查看: 25069|回复: 41
[原创]边界轮廓线程序,支持line arc circle *polyline spline ellipse insert
发表于 2003-9-19 15:34:00 | 显示全部楼层 |阅读模式
;;边界轮廓线
;;最后转成pline线
(vl-load-com)
(defun c:yad_outline(/ viewpt maxmin spl2arc ss_add os cor qa ss n pt1 pt2 l_pt dis ent m)
  (defun viewpt(/ a b c d x)
    (setq b (getvar "viewsize") c (car (getvar "screensize")) d (cadr (getvar "screensize"))
          a (* b (/ c d)) x (setq x (getvar "viewctr")) x (trans x 1 2) c (list (- (car x)  (/ a 2.0)) (- (cadr x) (/ b 2.0)) 0.0)
          d (list (+ (car x) (/ a 2.0)) (+ (cadr x) (/ b 2.0)) 0.0) c (trans c 2 1) d (trans d 2 1)
    (list c d)
  (defun maxmin(lst / x n a b c d)
    (setq x (car lst) a (car x) b (cadr x) c (car x) d (cadr x) n 1)
    (repeat (max (- (length lst) 1) 0)
      (setq x (nth n lst) a (min a (car x)) b (min b (cadr x)) c (max c (car x)) d (max d (cadr x)))
      (setq n (1+ n))
    (list (list a b) (list c d))
  (defun spl2arc(ent / obj len num spt ept ss i pt1 pt2 pt3 s)
    (setq obj (vlax-ename->vla-object ent)
          len (vlax-curve-getDistAtParam obj (vlax-curve-getEndParam obj))
          num (1+ (fix (/ len dis)))
          num (if (= num 1) 2 num)
          spt (vlax-curve-getStartPoint obj)
          ept (vlax-curve-getEndPoint obj)
    (command "_.divide" ent (* 2 num))
    (setvar "cecolor" "1")
    (setq ss (ssget "_p"))
    (if (equal spt ept)
      (setq i 1)
      (setq i 0)
    (setq pt3 spt)
    (setq s (ssadd))
    (repeat num
      (setq pt2 (cdr (assoc 10 (entget (ssname ss i)))))
      (if (/= num (/ (+ i 2) 2))
        (setq pt1 (cdr (assoc 10 (entget (ssname ss (1+ i))))))
        (setq pt1 ept)
      (command "_.arc" pt3 pt2 pt1)
      (ssadd (entlast) s)
      (setq pt3 pt1)
      (setq i (+ 2 i))
    (command "_.erase" ss ent "")
    (setvar "cecolor" "188")
    s
  (defun ss_add(s1 s2 / n)
    (setq n -1)
    (repeat (sslength s1)
      (ssadd (ssname s1 (setq n (1+ n))) s2)
    s2
  (prompt "\n请选择要生成边界轮廓线的所有对象(图块轮廓要闭合):")
  (if (setq ss (ssget '((0 . "line,arc,circle,*polyline,spline,ellipse,insert"))))
      (command "_.undo" "_be")
      (setq os (getvar "osmode")
            cor (getvar "cecolor")
            qa (getvar "qaflags")
      (setvar "osmode" 0)
      (setvar "cmdecho" 0)
      (setq n -1)
      (repeat (sslength ss)
        (vla-getboundingbox (vlax-ename->vla-object (ssname ss (setq n (1+ n)))) 'pt1 'pt2)
        (setq l_pt (append l_pt (list (vlax-safearray->list pt1) (vlax-safearray->list pt2))))
      (setq l_pt (maxmin l_pt)
            pt1 (car l_pt)
            pt2 (cadr l_pt)
            dis (/ (distance pt1 pt2) 20)
            pt1 (polar pt1 (angle pt2 pt1) dis)
            pt2 (polar pt2 (angle pt1 pt2) dis)
      (setq l_pt (maxmin (append (viewpt) (list pt1 pt2))))
      (command "_.zoom" "_w" (car l_pt) (cadr l_pt))
      (command "_.rectang" pt1 pt2)
      (setq ent (entlast))
      (command "_.boundary" "_a" "_o" "_r" "_i" "_y" "_b" "_n" ent ss "" "" (polar pt1 (angle pt1 pt2) (/ dis 2)) "")
      (if (equal (entlast) ent)
          (entdel ent)
          (prompt "\n没有边界轮廓线!")
          (entdel ent)
          (command "_.erase" (ssget "c" pt1 pt1 '((0 . "region") (62 . 188))) "")
          (setq m 0)
          (if (setq ss (ssget "x" '((0 . "region") (62 . 188))))
              (command "_.union" ss "")
              (entmod (subst (cons 62 1) (cons 62 188) (entget (setq ent (entlast)))))
              (command "_.explode" ent)
              (if (= (cdr (assoc 0 (entget (ssname ss 0)))) "REGION")
                  (setvar "qaflags" 1)
                  (command "_.explode" ss "")
              (if (ssget "p" '((0 . "spline,ellipse")))
                  (setq dis (abs (if (setq dis (getreal "\n请输入样条曲线或椭圆的取样距离:<600>")) dis 600.0)))
                  (if (= dis 0.0) (setq dis 600.0))
              (setq n -1)
                (setq ent (ssname ss (setq n (1+ n)))
                      name (cdr (assoc 0 (entget ent)))
                (if (or (= name "SPLINE") (= name "ELLIPSE"))
                    (ssdel ent ss)
                    (setq ss (ss_add (spl2arc ent) ss))
                    (setq n (1- n))
              (setq n -1)
              (while (setq ent (ssname ss (setq n (1+ n))))
                (if (entget ent)
                    (command "_.pedit" ent "_y" "_j" ss "" "")
                    (setq m (1+ m))
          (if (setq ss (ssget "x" '((0 . "*polyline") (62 . 188))))
              (setq n -1)
                (entmod (subst (cons 62 1) (cons 62 188) (entget (ssname ss (setq n (1+ n))))))
              (setq m (+ m (sslength ss)))
          (if (= m 0)
            (prompt (strcat "\n生成" (itoa m) "条边界轮廓线!"))
      (setvar "osmode" os)
      (setvar "cecolor" cor)
      (setvar "qaflags" qa)
      (command "_.undo" "_e")
(prompt "\n***边界轮廓线yad_outline***  YAD建筑")
请教你这句话的意思: 样条曲线或椭圆的取样距离:<600> 我测试是样条曲线转为多线时的点位密度不同,取1是太密还慢,但取600就快但所出线条,并且再大值,所出的密度都是一样的. 请教大师这个数据的意思具体是什么   发表于 2014-2-28 09:20
发表于 2022-6-24 17:12:32 | 显示全部楼层
这几天在测试这个程序,刚开始的时候在CAD2014里面测试还是没有问题的,但是后来不知怎地,程序出现了问题,然后一直提示:
已提取 2 个环。
已创建 2 个面域。
BOUNDARY 已创建 2 个面域
无效的选项关键字。
; 错误: 函数被取消
输入选项 [闭合(C)/合并(J)/宽度(W)/编辑顶点(E)/拟合(F)/样条曲线(S)/非曲线化(D)/线型生成(L)/反转(R)/放弃(U)]:
将程序放在CAD2015中测试又没有问题,真是起来怪了。
经过各种测试后发现了出现这种问题的原因是系统变量的问题,通过反查PEDIT命令得知:
如果 PEDITACCEPT 系统变量设定为 1,将不显示该提示,选定对象将自动转换为多段线。
也就是说我的这个系统变量不知何时被设置成了1,导致源代码:
这句中的关键字”Y"无效,所以才出现了命令行中“无效的选项关键字。”的提示。
更改建议是,先将该系统变量用变量记录下来,然后将其设置为0,然后这段程序结束后,在恢复成原来的系统变量:
(setq peacpt (getvar "PEDITACCEPT"))
(setvar "PEDITACCEPT" 0)
(setvar "PEDITACCEPT" peacpt)
如下图:
发表于 2020-8-19 12:21:36 | 显示全部楼层
BDYCAD 发表于 2003-9-20 08:56
我自己很久以前寫了一個,不知適不適合你.試試看.呵呵
(defun c:ee (/ a)
能改一下吗?判断连接后的线是否闭合,在命令行给出提示。谢谢!
发表于 2003-9-19 16:38:00 | 显示全部楼层
好東東.支持.你有腦總比我的好使.
          我想變成SPLINE的.改改看.
我愛CAD.
发表于 2003-9-19 16:56:00 | 显示全部楼层
我剛剛用了很傻的辦法將這個PLINE變成SPLINE.就是在程序結束后加上
(Command "pedit" "l" "s" "")
可是有尖角的地方變成圓角了.不知高明的做法是如何的.請教樓主一二了.
我愛CAD
 楼主| 发表于 2003-9-19 19:27:00 | 显示全部楼层
你转成spline线肯定会这样的,你见过有尖角的spline线吗?
发表于 2003-9-19 21:11:00 | 显示全部楼层
lyy你好,我想請你幫我寫一個自動串接的命令.謝謝!!!
发表于 2003-9-20 08:56:00 | 显示全部楼层
(defun c:ee (/ a)
  (setq a (entsel "\nPlease select object the line or arc of pedit:"))
  (command "pedit" a "" "J" "all" "" "")
  (princ "\nYou are OK")
  (setvar "cmdecho" 1)
;;;不能對付SPLINE \ ELLIPSE
我愛CAD, 多多指教.
发表于 2003-9-20 09:02:00 | 显示全部楼层
不知樓主能不能在生成的PLINE可以轉出SPLINE,而且不會變形.就算會變形.在有尖角的地方不要變形得太離普的程序來用用.晚輩的功力現在有限,所以我目前做不到,還請各位高人不吝指教.謝謝啦.
我愛CAD  曾經為CAD而瘋狂
发表于 2005-10-15 09:34:00 | 显示全部楼层
好东东.支持.你有脑总比我的好使
发表于 2008-8-7 12:45:00 | 显示全部楼层
很好的东东,但是有时也用不了,
GMT+8, 2025-5-14 05:52 , Processed in 0.213357 second(s), 30 queries , Gzip On.
