- 积分
- 10518
- 明经币
- 个
- 注册时间
- 2002-6-3
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
发表于 2003-9-13 10:46:00
显示全部楼层
如果图纸唯一的话,那么图框应该主是图中最大的实体对象了,因而可以使用GetBoundingBox来获取最小点和最大点。
Sub Example_GetBoundingBox()
' This example creates a line in model space. It then finds the
' bounding box for the line and displays the corners of the box.
Dim startPoint(0 To 2) As Double
Dim endPoint(0 To 2) As Double
Dim lineObj As AcadLine
' Create the Line object in model space
startPoint(0) = 2#: startPoint(1) = 2#: startPoint(2) = 0#
endPoint(0) = 4#: endPoint(1) = 4#: endPoint(2) = 0#
Set lineObj = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
ZoomAll
Dim minExt As Variant
Dim maxExt As Variant
' Return the bounding box for the line and return the minimum
' and maximum extents of the box in the minExt and maxExt variables.
lineObj.GetBoundingBox minExt, maxExt
' Print the min and max extents
MsgBox "The extents of the bounding box for the line are:" & vbCrLf _
& "Min Extent: " & minExt(0) & "," & minExt(1) & "," & minExt(2) _
& vbCrLf & "Max Extent: " & maxExt(0) & "," & maxExt(1) & "," & maxExt(2), vbInformation, "GetBoundingBox Example"
End Sub |
