查看: 3349|回复: 6
[源码] [源码]批量绘制直线中垂线
发表于 2013-9-8 20:40:18 | 显示全部楼层 |阅读模式
;;;***********绘制直线的中垂线 程序开始************
(defun c:zcx ()
  (setvar "pickadd" 1)
  (setvar "osmode" 15359)
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (princ "\n★功能:批量绘制直线的中垂线.")
  (setq ss (ssget '((0 . "LINE"))))
  (if (null ss)
    (progn (princ "\n★提示:未选取直线!") (exit))
  (setq n (sslength ss))
  (setq i 0)
  (setvar "osmode" 0)
  (while (< i n)
    (setq entname (ssname ss i))
    (setq entdata (entget entname))
    (setq i (+ i 1))
    (setq ptqd (cdr (assoc 10 entdata)))
    (setq ptzd (cdr (assoc 11 entdata)))
    (setq dist (distance ptqd ptzd))
    (setq ang (angle ptqd ptzd))
    (setq ptqdx (car ptqd))
    (setq ptqdy (cadr ptqd))
    (setq ptzdx (car ptzd))
    (setq ptzdy (cadr ptzd))
    (setq ptzxx (/ (+ ptqdx ptzdx) 2))
    (setq ptzxy (/ (+ ptqdy ptzdy) 2))
    (setq
      pt1 (polar (list ptzxx ptzxy) (+ ang (angtof "90")) (/ dist 2))
    (setq
      pt2 (polar (list ptzxx ptzxy) (+ ang (angtof "-90")) (/ dist 2))
    (command "LAYER" "M" "中垂线" "C" "RED" "中垂线" "")
    (command "COLOR" "Bylayer")
    (command "LINE" pt1 pt2 "")
  (command "undo" "e")
;;;**************绘制直线的中垂线 程序结束**************
发表于 2014-8-20 19:28:23 | 显示全部楼层
谢谢分享。
发表于 2014-8-20 19:30:36 | 显示全部楼层
只支持直线
http://bbs.mjtd.com/thread-95149-1-1.html
发表于 2018-1-14 03:40:02 | 显示全部楼层
如果多些选择就更好了
发表于 2018-1-14 08:49:23 | 显示全部楼层
谢谢! 荒野孤行 分向程序!!!
发表于 2023-5-3 18:37:05 | 显示全部楼层
感谢分享,正好需要
GMT+8, 2025-7-18 07:54 , Processed in 0.173485 second(s), 25 queries , Gzip On.
