查看: 1542|回复: 1
[求助]请教这是为什么呢?多多帮助。
发表于 2003-9-19 17:28:00 | 显示全部楼层 |阅读模式
(defun c:uxing()
  (setq s (ssget))
  (setq num (sslength s))
  (setq n 0)
  (setq ilistx nil)
  (setq ilisty nil)
  (repeat num
    (setq llast (ssname s n))
    (if (= (ascii(cdr(assoc 0 (entget llast))))(ascii "LWPOLYLINE"))
     (jx llast)
     (setq ilistx (cons  ix ilistx))
     (setq ilisty (cons  iy ilisty))
   (defun jx(as /)
   (princ "請選取一個矩形吧:")
  ;(SETQ AS (car A))
(setq ac (ENTGET AS))
;(setq AF (CDR (ASSOC 10 Ac)))
  (setq n 0)
  (setq sidian nil)
  (while (setq pand (assoc 10 ac))
      (setq jieduan (member pand ac))
      (setq one (cdr pand))
      (setq ac (cdr jieduan))
      (setq sidian (cons one sidian))
  ;;;;;;  get the resault   H  AND  B
  ;(if(eq (caar sidian)
  (setq n 1)
  ;(setq h  sidian)
  (repeat (- (length sidian) 1)
   (setq num (nth n sidian))
    (if (= (caar sidian) (car num))
      (setq h (abs(- (cadar sidian)(cadr num))))
      ;(setq h1 (distance (car sidian) num))
      ;;(setq h1 (abs(- (rtos(cdr one))(rtos (cdr num)))))
      (if (= (car(cdr(car sidian))) (cadr num))
      (setq b (abs(- (caar sidian)(car num))))
    (setq n (1+ n))
  ;/*(setq f  sidian)
;  (setq n 1)
; (repeat (- (length sidian) 1)
;    (setq num (nth n f))
;   (if (= (cadar sidian) (cadr num))
  ;    (setq b (abs(- (caar sidian)(car num))))
      ;(setq b1 (distance (car sidian) num))
; (setq n (1+ n))
  ;(SETQ b (distance one tow)) ;; ; 這是矩形的長度
  ;(setq h (distance one fou)) ;; ; 這是矩形的寬度
  (princ(strcat "\n""矩形的X跨度:"(rtos b)"\n"))
  (princ(strcat "矩形的Y跨度:"(rtos h)"\n"))
  (princ "\n")
  ;(princ h1)
  ;(princ (strcat"
;;;;(princ "矩形的長度="  (rtos b)))
; (princ (strcat"
;;;(princ "矩形的宽度="  (rtos h)))
  (setq ix (/(* (* h h h) b)12))
  (setq iy (/(* (* b b b) h)12))
  (princ(strcat"惯性矩的值: X:" (rtos ix)"\n"))
  (princ(strcat"惯性矩的值: Y:" (rtos iy)"\n"))
 楼主| 发表于 2003-9-19 17:29:00 | 显示全部楼层
问该判别式只能对矩形符合条件。能够计算惯性矩,怎么多义线不能够正确计算返回 0呢
请查看以下程序是否有误
(defun c:uxing()
  (setq s (ssget))
  (setq n 0)
  (setq ilistx nil)
  (setq ilisty nil)
  (repeat num
     (jx llast)
   (defun jx(as /)
   (princ "請選取一個矩形吧:")
  ;(SETQ AS (car A))
  (setq n 0)
  (setq sidian nil)
  (setq n 1)
  ;(setq h  sidian)
    (setq n (1+ n))
  ;/*(setq f  sidian)
;  (setq n 1)
; (setq n (1+ n))
  (princ "\n")
  ;(princ h1)
  ;(princ (strcat"
; (princ (strcat"
GMT+8, 2025-7-20 04:23 , Processed in 0.183932 second(s), 25 queries , Gzip On.
