查看: 1671|回复: 4
[基础] 有关 ssget的问题?
发表于 2013-8-28 23:09:55 | 显示全部楼层 |阅读模式
请教下列程序是否为最后二段有问题?
文字写不出来
请各位帮看看
谢谢!
;;文字结合
(defun C:tt (/)
  (setvar "CMDECHO" 0)
  (if (not (tblsearch "style" "001"))
    (command "style" "001" "romans,ae" "" "0.8" "10" "" "" "")
  ;;end if
  (if (not (tblsearch "style" "002"))
    (command "style" "002" "romans,ae" "" "0.8" "10" "" "" "")
  ;;end if
  (if (not (tblsearch "style" "003"))
    (command "style" "003" "romans,ae" "" "0.8" "10" "" "" "")
  ;;end if
  (setq p001 (getpoint "\n txt point:"))
  (setq p1 (getpoint "\n p1:"))
  (setq p2 (getcorner p1 "\n p2:"))
  (setq ss1 (ssget "c" p1 p2 '((0 . "TEXT") (7 . "001"))))
  (setq len1 (sslength ss1))
  (setq n1 0)
  (setq ent1 (ssname ss1 n1))
  (setq ent1txt (cdr (assoc 1 (entget ent1))))
  (setq ss2 (ssget "c" p1 p2 '((0 . "TEXT") (7 . "002"))))
  (setq len2 (sslength ss2))
  (setq n2 0)
  (setq ent2 (ssname ss2 n2))
  (setq ent2txt (cdr (assoc 1 (entget ent2))))
  (setq ss3 (ssget "c" p1 p2 '((0 . "TEXT") (7 . "003"))))
  (setq len3 (sslength ss3))
  (setq n3 0)
  (setq ent3 (ssname ss3 n3))
  (setq ent3txt (cdr (assoc 1 (entget ent3))))
(setq txtps (strcat ent1txt ent2txt ent3txt))
(command "text" p001 "" "" txtps "")
再次向各位请教如上述程序中
(setq txtps (strcatent1txt ent2txt ent3txt))
Txtps 由上述3种字抓出而结合写成
ssget 在选不到字型会出现程序出错
选择范围中 仅有  001 003 字型
有什么方式能在选不到002 字型的状况下而程序又不会中断?
如可行,程序该如何修正?
谢谢!!
发表于 2013-8-28 23:13:15 | 显示全部楼层
(setq ent3txt (cdr (assoc 3 (entget ent3))))
改为
谢谢指导!! 偷懒用copy的忘了改找寻 dxf码的值 检查老半天一直没注意到那!!  发表于 2013-8-28 23:26
 楼主| 发表于 2013-8-29 21:57:13 | 显示全部楼层
之前问题点已解决!!
新的问题点再次询问
自顶!!
希望各位先进能再次指导一下!
谢谢!
发表于 2013-8-29 22:38:44 | 显示全部楼层
(apply 'strcat (vl-remove nil '("001" nil "003")))
 楼主| 发表于 2013-8-29 23:34:51 | 显示全部楼层
感謝 Andyhon指點!!
明天上班再試試!!
謝謝
GMT+8, 2025-5-14 00:21 , Processed in 0.179901 second(s), 30 queries , Gzip On.
