查看: 2101|回复: 9
[源码] (悬赏50币)求修改langjs大师的《相同刷》刷图块不改变被刷图块的的方向!!!
发表于 2013-7-26 10:17:12 | 显示全部楼层 |阅读模式
悬赏币,我另外开贴领取(实在不好意思),偶实在是弄不来,求各位高手帮帮忙吧,小弟先谢了
真心希望langjs大师的《相同刷》刷图块时保持被刷图块的的方向,谢谢!!!
  经常做好的图图块已经被旋转了方向,需要刷部分块,所以希望刷块之后,图块保持和被刷之前的方向。
例如下图:
发表于 2013-7-26 22:39:18 | 显示全部楼层
都公开源程序了,只需要改一下变量就行了,自己动手试试
 楼主| 发表于 2013-7-26 22:57:59 | 显示全部楼层
俺实在是不会啊,麻烦高手帮忙改一个嘛
谢谢!!!
 楼主| 发表于 2013-7-26 22:58:33 | 显示全部楼层
俺实在是不会啊,麻烦高手帮忙改一个嘛,真的很需要
谢谢!!!
 楼主| 发表于 2013-7-27 10:58:10 | 显示全部楼层
麻烦高手们些帮忙改一下嘛,小弟确实搞不懂啊,先谢谢了!!!
发表于 2013-7-27 19:58:43 | 显示全部楼层
(defun c:xts (/ #errxts $orr buk en1 ent i name name1 snap ss tp ty uu)
  (defun #errxts (s)         ; 出错处理程序
    (redraw name 4)
    (setvar "nomutt" 0)
    (setvar "PICKBOX" buk)
    (setvar "osmode" snap)
    (command ".UNDO" "E")
    (setq *error* $orr)
  (setq $orr *error*)
  (setq *error* #errxts)
  (vl-load-com)          ; 主程序开始
  (setvar "cmdecho" 0)
  (command ".UNDO" "BE")
  (setq snap (getvar "osmode"))
  (setvar "osmode" 0)
  (setq buk (getvar "PICKBOX"))
  (setvar "PEDITACCEPT" 1)        ; 下面程序选择合适的源对象,如没选到重新选
  (while (not (and
  (setq name1 (nentsel "\n选择源对象:"))
  (setq name (car name1))
  (setq ent (entget name))
  (setq ty (cdr (assoc 0 ent)))
  (member ty '("TEXT" "MTEXT"
    "LWPOLYLINE" "CIRCLE"
    "INSERT" "LINE"
    "ARC" "HATCH"
    "DIMENSION" "ATTRIB"
    "TCH_ARROW" "TCH_TEXT"
    "TCH_DRAWINGNAME" "TCH_MULTILEADER"
    "TCH_ELEVATION"
    (if (= 52 (getvar "errno"))
      (vl-exit-with-error "")
  )           ; 下面程序加了一个判断,如果源对象选择的是块,且不是属性或者块内文字,则认为选择的是块
  (if (and
(not (member ty '("TEXT" "MTEXT"
        "ATTRIB"
(= (type (car (last name1))) 'ename)
(= (cdr (assoc 0 (entget (car (last name1))))) "INSERT")
    (setq name (car (last name1))
   ent (entget name)
  (redraw name 3)
  (setvar "nomutt" 1)
  (setvar "PICKBOX" (fix (+ 1 (* 1.2 buk))))
  (cond           ; 1、 如果源对象是文字、天正文字或者块内文字或者属性,则执行。。。
    ((member ty '("TEXT" "MTEXT"
       "ATTRIB" "TCH_TEXT"
       "TCH_ARROW" "TCH_DRAWINGNAME"
       "TCH_MULTILEADER" "TCH_ELEVATION"
      (setq uu (cdr (assoc 1 ent)))
      (princ (strcat "\n选择目标对象:<文字相同>  T = " "\"" uu "\""))
      (while t
(setq ss (ssget ":S" '((0 . "TEXT,MTEXT,INSERT,TCH_ARROW,TCH_TEXT,TCH_DRAWINGNAME,TCH_MULTILEADER,TCH_ELEVATION"))))
(if (= (caar (setq name1 (ssnamex ss 0))) 1) ; 如果目标文字是单选块内文字或者属性或普通文字,则执行。。。
     (setq ent (ssname ss 0)
    en1 (car (nentselp (trans (cadr (last (car name1))) 0 1)))
    tp (cdr (assoc 0 (entget en1)))
     (cond
       ((member tp '("TEXT" "MTEXT"
   "ATTRIB"
  (vla-put-textstring (vlax-ename->vla-object en1) uu)
  (entupd en1)
  (entupd ent)
       ((member tp '("TCH_TEXT" "TCH_ELEVATION"
   "TCH_ARROW"
  (vlax-put-property (vlax-ename->vla-object en1) 'text uu)
       ((= tp "TCH_DRAWINGNAME")
  (vlax-put-property (vlax-ename->vla-object en1) 'nametext uu)
       ((= tp "TCH_MULTILEADER")
  (vlax-put-property (vlax-ename->vla-object en1) 'uptext uu)
   (progn         ; 如果目标文字多选的是普通文字,则循环更新文字内容
     (repeat (setq i (sslength ss))
       (setq ent (entget (setq en1 (ssname ss (setq i (1- i))))))
       (setq tp (cdr (assoc 0 ent)))
       (cond
  ((member tp '("TEXT" "MTEXT"))
    (entmod (subst
       (cons 1 uu)
       (assoc 1 ent)
       ent
     "TCH_ARROW"
    ((member ty '("CIRCLE" "ARC"))     ; 3、 如果源对象是圆,则循环更新目标圆的直径
      (setq uu (cdr (assoc 40 ent)))
      (princ (strcat "\n选择目标对象:<半径相同>  R = " (rtos uu 2 2)))
      (repeat (setq i (sslength (setq ss (ssget '((0 . "CIRCLE,ARC"))))))
(setq ent (entget (ssname ss (setq i (1- i)))))
(entmod (subst
    (cons 40 uu)
    (assoc 40 ent)
    ent
    ((= ty "INSERT")         ; 4、 如果源对象是块,则拷贝源块到目标块的位置,删除目标块
      (princ " \n选择目标对象:<块相同>")
      (setq uu (cdr (assoc 10 ent)))
      (repeat (setq i (sslength (setq ss (ssget '((0 . "INSERT"))))))
        (setq ent_ang (cdr (assoc 50 ent)))
;;;        (setq ent_sc (cdr (assoc 41 ent)))
;;;        (command ".insert" (cdr (assoc 2 ent))(cdr (assoc 10 ent)) (cdr (assoc 41 ent)) (cdr (assoc 42 ent)) (cdr (assoc 43 ent)) (/ (* 180 (cdr (assoc 50 ent))) pi))
(command "COPY" name "" uu (cdr (assoc 10 ent)))
        (setq new_insert (entlast))
        (setq new_dat (entget new_insert))
        (entmod (subst (cons 50 ent_ang) (assoc 50 new_dat)new_dat))
      (command "ERASE" ss "")
    ((= ty "LWPOLYLINE")        ; 5、 如果源对象是多义线,则转化目标对象的线宽
      (if (not (setq uu (cdr (assoc 43 ent))))
      (princ (strcat "\n选择目标对象:<线宽相同>   W = " (rtos uu 2 2)))
      (repeat (setq i (sslength (setq ss (ssget '((0 . "LINE,ARC,POLYLINE,LWPOLYLINE,CIRCLE"))))))
(setq name1 (ssname ss (setq i (1- i)))
       tp (cdr (assoc 0 (setq ent (entget name1))))
(cond
   ((member tp '("LINE" "ARC"))
     (command "pedit" name1 "w" uu "x")
   ((member tp '("POLYLINE" "LWPOLYLINE"))
   ((= tp "CIRCLE")
     (command "donut" (- (* (cdr (assoc 40 ent)) 2) uu) (+ (* (cdr (assoc 40 ent)) 2) uu) (cdr (assoc 10 ent)) "")
     (entdel name1)
    )           ; 6、其他的一些情况,则调用特性匹配命令
    ((member ty '("LINE" "HATCH"
       "DIMENSION"
      (princ "\n选择目标对象:<特性匹配>")
      (command "matchprop" name (ssget (list (cons 0 ty))) "")
  (redraw name 4)
  (setvar "nomutt" 0)
  (setq *error* $orr)
 楼主| 发表于 2013-7-28 21:44:28 | 显示全部楼层
  (defun #errxts (s)        ...
非常感谢版主的热心关注,现在终于可以不改变被刷块的方向了。
1、不过“增强属性块”的文字的方向同被刷块方向一致就更好了,例如下图:
2、输入命令显示如下(可否麻烦版主弄成简体中文,这个确实有点看不懂啊):
命令: xts
閫夋嫨婧愬黡?
閫夋嫨鐩爣瀵硅薄:<鍧楃浉鍚
3、另 请教下我保存为最后一种格式不知道是否正确,主要是前面几种格式我加载都出现错误啊
麻烦版主再修改一下嘛,谢谢了!!!
发表于 2013-7-28 22:52:43 | 显示全部楼层
如果想用这个程序来改的话还不如重新写一个,改这个的工作量太大了
发表于 2025-5-14 14:36:24 | 显示全部楼层
电气专业的吗
GMT+8, 2025-6-24 04:17 , Processed in 0.182789 second(s), 26 queries , Gzip On.
