查看: 2064|回复: 0
緊急求救:關於 ActiveX Control 的問題?
发表于 2003-9-16 15:01:00 | 显示全部楼层 |阅读模式
不知道為什麼在我重裝Windows 2000 server系統, Microsoft VisualStudio6.0 軟件後,再打開原先寫的Arx 程式時,隻要對話框內含有ActiveX 控件。就會出現  如下提示:
“The Active X Control cannot be instantiated.”
"Control IDC-ADODC1 could not reload its state from its data saved from the lasted time the dialog editor was used ,The control will be uninitialized on the dialog."
"Control IDC_DATAGRID1 could not reload its state from its data saved from the lasted time the dialog editor was used ,The control will be uninitialized on the dialog."
不知道在哪個環節出了問題?現在本人焦急萬分,望各位救救我.該不用重裝系統吧?
GMT+8, 2025-5-15 13:33 , Processed in 0.157916 second(s), 25 queries , Gzip On.
