查看: 1222|回复: 1
[提问] 首次发贴望大是帮忙 "cmddia" nil
发表于 2013-9-23 00:09:50 | 显示全部楼层 |阅读模式
选择后提示 AutoCAD 变量设置被拒绝: "cmddia" nil  求大虾们帮忙啊。感激不尽
(defun C:ft (/ hpsc ss i s1 htcbl)
    (setvar "cmdecho" 0)
    (setq hpsc (getvar "hpscale"))
    (command "_undo" "_begin")
   (princ "\n请选择")
    (setq ss (ssget '((0 . "hatch"))) i -1)
    (while (setq s1 (ssname ss (setq i (1+ i))))
           (command "hatchedit" s1 "p" "" (abs htcbl) "")
    (setq htcbl (getdist "\n请输入比例<默认:100>:"))
    (if (= htcbl nil) (setq htcbl 10))
        (command "_undo" "_end")
    (setvar "hpscale" hpsc)
发表于 2013-9-23 07:56:45 | 显示全部楼层
... 变量设置被拒绝: "cmddia" nil  ...
           (command "hatchedit" s1 "p" "" (abs htcbl) "")    ; Why Abs?
   ;; (setq htcbl (getdist "\n请输入比例<默认:100>:"))
  ;; (if (= htcbl nil) (setq htcbl 10))
GMT+8, 2025-5-26 07:40 , Processed in 0.179927 second(s), 27 queries , Gzip On.
