查看: 21203|回复: 71
[源码] 动态云线
发表于 2013-9-4 11:19:28 | 显示全部楼层 |阅读模式
  1. ;动态云线,初学者第一次,希望多多支持
  2. (defun c:YUN( / aa cdu ent jdu kk l msg os p0 p1 pa pb ss sss temp *error*)
  3.   (defun *error*(msg)
  4.      (setvar "cmdecho" temp)
  5.      (setvar"cecolor" ocolo)
  6.      (setvar "clayer" oldlay)
  7.      (redraw)
  8.      (if (> (setq os (getvar 'osmode)) 16383) (setvar 'osmode (- os 16384)))
  9.      (princ msg)
  10.      (exit)
  11.      (princ)
  12.      )
  13.   (setq oldlay (getvar "clayer"))
  14.   (setq temp (getvar "cmdecho"))
  15.   (setq ocolo(getvar"cecolor"))
  16.   (if(null (tblsearch "layer" "yunxian"))
  17.       (command "layer" "n" "yunxian" "c" "6" "yunxian" ""))
  18.     (setvar "clayer" "yunxian")
  19.   (setvar"cecolor" "bylayer")
  20.   (if(and(setq pa(getpoint"\n矩形第一点"))(setq pb(getcorner pa"\n矩形第二点")))
  21.   (progn(command"RECTANG" pa pb)
  22. (setq ss(entlast))(setq jdu(angle pa pb))(setq cdu(*(distance pa pb)0.99))(setq p0(polar pa jdu cdu)))
  23.   )
  24.   (setvar "cmdecho" 0)
  25. (if(not(and pa pb))(progn
  26.   ;(setq sss(entsel"选择对象"))
  27.   ;(setq p0(osnap (cadr sss) "near"))(setq ss(car sss))))
  28.   (setq sss (ssget ":E:S" '((0 . "line,LWPOLYLINE,circle,ARC,spline,ELLIPSE,"))))
  29.   (setq ss(ssname sss 0))))
  30.   (setq ent(entget ss))
  31.   (setq aa nil)
  32. (while(= 5(car(setq kk(grread T 1 0))))
  33.    (setq p1(cadr kk))
  34.    (if(= p0 nil)(setq p0(polar p1 pi 1)))
  35.    (cond ((= aa t)(entdel ss)))
  36.    (if(= aa t)(progn(entmake ent)(setq ss(entlast))))
  37.    (redraw)
  38.    (grdraw p0 p1 1)
  39.    (setq l(distance p0 p1))(setq l(/ l 2))
  40.      (if (< (setq os (getvar 'osmode)) 16384) (setvar 'osmode (+ os 16384)))
  41.    (command"_revcloud" "A" l l "o"ss"n")
  42.      (if (> (setq os (getvar 'osmode)) 16383) (setvar 'osmode (- os 16384)))
  43.    (setq ss(entlast))
  44.    (setq aa t)
  45.   )
  46.   (redraw)
  47.   (setvar"cecolor" ocolo)
  48.   (setvar "clayer" oldlay)
  49.   (setvar "cmdecho" temp)
  50.   (princ)
  51.   )
不错,但有个小缺陷,当点距过在时,有时会出错退出  发表于 2014-8-28 12:05
参与人数 3明经币 +2 金钱 +10 收起 理由
tigcat + 1 + 5 很给力!
冰之绝恋 + 5 赞一个!
自贡黄明儒 + 1 赞一个!
本帖被以下淘专辑推荐:
 楼主| 发表于 2020-5-10 15:56:06 | 显示全部楼层
yanchao316 发表于 2016-6-7 18:23
求救到底怎么做才能用啊,我复制代码在txt改成lsp出现:命令: 读入的 (八进制) 字符不正确: 0,直接转存代 ...
我上传了lsp文件,可以直接下载试试
发表于 2022-5-9 18:42:41 | 显示全部楼层
确实存在一个小bug ,选择一个已画的矩形时,会提示:无法转换对象,对象对于云的圆弧而言过大,希望楼主持续完善优化一下。
发表于 2020-5-11 22:42:54 | 显示全部楼层
52幕墙设计 发表于 2020-5-10 15:56
我上传了lsp文件,可以直接下载试试
多谢了
发表于 2013-9-4 11:25:51 | 显示全部楼层
占个沙发,多谢楼主分享源码
发表于 2013-9-4 15:03:52 | 显示全部楼层
这个不错~~~~~~~
发表于 2013-9-4 15:26:28 | 显示全部楼层
这个相当不错,值得学习
发表于 2013-9-4 21:36:20 | 显示全部楼层
这个程序不错,学习了!
发表于 2013-9-5 08:10:26 | 显示全部楼层
很实用,谢谢楼主分享
发表于 2013-9-5 09:05:39 | 显示全部楼层
这个程序不错,学习了!
发表于 2013-9-5 10:19:51 | 显示全部楼层
我喜欢这个
发表于 2013-9-5 12:49:40 | 显示全部楼层
可以增加画圆形 椭圆形……
发表于 2013-9-5 16:18:31 | 显示全部楼层
程序不错,学习了!
GMT+8, 2025-5-25 10:52 , Processed in 0.208409 second(s), 31 queries , Gzip On.
