查看: 2391|回复: 6
[提问] 这个程序绘制一个通孔,为什么选择边缘执行成功,选中间不成功??
发表于 2013-9-23 20:03:49 | 显示全部楼层 |阅读模式
(defun c:MH (/ pa,pb,ww,p1,p2,p3,p4)
(setq pa (getpoint "请输入开始点:"))
(setq pb (getpoint "请输入终止点:"))
(setq ww (getreal "\n请输入螺纹大小M(6,8,10,12,14):"))
(setq p1 ( list (+ (car pa) (/ ww 2)) (cadr pa)))
(setq p2 ( list (+ (car pb) (/ ww 2)) (cadr pb)))
(setq p3 ( list (car p1) (- (cadr p1) 2)))
(setq p4 ( list (- (car pb) (/ ww 2)) (cadr pb)))
(command "line" pa pb "" )
(command "line" p1 p2 "" )
(command "mirror" p3 "" pa pb "" )
发表于 2013-9-23 21:07:50 | 显示全部楼层
通孔为是何义?
看来楼主只是忘了关闭捕捉模式
 楼主| 发表于 2013-9-25 19:07:48 | 显示全部楼层
我就是要用捕捉来定位的,所谓通孔就是机械上加工的圆孔,例如9的圆孔,就是如此,只是我的程序在捕捉环境下无法正常使用!
发表于 2013-9-25 19:35:09 | 显示全部楼层
...要用捕捉来定位的...
于何段落要用捕捉来定位!?
包括下三列吗?
发表于 2013-9-25 20:45:36 | 显示全部楼层
  1. (defun c:MH (/ pa pb ww p1 p2)
  2. (setq pa (getpoint "请输入开始点: "))
  3. (setq pb (getpoint "请输入终止点: "))
  4. (setq ww (getreal "\n请输入螺纹大小M(6,8,10,12,14): "))
  5. (if (= ww nil) (setq ww 6))
  6. (setq ang (angle pa pb))
  7. (setq p1 (polar pa (+ (/ pi 2) ang) (/ ww 2)))
  8. (setq p2 (polar pb (+ (/ pi 2) ang) (/ ww 2)))
  9. (command "line" "non" pa "non" pb "" )
  10. (command "line" "non" p1 "non" p2 "" )
  11. (command "mirror" "L" "" "non" pa "non" pb "")
  12. (princ)
  13. )
 楼主| 发表于 2013-9-26 20:47:35 | 显示全部楼层
非常感谢版主的帮助,让我学到更多东西。不过还要请版主讲解一下我的错误在哪里??谢谢!
发表于 2022-12-24 13:53:42 | 显示全部楼层
收藏了!有一天可能会用到
GMT+8, 2025-11-13 04:41 , Processed in 0.204815 second(s), 30 queries , Gzip On.
