查看: 3039|回复: 6
求助,如果有谁知道如何用主视图,左视图和俯视图直接生成三维视图,请告之。谢谢!
发表于 2002-6-21 13:27:00 | 显示全部楼层 |阅读模式
求助,如果有谁知道如何用主视图,左视图和俯视图直接生成三维视图,请告之。谢谢!!![br]请告之。
发表于 2002-6-21 14:19:00 | 显示全部楼层
在图纸空间中命令mvset.
 楼主| 发表于 2002-6-22 09:52:00 | 显示全部楼层
为什么会不好使
为什么我用这个命令提示说命令不对。
发表于 2002-6-22 14:48:00 | 显示全部楼层
对不起, 是用mview。
你可以参看帮助,方法是:
输入mview,然后回车,接着按F1.
发表于 2002-7-2 12:56:00 | 显示全部楼层
会员(免费)才能下载
会员(免费)才能下载
http://www.cadalog.com/download2.phtml?file=/fromcadalog/MAKE2DLIGHT.EXE&filename=MAKE2DLIGHT.EXE&ID=4334
MakeIt2D Light will create 2D orthographic and isometric views of your AutoCAD?R13, R14, AutoCAD 2000 solid model. If you need to automatically create 2D working drawings from your 3D solid model, MakeIt2D Light is your answer.
MakeIt2D Light works entirely inside AutoCAD 2000. The program first evaluates your 3D solid model. The solid model can be in the current AutoCAD drawing or another existing drawing or a ACIS, SAT file. The program creates slides of 4 possible 2D views of the 3D model. This includes 1 isometric view. From a dialog box, you select the 2D views you want. MakeIt2D Light then creates the 2D geometry of each view you selected. The geometry can be displayed as 2D blocks or as lines and arcs. MakeIt2D Light does full section views as well.
If you like this program check out the full working version in the Cadalog.com On Line Store. It is called Makeit 2D R14/2000
发表于 2002-7-22 13:25:00 | 显示全部楼层
用DB的软件可以吗?
发表于 2002-7-26 15:35:00 | 显示全部楼层
我好像弄错了!以上是3D转为三视图,至于三视图转3D....
我好像弄错了!以上是3D转为三视图,至于三视图转3D(我只有同公司出品的R14版的版本),其实并不好用,我从来没有用过
GMT+8, 2025-5-22 16:00 , Processed in 0.185069 second(s), 27 queries , Gzip On.
