- 积分
- 10393
- 明经币
- 个
- 注册时间
- 2009-9-1
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
图一
图二
图三
程序:
(defun c:QQ ()
(command "layer" "LO" "*" "")
(command "layer" "U" "AC" "U" "AM" "U" "Af" "")
(command "copy" "ALL" "" "0,0" "500,2000");上模座
(command "layer" "U" "Uf" "U" "UM" "U" "UC" "LO" "AC" "LO" "AM" "LO" "AF" "")
(command "copy" "ALL" "" "0,0" "500,1500");上垫板
(command "layer" "U" "Hf" "U" "HM" "U" "HC" "LO" "UC" "LO" "UM" "LO" "UF" "")
(command "copy" "ALL" "" "0,0" "500,1000");固定板
(command "layer" "U" "Kf" "U" "KM" "U" "KC" "LO" "HC" "LO" "HM" "LO" "HF" "")
(command "copy" "ALL" "" "0,0" "500,500");止高板
(command "layer" "U" "Sf" "U" "SM" "U" "SC" "LO" "KC" "LO" "KM" "LO" "KF" "")
(command "copy" "ALL" "" "0,0" "500,0");脱料板
(command "layer" "U" "Tf" "U" "TM" "U" "TC" "LO" "HC" "LO" "HM" "LO" "HF" "")
(command "copy" "ALL" "" "0,0" "500,500");中空板
(command "layer" "U" "Df" "U" "DM" "U" "DC" "LO" "TC" "LO" "TM" "LO" "TF" "")
(command "copy" "ALL" "" "0,0" "500,0");凹模板
(command "layer" "U" "Bf" "U" "BM" "U" "BC" "LO" "DC" "LO" "DM" "LO" "DF" "")
(command "copy" "ALL" "" "0,0" "500,-500");下垫板
(command "layer" "U" "Zf" "U" "ZM" "U" "ZC" "LO" "DC" "LO" "DM" "LO" "DF" "")
(command "copy" "ALL" "" "0,0" "500,-500");下脱板
(command "layer" "U" "Wf" "U" "WM" "U" "WC" "LO" "ZC" "LO" "ZM" "LO" "ZF" "")
(command "copy" "ALL" "" "0,0" "500,-1000");下夹板
(command "layer" "U" "Lf" "U" "LM" "U" "LC" "LO" "WC" "LO" "WM" "LO" "WF" "")
(command "copy" "ALL" "" "0,0" "500,-1500");下模座
(command "layer" "U" "Pf" "U" "PM" "U" "PC" "LO" "LC" "LO" "LM" "LO" "LF" "")
(command "copy" "ALL" "" "0,0" "1000,500");冲子层
(command "layer" "U" "Rf" "U" "RM" "U" "RC" "LO" "PC" "LO" "PM" "LO" "PF" "")
(command "copy" "ALL" "" "0,0" "1000,500");打料板
(command "layer" "U" "Qf" "U" "QM" "U" "QC" "LO" "RC" "LO" "RM" "LO" "RF" "")
(command "copy" "ALL" "" "0,0" "1000,0");内脱板
(command "layer" "U" "Nf" "U" "NM" "U" "NC" "LO" "QC" "LO" "QM" "LO" "QF" "")
(command "copy" "ALL" "" "0,0" "1000,-500");入块层
(command "layer" "U" "*" "")
请问高手们,输入QQ命令后
,提示:
请选取图框左下角点
请选取图框右上角的点
请确定分离位置点
根据图框大小,实现图三效果图,每个图框间距为50mm,请高手们指点迷津,谢谢
