查看: 1381|回复: 4
[已解答] 连续复制后删除原对象
发表于 2013-9-7 10:16:55 | 显示全部楼层 |阅读模式
(defun c:m1 ()
(setq ss (ssget))
(setq p1 (getpoint "\n请输入一个角点:"))
(setq p2 (getpoint "\n请输入另一个角点:"))
(setq pc (list (/ (+ (car p1) (car p2)) 2) (/ (+ (cadr p1) (cadr p2)) 2)))
(initget 128 "Copy Move")
(setq yesno (getkword "\n复制(c)/移动(m):<c>"))
(if (or (= yesno "Copy") (= yesno nil)) (command "copy" ss "" "m" pc))
(if (= yesno "Move") (progn
  (command "erase" ss "")))
(princ))
为什么(command "erase" ss "")没有在程序中发挥作用?
发表于 2013-9-7 11:03:40 | 显示全部楼层
Try...
    (while (= 1 (getvar "cmdactive"))
      (command pause)
958620832 + 1 赞一个!
发表于 2013-9-7 11:06:38 | 显示全部楼层
  1. (defun c:m1 ()
  2.   (setq ss (ssget))
  3.   (setq p1 (getpoint "\n请输入一个角点:"))
  4.   (setq p2 (getpoint p2 "\n请输入另一个角点:"))
  5.   (setq        pc (list (/ (+ (car p1) (car p2)) 2)
  6.                  (/ (+ (cadr p1) (cadr p2)) 2)
  7.            )
  8.   )
  9.   (initget 128 "Copy Move")
  10.   (setq yesno (getkword "\n复制(c)/移动(m):<c>"))
  11.   (if (or (= yesno "Copy") (= yesno nil))
  12.     (command "copy" ss "" "m" pc)
  13.   )
  14.   (if (= yesno "Move")
  15.     (progn
  16.       (command "copy" ss "" p1 p2)
  17.       (command "erase" ss)
  18.     )
  19.   )
  20.   (princ)
  21. )
 楼主| 发表于 2013-9-7 11:36:41 | 显示全部楼层
自贡黄明儒 发表于 2013-9-7 11:06
你试过了么?成功了么?
当然试过,成功了  发表于 2013-9-7 11:52
发表于 2013-9-8 13:55:18 | 显示全部楼层
andyhon正解。程序全文如下:
(defun c:m1 ()
(setq ss (ssget))
(setq yesno (getkword "\n复制不删原对象(c)/复制后删原对象(m):<c>"))
      (command pause)
(princ))
GMT+8, 2025-5-26 09:48 , Processed in 0.168706 second(s), 27 queries , Gzip On.
