 - (defun ddzb (e / befor_xy el en_list group_xy i m)
- (setq el (entget e))
- (setq Befor_xy (member (assoc 10 el) el))
- (setq Group_xy (reverse (member (assoc 42 (reverse Befor_xy))
- (reverse Befor_xy)
- (setq i 0)
- (setq M_list nil)
- (repeat (length Group_xy)
- (setq M_list (append
- M_list
- (list (cdr (nth i Group_xy)))
- (setq i (+ i 4))
- (setq En_list (vl-remove nil (setq M_list M_list)))
- (print En_list)
- (princ)
- ;;;以上为收集单条多段线顶点坐标函数
- (defun c:sjzb ( / ff i ls n n_e num ss xy)
- (if (setq ss (ssget '((0 . "LWPOLYLINE"))))
- (progn
- (setq ff (open "c:/多段线顶点坐标.txt" "w"))
- (setq n 0)
- (repeat (sslength ss)
- (setq n_e (ssname ss n)) ;;;;;;;;;;;;;;;;;;;;;
- (setq xy (ddzb n_e)) ;;;此处为何不能为xy赋值?;;;
- (setq i (+ n 1)) ;;;;;;;;;;;;;;;;;;;;;
- (setq num (itoa i))
- (setq ls (strcat num ",," xy))
- (write-line ls ff)
- (setq n (+ n 1))
- (close ff)
- (prompt "坐标已导出到c:\根目录下")
- (prin1)
