查看: 1964|回复: 2
[提问] 请教以下这段关于全体改颜色的命令有什么错误,谢谢。
发表于 2013-9-5 17:10:20 | 显示全部楼层 |阅读模式
我在论坛搜到了以下一段关于改颜色的命令,但是有时候会出现以下错误:选择对象:  ; 错误: AutoCAD.Application: 此代理不允
不知道是什么原因,请大侠指点,谢谢。
(defun c:test (/ SS BLKS I BNLst)
  (princ "\n选择要修改颜色的对象: ")
  (if (and (setq SS (ssget))
           (or $ChColor$ (setq $ChColor$ 7))
           (setq $ChColor$ (acad_colordlg $ChColor$))
      (setq BLKS  (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
      (defun ChColor (OBJ / oName BlkName)
        (setq oName (vla-get-ObjectName OBJ))
        (cond
          ((wcmatch oName "*Dimension,AcDbLeader,AcDbFcf")
           (vla-put-DimensionLineColor OBJ $ChColor$)
           (if (wcmatch oName "*Dimension")
               (vla-put-ExtensionLineColor OBJ $ChColor$)
               (if (setq BlkName (assoc 2 (entget (vlax-vla-object->ename OBJ))))
                 (vlax-for OBJ (vla-item Blks (cdr BlkName))
                   (vla-put-color OBJ $ChColor$)
           (if (wcmatch oName "*Dimension,AcDbFcf")
             (vla-put-TextColor OBJ $ChColor$)
          ((= oName "AcDbBlockReference")
           (setq BlkName (vla-get-name OBJ))
           (if (not (member BlkName BNLst))
               (setq BNLst (cons BlkName BNLst))
               (vlax-for X (vla-item Blks BlkName)
                 (ChColor X)
           (if (= (vla-get-HasAttributes OBJ) :vlax-true)
             (foreach X (vlax-invoke OBJ 'getattributes)
               (vla-put-color X $ChColor$)
        (vla-put-color obj $ChColor$)
      (repeat (setq I (sslength SS))
        (setq OBJ (vlax-ename->vla-object (ssname SS (setq I (1- I)))))
        (ChColor OBJ)
发表于 2013-9-5 19:13:03 | 显示全部楼层
选到代理图形了吧
发表于 2013-9-5 19:28:49 | 显示全部楼层
感谢分享!  发表于 2015-6-25 11:24
GMT+8, 2025-5-26 10:26 , Processed in 0.157715 second(s), 28 queries , Gzip On.
