查看: 2421|回复: 0
[OpenDCL] OPENDCL有没有办法获得所有的NAME值?
发表于 2013-8-2 22:58:45 | 显示全部楼层 |阅读模式
OPENDCL中每个对话框的每个控件都有一个NAME值,有没有办法实现获取所有NAME值,或者是varname值;
Name
Friendly Name
Name
API Name
Name
Type
String
Restrictions
Must be unique within container
Get Function
(dcl_Control_GetName <CONTROL>)
Set Function
N/A
Applies To
All Controls and Forms
Every form in a project, and every control on a form must have a unique name. When a new control is added to a form, it is assigned an automatically generated unique name, however the name may be changed to something more meaningful if desired.
VarName
Friendly Name
VarName
API Name
VarName
Type
String
Restrictions
Get Function
N/A
Set Function
N/A
Applies To
When an instance of a form or control is created, OpenDCL sets the value of an AutoLISP variable to a handle for the control. This handle can be used as a reference to the control when calling OpenDCL functions. If the VarName property is not empty, its value is used as the AutoLISP variable name. If the VarName property is empty, the AutoLISP variable name is generated automatically in the form <project-key>_<form-name>_<control-name> to ensure a unique symbol name.
GMT+8, 2025-11-27 04:06 , Processed in 0.177768 second(s), 28 queries , Gzip On.
