]路人 10:08:14
差不多
[VBALISPER]恐龙 10:09:08
我刚从昨天聊天记录复制过来的呀.桔子和雨中漫建议的是用mapcar
[pzweng][pzweng]路人 10:09:26
这样啊
呵呵,我只看到mapcar
[夏生生][x_s_s_1]生无可恋 10:09:46
出个变更先
[pzweng][pzweng]路人 10:13:00
恐龙
如果是-143呢
应该是什么值
[VBALISPER]恐龙 10:14:04
借前一位150.本位=7
[pzweng][pzweng]路人 10:14:20
不太懂
[VBALISPER]恐龙 10:14:29
每个元素值=0
[pzweng][pzweng]路人 10:14:57
(3 2 -6 3 -56 85 5 41 22 15 -50 -52 33 22 37 17 36 -4 13 -56 44 81 19
51 -23 13 -14 47 11 31 -60)
这个表的结果应该是什么样的
[VBALISPER]恐龙 10:15:18
不是
[pzweng][pzweng]路人 10:15:28
(3 2 -6 3 -56 85 5 41 22 15 -50 -52 33 22 37 17 36 -4 13 -56 44 81 19 51 -23 13 -14 47 11 31 -60)
这个表的结果应该是什么样的
[VBALISPER]恐龙 10:16:03
就相当于每个元素是一位数.0-9的数.>9了要进位.
[lisp-study]jun 10:16:32
不懂
你直接举例说明
[pzweng][pzweng]路人 10:16:47
-60进位是多少
[VBALISPER]恐龙 10:16:49
(3 1 3 8 2 5 9 3 2 9 5 1 5 5 9 0 5 6 7 9 2 3 3 8 8 1 10 8 3 4 10)可能是这个结果吧.只是还有两个10没有进位.
[pzweng][pzweng]路人 10:17:02
-60借位后是多少
[VBALISPER]恐龙 10:17:15
要在前面借60.这位为0,前位-6
[pzweng][pzweng]路人 10:17:31
那应该是7?
[VBALISPER]恐龙 10:17:44
所以这个程序不知道错在哪里.我也没检查出来错误.
[pzweng][pzweng]路人 10:17:52
是不是返回7?
[VBALISPER]恐龙 10:17:57
不是7
[pzweng][pzweng]路人 10:18:01
是多少
6?
[VBALISPER]恐龙 10:18:29
-60,要在前面借6个,在本位就是60.结果是这位为0,前位-6
就和数学加减法进位借位一样.
[VBALISPER]恐龙 10:20:10
假设是(1 9 34)那么34,就要向前一位进3,本位变成4,9得到后面进来的3,变成12,又向前进1,本位变成2.最后结果就是(2 2 4)
[328302216][328302216]小莫 10:21:05
谁有画门、窗、柱、樑的小程序,可以分享弄来玩玩吗!!
[pzweng][pzweng]路人 10:21:33
明白了
134呢
(1 9 134) -> (3 2 4)
是不
[VBALISPER]恐龙 10:22:12
(9 -60)就从前一位借6个过来.把-60变成0,前面减6,得(3 0)
134就要向前 一位进13
[pzweng][pzweng]路人 10:22:26
明白了
我看看
[VBALISPER]恐龙 10:22:46
多谢各位出手相助.
[lisp-study]jun 10:23:17
这样说一下子就明白了
[pzweng][pzweng]路人 10:23:27
9494
[VBALISPER]恐龙 10:23:40
[pzweng][pzweng]路人 10:23:48
干脆重写得了
[VBALISPER]恐龙 10:25:10
哦.写得不好哈.我感觉程序没问题,用了昨天你们写的修改某个元素值的函数.但结果却不对.用了两次进位函数还是有个别出现10的情况.
[夏生生][x_s_s_1]生无可恋 10:25:15
(11 31 -60)返回(14 7 0)?
[VBALISPER]恐龙 10:25:59
31被借6个,变成25.第二位就为5,向前进2
(1 3 5 0)
第1个11+2,=13,就又向前进1.
[夏生生][x_s_s_1]生无可恋 10:26:50
那就是说明你的表要变长的
[VBALISPER]恐龙 10:26:58
不会.
最前面的数字小,不会再进位
[VBALISPER]恐龙 10:28:33
这是求PI的程序的一部分.最前面的3.14这些不会再进位了.
[VBALISPER]恐龙 10:29:56
只是目前精度还不够,结果不是(3 1 4 1 5 9 2 6....)后面几位有错.但每个元素只能是0-9的数.要进位或借位.
[pzweng][pzweng]路人 10:30:11
前面是(0 3 -6)->会是什么
[VBALISPER]恐龙 10:30:33
(0 2 4)
[夏生生][x_s_s_1]生无可恋 10:30:33
你那个表最后6唯是不是(2 0 8 3 5 0)
[pzweng][pzweng]路人 10:30:51
怎么来的
[VBALISPER]恐龙 10:31:01
我看看
[夏生生][x_s_s_1]生无可恋 10:31:23
[pzweng][pzweng]路人 10:31:37
[500w008]500w008 10:31:53
那个形心程序怎么把 选择的多义性也变成了ETMAKE的图层了
[VBALISPER]恐龙 10:32:02
13 -14 47 11 31 -60)                  1 2 0 8 3 5 0
对的208350,前面还要进一个1
[夏生生][x_s_s_1]生无可恋 10:32:32
明白了
[仲文玉][仲文玉]wygjx 10:33:05
这东东有啥用哈
有点意思
[pzweng][pzweng]路人 10:33:43
那不是表长了?
[仲文玉][仲文玉]wygjx 10:34:11
表长度会因为首位数字大小改变
[pzweng][pzweng]路人 10:35:06
是呀
[仲文玉][仲文玉]wygjx 10:35:26
首先判断首位数字
[仲文玉][仲文玉]wygjx 10:36:00
如果>8就要看第二位了
[xiaomm250][lisp_](car (entsel)) 10:36:47
[qqimg]201307/{162009BA-D4CD-F36C-1E0C-4F65F843BBC0}.jpg[/qqimg] ,如何把这儿加载的插件的记录都导出来,然后导到另一台电脑上?
[pzweng][pzweng]路人 10:36:54
第二会是3位数怎么办
[VBALISPER]恐龙 10:37:01
这是由很多表单位相加得到的.每个元素代表一个数字,只能是0-9的.这个程序计算PI值的一部分,前几位定了,只能是3 1 4 ...
前面不会再进位了.
[仲文玉][仲文玉]wygjx 10:37:40
啊,不进位?
[VBALISPER]恐龙 10:38:02
嗯.应该是从后面往前进位
第一位是3,
[仲文玉][仲文玉]wygjx 10:38:41
第2位是3位数,就要吧3位数的前两位进入第一位
3位数,不是3
[仲文玉][仲文玉]wygjx 10:39:19
是3的就保持原数不变了
[pzweng][pzweng]路人 10:39:20
3位数怎么办
[VBALISPER]恐龙 10:39:24
第3位如果>9了,就向第2位进1.和数学加法一样.
0-9的都不变.
[pzweng][pzweng]路人 10:39:56
(3 155) -> (3+15 5)->(1 8 5)
[仲文玉][仲文玉]wygjx 10:40:04
就要把 3位数的前两位 并入第一位后,计算第一位
[VBALISPER]恐龙 10:40:06
哦.我明白了.我的程序就错在这里.
[pzweng][pzweng]路人 10:40:29
错哪里了
[VBALISPER]恐龙 10:41:04
0-9的也进位或借位了.
[仲文玉][仲文玉]wygjx 10:41:05
如果第二位是三位数,表长度至少加一位
[pzweng][pzweng]路人 10:44:10
少一个判断吧
[VBALISPER]恐龙 10:44:46
(3 2 -6 3 -56 85 5 41 22 15 -50 -52 33 22 37 17 36 -4 13 -56 44 81 19 51 -23 13 -14 47 11 31 -60)现在的表是这样.前几位没有3位数的.
[pzweng][pzweng]路人 10:44:48
把做好的程序发过来看看
[VBALISPER]恐龙 10:45:30
好的。
[pzweng][pzweng]路人 10:46:23
求圆周率啊
[VBALISPER]恐龙 10:46:59
是的。
[VBALISPER]恐龙 10:53:46
我还是没找到错的地方。>9和
[pzweng][pzweng]路人 10:55:19
还不行
[pzweng][pzweng]路人 10:56:36
你没有写等于9的判断呀
[VBALISPER]恐龙 10:56:53
=9不用进位嘛
[pzweng][pzweng]路人 10:57:16
那也得写
程序不知道
[VBALISPER]恐龙 10:57:55
我没明白.不进位就保持原样.
[仲文玉][仲文玉]wygjx 10:59:08
本位是9可以不写
他是从表最后往前算的
[VBALISPER]恐龙 10:59:25
(1 3 9 3)不进行change_n过程.直接跳过了.
[仲文玉][仲文玉]wygjx 10:59:26
不影响
[pzweng][pzweng]路人 10:59:59
说明9还是要判断的
[pzweng][pzweng]路人 11:03:04
不对
我看一下
[pzweng][pzweng]路人 11:04:47
感觉写复杂了
[VBALISPER]恐龙 11:05:59
哦.是有可能.我程序就是写得乱.
[pzweng][pzweng]路人 11:06:47
我知道了
(setq jg (change_n    jg m (+ benwei jiews)))
这里错了
(+ benwei jiews) = 10
[VBALISPER]恐龙 11:08:21
多借了1个10,好象是
[仲文玉][仲文玉]wygjx 11:08:43
fix
[VBALISPER]恐龙 11:09:21
看来就是这里错了.  -43  借 50   而-40,只能借40不能借50
谢谢各位
[pzweng][pzweng]路人 11:10:38
(3 1 7 2 8 5 9 3 2 9 5 9 5 5 9 0 5 4 7 1 2 3 3 8 2 1 0 8 3 4 0)
这样对不
(setq tem_n (- (abs benwei )(* 10 (fix (/ (abs benwei) 10)))))
加了这句
[VBALISPER]恐龙 11:11:10
可能是对的吧.位数少,前面都不是3 1 4了
[VBALISPER]恐龙 11:13:21
好象还没有对,直接fix,好象遇到-43这样的,只借了40来,还是-3.要借50,得7
我再改一下.
[邹锋]Tony 11:13:38
它把图纸也删除了,怎么让它不删除
[邹锋]Tony 11:20:02
怎么搞
[pzweng][pzweng]路人 11:28:59
(3 2 -6 3 -56 85 5 )前面几位
这几位能得出3.14159?
[pzweng][pzweng]路人 11:37:28
恐龙在吗
[VBALISPER]恐龙 11:46:50
[夏生生][x_s_s_1]生无可恋 11:46:51
(defun test (lst / n a b c d lst1)
  (setq n (length lst))
  (setq lst (reverse lst))
  (repeat n
    (setq a   (car lst)
      lst (cdr lst)
    (cond ((< a 0)
       (setq c (abs a)
         d (fix (/ c 10.))
       (if (= 0 (rem c 10))
         (setq b    (- d)
           lst1    (cons 0 lst1)
           lst    (cons (+ (car lst) b) (cdr lst))
         (setq b    (- (1+ d))
           lst1    (cons (- a (* b 10)) lst1)
      ((= 0 a) (setq lst1 (cons 0 lst1)))
      ((> a 0)
       (setq b (fix (/ a 10.)))
       (if (< a 10)
         (setq lst1 (cons a lst1))
         (setq lst1    (cons (- a (* b 10)) lst1)
恐龙,看看这个
(3 1 3 8 2 5 9 3 2 9 5 1 5 5 9 0 5 6 7 9 2 3 3 8 8 2 0 8 3 5 0) 你的表返回的
[VBALISPER]恐龙 11:47:28
前几位不一能是 3 1 4 1 5 9 ,位数少了,相加的项少了,精度 不够
好的.谢谢
[pzweng][pzweng]路人 11:49:06
程序没错吧
[VBALISPER]恐龙 11:50:47
应该没有错.我那个就是还要加一个判断.编的时候,只考虑到了-43这样的情况.借50.没考虑到整10的情况,-40,只借40,得0,如果借了50,就成了10了.
[pzweng][pzweng]路人 11:51:29
(>= benwei 9)
这里要用>=
[VBALISPER]恐龙 11:51:49
不是吧.=9也不用进位的.
[VBALISPER]恐龙 11:52:29
吃饭了.食堂定时的.下午再聊.谢谢各位关注.指导
[夏生生][x_s_s_1]生无可恋 11:52:47
测试下
[pzweng][pzweng]路人 11:52:50
你试试看
[VBALISPER]恐龙 11:53:09
好的
[pzweng][pzweng]路人 11:54:47
(3 1 3 8 2 5 9 3 2 9 5 1 5 5 9 0 5 6 7 9 2 3 3 8 8 2 0 8 3 4 9 6 8 9 7 0 3 6 3 3 8 3 7 8 9 4 6 1 7 7 0 2 1
 楼主| 发表于 2013-7-11 12:13:35 | 显示全部楼层
[stoyer][stoyer] 12:13:35
请问各们老大,自定义菜单怎么和自己写的lisp命令链接起来?
比如我有两个命令,AA1 ,AA2;哪位老大能给个范本啊?
 楼主| 发表于 2013-7-11 12:36:19 | 显示全部楼层
[邹锋]Tony 12:36:19
谁有秋枫打印源码
 楼主| 发表于 2013-7-11 14:01:45 | 显示全部楼层
[hutong]死胡同 14:01:45
[qqimg]201307/{BD3DE564-8A94-B769-82D5-7F0CCE90C2D9}.jpg[/qqimg]
川G-胡同(331871107)  14:00:34
如何通过中间的注记15 获取到外面的封闭多段线..求给个思路
[gtj116600]轶凡 14:03:55
boundary
hatch
[农]老农 14:10:19
各位  请问CAD中有的图块用getboundingbox无法获取外框尺寸时,有何办法解决?
 楼主| 发表于 2013-7-11 15:25:31 | 显示全部楼层
[yarp]潜水 15:25:31
请教一下,cad浮点精度的有效位数是多少位啊?(不是指显示出来的)
[pzweng][pzweng]路人 15:27:21
16吧
[yarp]潜水 15:30:56
谢谢。
 楼主| 发表于 2013-7-11 15:48:23 | 显示全部楼层
[leyouyou001]youyou 15:48:23
大师们,有没有测量线段,直接把线段的长度文字标注在线段上呀
[hutong]死胡同 15:48:46
注记吧.
d
[leyouyou001]youyou 15:49:07
有吗
[vormittag]桔子 15:49:18
这是最简单的编程练习了。
[leyouyou001]youyou 15:49:34
[leyouyou001]youyou 15:52:27
谁给搞一个呀
[tryhi]大海 15:53:23
[qqimg]201307/{972A43C1-3E99-C8D2-0CF8-260F38DFA393}.jpg[/qqimg]
谁知道这个东西怎么弄出来的,在CASS里面
[VBALISPER]恐龙 15:53:59
生无可恋,你的代码我试了,很好.正在看各句的含义.
[夏生生][x_s_s_1]生无可恋 15:55:29
[VBALISPER]恐龙 15:56:40
是将表倒置后,逐位重新组表哈,省去了替换的过程,速度快了很多.
[夏生生][x_s_s_1]生无可恋 15:57:19
算法还不是很好,判断太多
您根据这个思路再优化一下吧
[VBALISPER]恐龙 15:57:59
好的.谢谢了
[夏生生][x_s_s_1]生无可恋 15:58:07
不客气
[夏生生][x_s_s_1]生无可恋 15:58:44
优化cond部分
[VBALISPER]恐龙 15:59:36
你写的,差不多也是很优的了.
 楼主| 发表于 2013-7-11 16:14:23 | 显示全部楼层
[xiaomm09]江湖 16:14:23
[AMKYUD]??? 在否?
[cmbcmbcjh]兮兮 16:14:37
线条line 显示有宽度,改那个变量?
[pzweng][pzweng]路人 16:15:04
lineweigth
[cmbcmbcjh]兮兮 16:15:22
谢谢
[xiaomm09]江湖 16:15:30
你发的递归的视频 是 郝斌的C语言里面的吗?怎么编号从50几开始的?
[pzweng][pzweng]路人 16:15:36
LWDISPLAY
[lisp-study]jun 16:17:39
我写的东西在08以前的版本都没问题  在2010中就出问题了 请问2010有哪些不一样的么
[csc123456]顽强 16:17:51
哪位有现成的比较好用的PDF虚拟打印机发个给我呀,谢谢啦!
方便的话,发个离线,多谢啦!
[hutong]死胡同 16:19:29
PDFfactory
[tryhi]大海 16:21:38
请问一下arcgis怎么转成CAD格式的,想把某一字段也一块转换成标注
[小伟jeny]小伟 16:24:01
先转成anno
在exporttocad
[cmbcmbcjh]兮兮 16:25:49
[qqimg]201307/{81519470-6916-B48A-3C8C-86FB00BA332C}.jpg[/qqimg]
[csc123456]顽强 16:29:50
谢谢 可恋
[tryhi]大海 16:36:08
请问小伟
@[小伟jeny]小伟
[qqimg]201307/{4C0D8B81-31DE-B5C2-AF3D-78D7C1F6530E}.jpg[/qqimg]
这里是灰色怎么弄
GMT+8, 2025-11-28 13:56 , Processed in 0.245599 second(s), 26 queries , Gzip On.
