查看: 2100|回复: 4
[资源] 数据库连接函数ADOLISP,目前测试32位CAD可用(系统32位和64位均可)
发表于 2013-8-25 11:38:58 | 显示全部楼层 |阅读模式
[pcode=lisp,true]
;;; An example of using ADOLISP_Library.lsp
(if (not ADOLISP_ConnectToDB)
  (load "ADOLISP_Library.lsp")
(defun C:Example (/ ConnectionObject Result ConnectString SQLStatement
                  TablesList ColumnsList
  ;; Connecting to the database ...
  (setq ConnectString
         "Provider=MSDASQL;Driver={Microsoft Access Driver (*.mdb)};DBQ=C:\\CAD\\ADOLISP_test.mdb"
  ;; An alternative connect string
  ;(setq ConnectString "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\\CAD\\ADOLISP_test.mdb;Persist Security Info=False")
  (setq ConnectString "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=C:\\CAD\\ADOLISP_test.accdb;Persist Security Info=False")
  (prompt (strcat "\n\nConnecting to the database using \n\""
                  ConnectString
  (if (not (setq ConnectionObject
                  (ADOLISP_ConnectToDB ConnectString "admin" "")
      (prompt "\nConnection failed!")
      (ADOLISP_ErrorPrinter)
    (prompt "\nResult: succeeded!")
  ;; If we got a connection ...
  (if ConnectionObject
      ;; Retrieve some data
      (setq
        SQLStatement "SELECT * FROM DESKS WHERE AutoCAD_HANDLE = '2A'"
      (prompt
        (strcat
          "\n\nExecuting a SELECT statement to retrieve some data:\n\""
          SQLStatement
      (if (setq Result (ADOLISP_DoSQL ConnectionObject SQLStatement))
          (prompt "\nResult: ")
          (print Result)
          (prompt "\nFailed!")
      ;; Insert a row
      (setq SQLStatement
             "INSERT INTO DESKS (AUTOCAD_HANDLE, AUTOCAD_DRAWING, OCCUPANT, EXTENSION, PROPERTY_NUMBER) VALUES ('ABCDEF00', 'TESTDRAWING', 'Barbara', '123456', '654321')"
      (prompt (strcat "\n\nInserting a row:\n\""
                      SQLStatement
        (prompt "\nResult:\nSucceeded!")
      ;; Change a row or rows
      (setq SQLStatement
             "UPDATE DESKS SET OCCUPANT='Me' WHERE AUTOCAD_DRAWING='TESTDRAWING'"
      (prompt (strcat "\n\nChanging a row or rows:\n\""
                      SQLStatement
      ;; Delete a row or rows
      (setq SQLStatement
             "DELETE FROM DESKS WHERE AUTOCAD_DRAWING='TESTDRAWING'"
      (prompt (strcat "\n\nDeleting a row or rows:\n\""
                      SQLStatement
      ;; Just for grins, see what's in the database
      (prompt "\n\nTables and views in the database:")
      (setq TablesList (ADOLISP_GetTablesAndViews ConnectionObject))
      (print (ADOLISP_GetTablesAndViews ConnectionObject))
      (prompt (strcat "\n\nColumn properties in table "
                      (caar TablesList)
      (setq ColumnsList
             (ADOLISP_GetColumns
               ConnectionObject
               (caar TablesList)
      (foreach Item ColumnsList
        (print Item)
      ;; Disconnect
      (prompt "\n\nDisconnecting from the database\n")
      (ADOLISP_DisconnectFromDB ConnectionObject)
      ;; Although the following is unnecessary in this case (because
      ;; ConnectionObject is a local variable), it's never a _bad_
      ;; idea to NIL-out the connection object.
      (setq ConnectionObject nil)
  (prin1)
(prin1)
[/pcode]
发表于 2013-8-25 14:22:42 | 显示全部楼层
个别电脑安装数据库引擎.
发表于 2013-8-25 19:26:11 来自手机 | 显示全部楼层
这个太深了,楼主多给大家举点例吧!
发表于 2013-8-26 18:23:46 | 显示全部楼层
刚刚接触ADOLISP。
发表于 2015-9-2 13:46:49 | 显示全部楼层
正在找,谢谢楼主分享
GMT+8, 2025-5-21 10:11 , Processed in 0.234024 second(s), 26 queries , Gzip On.
