查看: 4929|回复: 9
[源码] 编号程序
发表于 2013-9-16 19:59:52 | 显示全部楼层 |阅读模式
1、本程序不是本人所写,也不知是哪位高人的作品,
2、程序原来明经上有的,但是后来不知为何原因帐号被封,后看到很多人找就再次发出来
3、求改进该程序  (1、加循环,2、将该程序封装成单独函数,以便其他程序可以直接调用编号,3、加详细注释,让我们这些小菜能好好学习。)在此谢谢程序的作者和修改程序的作者。
  1. ;参数初始化
  2. (defun chushihua()
  3.   ;(setvar "cmdecho" 0)
  4.   (setq bhlx 0)
  5.   (write-line "编号类型:0")
  6.   (setq bh0 0)
  7.   (write-line "编号初值:1")
  8.   (setq bh1 64)
  9.   (setq bh2 0)
  10.   (setq bh3 64)
  11.   (setq yx "Y")
  12.   (write-line "引线:Y")
  13.   (setq bklx "Y")
  14.   (write-line "边框:Y")
  15.   (setq r 2.5)
  16.   (setq zidong_r t)
  17.   (write-line "边框圆半径:自动")
  18.   (setq th 3.5)
  19.   (write-line "文字高度:3.5")
  20.   (setq ta 0)
  21.   (write-line "文字旋转角度:0")
  22.   (setq jl 1)
  23.   (write-line "编号到引线距离:1")
  24.   (setq jiantou 2.5)
  25.   (write-line "箭头大小:2.5")
  26.   (setq chang 5)
  27.   (setq zidong_chang t)
  28.   (write-line "水平段引线长度:自动")
  29.   (setq qianzhui2 "")
  30.   (write-line "自然数前缀:无")
  31.   (setq houzhui2 "")
  32.   (write-line "自然数后缀:无")
  33.   (setq qianzhui3 "")
  34.   (write-line "字母前缀:无")
  35.   (setq houzhui3 "")
  36.   (write-line "字母后缀:无")
  37.   (setq pianyi 7)
  38.   (write-line "边框自动处理时,文字到边框的偏移系数:7")
  39. )
  40. (chushihua)
  41. ;主函数*********************************************************************
  42. (defun c:sb(/ o ob)
  43.   (defun er(str)
  44.     (setvar "osmode" dx)
  45.     (princ "\nSB已取消")
  46.   )
  47.   (setq erod *error* *error* er)
  48.   (if (= yx "N")
  49.     (progn
  50.       (initget "C Y K W H T")
  51.       (setq ob (getpoint "\n指定编号位置[编号初值(C)/引线(Y)/边框(K)/文字(W)/还原为默认设置(H)/退出(T)]:<编号之前请先将当前文字样式的文字高度项设为0>"))
  52.       (if (or (= ob "C") (= ob "Y") (= ob "T") (= ob "K") (= ob "W") (= ob "H") (= ob nil))
  53.         (progn
  54.           (if (= ob "C") (chuzhi))
  55.           (if (= ob "Y") (yinxian))
  56.           (if (= ob "K") (bkshezhi))
  57.           (if (= ob "W") (wenzi))
  58.           (if (= ob "H") (chushihua))
  59.           (if (= ob nil) (gaodu0))
  60.           (if (= ob "T") (exit))
  61.         )
  62.         (progn
  63.           (huitu o ob)
  64.         )
  65.       )
  66.     )
  67.     (progn
  68.       (initget "C Y K W H T")
  69.       (setq o (getpoint "\n指定标注位置[编号初值(C)/引线(Y)/边框(K)/文字(W)/还原为默认设置(H)/退出(T)]:<编号之前请先将当前文字样式的文字高度项设为0>"))
  70.       (if (or (= o "C") (= o "Y") (= o "T") (= o "K") (= o "W") (= o "H") (= o nil))
  71.         (progn
  72.           (if (= o "C") (chuzhi))
  73.           (if (= o "Y") (yinxian))
  74.           (if (= o "K") (bkshezhi))
  75.           (if (= o "W") (wenzi))
  76.           (if (= o "H") (chushihua))
  77.           (if (= o nil) (gaodu0))
  78.           (if (= o "T") (exit))
  79.         )
  80.         (progn
  81.           (initget 1)
  82.           (setq ob (getpoint o "\n指定编号位置:"))
  83.           (huitu o ob)
  84.         )
  85.       )
  86.     )
  87.   )
  88. )
  89. ;绘制过程*********************************************************************************
  90. (defun huitu(o ob / dian1 dian2 dianx diany jiantou0 chang0)
  91.   (graphscr)
  92.   (setq jiantou0 jiantou)
  93.   (command "text" '(0 0) th ta "编号速写" "erase" (entlast) "")
  94.   ;编号升序
  95.   ;0 (1 2 3...) 1 (a b c.../A B C...) 2 (a1 a2.../B1 B2...) 3 (aa ab ac.../Ma Mb Mc...)
  96.   (if (= bhlx 0)
  97.     (progn
  98.       (setq bh0 (+ bh0 1))
  99.       (setq bh (itoa bh0))
  100.     )
  101.   )
  102.   (if (= bhlx 1)
  103.     (progn
  104.       (setq bh1 (+ 1 bh1))
  105.       (if (> bh1 122) (setq bh1 97))
  106.       (if (and (> bh1 90) (< bh1 97)) (setq bh1 65))
  107.       (if (< bh1 65) (setq bh1 65))
  108.       (if (and (< bh1 97) (> bh1 90)) (setq bh1 97))
  109.       (setq bh (chr bh1))
  110.     )
  111.   )
  112.   (if (= bhlx 2)
  113.     (setq bh (strcat qianzhui2 (itoa (setq  bh2 (+ 1 bh2))) houzhui2))
  114.   )
  115.   (if (= bhlx 3)
  116.     (progn
  117.       (setq bh3 (+ 1 bh3))
  118.       (if (> bh3 122) (setq bh3 97))
  119.       (if (and (> bh3 90) (< bh3 97)) (setq bh3 65))
  120.       (if (< bh3 65) (setq bh3 65))
  121.       (if (and (< bh3 97) (> bh3 90)) (setq bh3 97))
  122.       (setq bh (strcat qianzhui3 (chr bh3) houzhui3))
  123.     )
  124.   )
  125.   (if (= bklx "Y")       ;边框半径是否自动处理及r0值
  126.     (progn
  127.       (if (= zidong_r t)
  128.         (setq r0 (/ (tdaxiao 3) 2))
  129.         (setq r0 r)
  130.       )
  131.     )
  132.     (setq r0 (/ (tdaxiao 2) 2))
  133.   )
  134.   (if (= bklx "J")       ;边框为矩形时r0值
  135.     (if (= zidong_j t)
  136.       (setq r0 (/ (tdaxiao 2) 2))
  137.       (setq r0 (/ jgao 2))
  138.     )
  139.   )
  140.   (if (= zidong_chang t) ;引线长度是否自动处理及chang0值
  141.     (progn
  142.       (if (= bklx "Y")
  143.         (setq chang0 (* r0 2))
  144.         (progn
  145.           (if (= bklx "J")
  146.             (if (= zidong_j t)
  147.               (setq chang0 (tdaxiao 1))
  148.               (setq chang0 jkuan)
  149.             )
  150.             (if (= bklx "W")
  151.               (setq chang0 (tdaxiao 1))
  152.             )
  153.           )
  154.         )
  155.
  156.       )
  157.     )
  158.     (setq chang0 chang)
  159.   )
  160.   ;对象捕捉
  161.   (setq dx (getvar "osmode"))
  162.   (setvar "osmode" 0)
  163.   (biankuangy r0 ob bh)
  164.   (if (and (/= yx "N") (/= yx "n"))
  165.     (progn
  166.       (if (>= (car o) (car ob))
  167.         (progn
  168.           (setq dian1 (list(+ (car ob) (/ chang0 2)) (- (cadr ob) r0 jl)))
  169.           (setq dian2 (list(- (car ob) (/ chang0 2)) (- (cadr ob) r0 jl)))
  170.           (if (> jiantou0 (distance o dian1)) (setq jiantou0 0))
  171.           (setq dianx (+ (car o) (* (/ jiantou0 (distance o dian1)) (- (car dian1) (car o)))))
  172.           (setq diany (+ (cadr o) (* (/ jiantou0 (distance o dian1)) (- (cadr dian1) (cadr o)))))
  173.           (command "pline" o "w" 0 (/ jiantou0 3) (list dianx diany) "w" 0 0 dian1 dian2 "")
  174.
  175.         )
  176.         (progn
  177.           (setq dian1 (list(- (car ob) (/ chang0 2)) (- (cadr ob) r0 jl)))
  178.           (setq dian2 (list(+ (car ob) (/ chang0 2)) (- (cadr ob) r0 jl)))
  179.           (if (> jiantou0 (distance o dian1)) (setq jiantou0 0))
  180.           (setq dianx (+ (car o) (* (/ jiantou0 (distance o dian1)) (- (car dian1) (car o)))))
  181.           (setq diany (+ (cadr o) (* (/ jiantou0 (distance o dian1)) (- (cadr dian1) (cadr o)))))
  182.           (command "pline" o "w" 0 (/ jiantou0 3) (list dianx diany) "w" 0 0 dian1 dian2 "")
  183.
  184.         )
  185.       )
  186.     )
  187.   )
  188.   ;对象捕捉
  189.   (setvar "osmode" dx)
  190.   (setq *error* erod erod nil)
  191. (eval bh)
  192. )
  193. ;参数设置********************************************************************************
  194. ;初值设置
  195. (defun chuzhi(/ qianzhui20 houzhui20 qianzhui30 houzhui30)
  196.       (initget 1 "0 1 2 3")
  197.       (setq bhlx (atoi (getkword "选择一种编号类型:\n<0>  自然数序列(1 2 3...)  <1>  字母序列(a b c.../A B C...)  <2>  带前/后缀自然数序列(a1 a2.../B1 B2.../(1)...)  <3>  带前/后缀字母序列(aa ab ac.../Ma Mb Mc.../(a)...)  选择其中一种0/1/2/3:")))
  198.       (if (= bhlx 0)
  199.         (progn
  200.           (setq bh0 (getint "\n输入起始数值:<1>"))
  201.           (if (= bh0 nil) (setq bh0 1))
  202.           (setq bh0 (1- bh0))
  203.         )
  204.       )
  205.       (if (= bhlx 1)
  206.         (progn
  207.           (setq bh1 (1- (ascii (getstring "\n输入起始字母:<A>"))))
  208.         )
  209.       )
  210.       (if (= bhlx 2)
  211.         (progn
  212.           (setq qianzhui20 (getstring (strcat "输入前缀:<" qianzhui2 ">")))
  213.           (if (/= qianzhui20 "") (setq qianzhui2 qianzhui20))
  214.           (setq bh2 (getint "\n输入起始数值:<1>"))
  215.           (if (= bh2 nil) (setq bh2 1))
  216.           (setq bh2 (1- bh2))
  217.           (setq houzhui20 (getstring (strcat "输入后缀:<" houzhui2 ">")))
  218.           (if (/= houzhui20 "") (setq houzhui2 houzhui20))
  219.         )
  220.       )
  221.       (if (= bhlx 3)
  222.         (progn
  223.           (setq qianzhui30 (getstring (strcat "输入前缀:<" qianzhui3 ">")))
  224.           (if (/= qianzhui30 "") (setq qianzhui3 qianzhui30))
  225.           (setq bh3 (1- (ascii (getstring "\n输入起始字母:<A>"))))
  226.           (setq houzhui30 (getstring (strcat "输入后缀:<" houzhui3 ">")))
  227.           (if (/= houzhui30 "") (setq houzhui3 houzhui30))
  228.         )
  229.       )
  230.   (c:sb)
  231. )
  232. ;引线设置
  233. (defun yinxian(/ yx0 yxf jl0 chang0 jiantou0)
  234.   (initget "Y N")
  235.   (if (= yx "Y") (setq yxf "N") (setq yxf "Y"))
  236.   (setq yx0 (getkword (strcat "\n" "编号是否带引线?<Y>/<N>:<" yxf ">")))
  237.   (if (= yx0 nil) (setq yx yxf) (setq yx yx0))
  238.   (if (= yx "Y")
  239.     (progn
  240.       (setq jl0 (getdist (strcat "输入编号到引线的距离:<" (rtos jl) ">")))
  241.       (if (/= jl0 nil) (setq jl jl0))
  242.       (setq chang0 (getdist "输入水平段引线的长度:<自动>"))
  243.       (if (/= chang0 nil) (setq chang chang0 zidong_chang nil) (setq zidong_chang t))
  244.       (setq jiantou0 (getdist (strcat "输入箭头大小:<" (rtos jiantou) ">")))
  245.       (if (/= jiantou0 nil) (setq jiantou jiantou0))
  246.     )
  247.   )
  248.   (c:sb)
  249. )
  250. ;边框设置
  251. (defun bkshezhi(/ r0)
  252.   (initget 1 "Y W J")
  253.   (setq bklx (getkword "\n选择边框类型[圆(Y)/矩形(J)/无(W)]:"))
  254.   (if (= bklx "Y")
  255.     (progn
  256.       (setq r0 (getdist (strcat "输入圆半径:<" "自动" ">")))
  257.       (if (/= r0 nil) (setq r r0 zidong_r nil) (setq zidong_r t))
  258.     )
  259.   )
  260.   (if (= bklx "J")
  261.     (progn
  262.       (setq jkuan (getdist "\n输入矩形宽:<自动>"))
  263.       (if (= jkuan nil)
  264.         (setq zidong_j t)
  265.         (progn
  266.           (setq zidong_j nil)
  267.           (setq jgao (getdist "\n输入矩形高度:"))
  268.         )
  269.       )
  270.     )
  271.   )
  272. (c:sb)
  273. )
  274. ;文字设置
  275. (defun wenzi(/ th0 ta0)
  276. (setq th0 (getdist (strcat "输入文字高度:<" (rtos th) ">")))
  277.   (if (/= th0 nil)
  278.     (progn
  279.       (setq th th0)
  280.     )
  281.   )
  282.   (setq ta0 (getangle (strcat "输入文字角度:<" (rtos ta) ">")))
  283.   (if (/= ta0 nil)
  284.     (progn
  285.       (setq ta ta0)
  286.       (setq ta (* (/ ta pi) 180))
  287.     )
  288.   )
  289. (c:sb)
  290. )
  291. ;绘边框
  292. (defun biankuangy(banjing yuanxin bianhao)
  293.   (if (= bklx "Y")
  294.     (command "circle" yuanxin banjing)
  295.   )
  296.   (if (= bklx "J")
  297.     (progn
  298.       (if (= zidong_j t)
  299.         (setq jkuan0 (tdaxiao 1) jgao0 (tdaxiao 2))
  300.         (setq jkuan0 jkuan jgao0 jgao)
  301.       )
  302.       (command "pline")
  303.       (command (list (- (car yuanxin) (/ jkuan0 2)) (- (cadr yuanxin) (/ jgao0 2))))
  304.       (command "w" 0 0)
  305.       (command (list (+ (car yuanxin) (/ jkuan0 2)) (- (cadr yuanxin) (/ jgao0 2))))
  306.       (command (list (+ (car yuanxin) (/ jkuan0 2)) (+ (cadr yuanxin) (/ jgao0 2))))
  307.       (command (list (- (car yuanxin) (/ jkuan0 2)) (+ (cadr yuanxin) (/ jgao0 2))))
  308.       (command "c")
  309.     )
  310.   )
  311.   (command "text" "J" "MC" yuanxin th ta bianhao)
  312. )
  313. ;将当前文字样式的文字高度项设置为0
  314. (defun gaodu0()
  315.   (command "style" "" "" 0 "" "" "" "" "")
  316.   (c:sb)
  317. )
  318. ;编号文字宽与高
  319. (defun tdaxiao(x / a b c)  ;x=t则b=宽.x=nil则b=高
  320.   (setq a (textbox (list (cons 1 bh))))
  321.   (setq c (/ (- (cadar a) (cadadr a)) pianyi))
  322.   (if (= x 1)
  323.     (setq b (- (caadr a) (caar a) c))
  324.     (if (= x 2)
  325.       (setq b (- (cadadr a) (cadar a) c))
  326.       (setq b (- (distance (car a) (cadr a)) c))
  327.     )
  328.   )
  329.   (eval b)
  330. )
发表于 2016-8-4 16:27:19 | 显示全部楼层
求一个自动编号闭合面的插件
发表于 2013-9-16 20:07:41 | 显示全部楼层
下面算做你说的循环吗:
;参数初始化
(defun chushihua()
  (setq bhlx 0)
  (setq bh0 0)
  (setq bh1 64)
  (setq bh2 0)
  (setq bh3 64)
  (setq yx "Y")
  (write-line "引线:Y")
  (setq bklx "Y")
  (write-line "边框:Y")
  (setq r 2.5)
  (setq zidong_r t)
  (setq th 3.5)
  (setq ta 0)
  (setq jl 1)
  (setq jiantou 2.5)
  (setq chang 5)
  (setq qianzhui2 "")
  (setq houzhui2 "")
  (setq qianzhui3 "")
  (setq houzhui3 "")
  (setq pianyi 7)
(chushihua)
(defun c:sb(/ o ob)
  (defun er(str)
    (princ "\nSB已取消")
(while
  (if (= yx "N")
          (huitu o ob)
          (initget 1)
          (huitu o ob)
  (graphscr)
  ;编号升序
  (if (= bhlx 0)
  (if (= bhlx 1)
      (setq bh (chr bh1))
  (if (= bhlx 2)
  (if (= bhlx 3)
      (if (= zidong_r t)
        (setq r0 r)
    (if (= zidong_j t)
      (if (= bklx "Y")
          (if (= bklx "J")
            (if (= zidong_j t)
              (setq chang0 jkuan)
            (if (= bklx "W")
    (setq chang0 chang)
  ;对象捕捉
  (setvar "osmode" 0)
  ;对象捕捉
(eval bh)
;初值设置
      (if (= bhlx 0)
          (setq bh0 (1- bh0))
      (if (= bhlx 1)
      (if (= bhlx 2)
          (setq bh2 (1- bh2))
      (if (= bhlx 3)
  (c:sb)
;引线设置
  (initget "Y N")
  (if (= yx "Y")
  (c:sb)
;边框设置
  (initget 1 "Y W J")
  (if (= bklx "Y")
  (if (= bklx "J")
      (if (= jkuan nil)
        (setq zidong_j t)
          (setq zidong_j nil)
(c:sb)
;文字设置
  (if (/= th0 nil)
      (setq th th0)
  (if (/= ta0 nil)
      (setq ta ta0)
(c:sb)
;绘边框
  (if (= bklx "Y")
  (if (= bklx "J")
      (if (= zidong_j t)
      (command "pline")
      (command "w" 0 0)
      (command "c")
;将当前文字样式的文字高度项设置为0
(defun gaodu0()
  (c:sb)
;编号文字宽与高
  (if (= x 1)
    (if (= x 2)
  (eval b)
 楼主| 发表于 2013-9-16 20:37:09 | 显示全部楼层
vlisp2012 发表于 2013-9-16 20:07
下面算做你说的循环吗:
能不能标识下修改的部分呢,
发表于 2013-9-16 20:40:10 | 显示全部楼层
(defun c:sb(/ o ob)
  (defun er(str)
    (princ "\nSB已取消")
(while
发表于 2015-6-11 19:53:38 | 显示全部楼层
把这个做成对话框的该多好啊
发表于 2015-11-27 21:33:54 | 显示全部楼层
楼主辛苦了,标记一下
发表于 2015-12-21 20:22:50 | 显示全部楼层
dfgfghgjhjkhjkfdghfgh
发表于 2015-12-22 08:15:58 | 显示全部楼层
楼上是个不错的解释………………
发表于 2016-6-15 10:18:58 | 显示全部楼层
非常感谢分享,如果编号能再加一个自主输入就更好了
GMT+8, 2025-5-11 19:37 , Processed in 0.214925 second(s), 31 queries , Gzip On.
