查看: 1754|回复: 4
[VBA群] 2013-09-30 明经AutoCAD.VBA编程(45054712) 群聊记录:Sub testEntity() Dim vl(0 To 7) As
 关闭 [复制链接]
发表于 2013-9-30 13:49:50 | 显示全部楼层 |阅读模式
[VBA/VB/C#]efan2000 13:49:50
Sub testEntity()
    Dim vl(0 To 7) As Double
    vl(2) = 20
    vl(4) = 20
    vl(5) = 10
    vl(7) = 10
    Dim lwp As AcadLWPolyline
    Set lwp = ThisDrawing.ModelSpace.AddLightWeightPolyline(vl)
    Dim mh As mcArxProject1Lib.Entity
    Set mh = New mcArxProject1Lib.Entity
    Dim t As Variant
    Dim v As Variant
    mh.getDXFGroupCode lwp, t, v
    Dim s As String
    Dim ss() As String
    ReDim ss(UBound(t))
    Dim i As Integer
    Dim j As Integer
    For i = 0 To UBound(t)
        s = s & vbCrLf & vbTab & i & ": " & t(i) & ": "
        If IsEmpty(v(i)) Then
            s = s & "空"
        Else
            If VarType(v(i)) = vbInteger Then
                s = s & v(i)
            ElseIf VarType(v(i)) = vbLong Then
                s = s & v(i)
            ElseIf VarType(v(i)) = vbSingle Then
                s = s & v(i)
            ElseIf VarType(v(i)) = vbDouble Then
                s = s & v(i)
            ElseIf VarType(v(i)) = vbString Then
                s = s & v(i)
            ElseIf VarType(v(i)) = (vbArray Or vbDouble) Then
                For j = 0 To UBound(v(i))
                    If j  UBound(v(i)) Then
                        ss(i) = ss(i) & v(i)(j) & ", "
                    Else
                    End If
                Next
                s = s & ss(i)
            End If
        End If
    Next
    Debug.Print "getDXFGroupCode: " & s
End Sub
getDXFGroupCode:
    0: -1: 2129989240
    1: 0: LWPOLYLINE
    2: 330: 2129988856
    3: 5: 87
    4: 100: AcDbEntity
    5: 67: 0
    6: 410: Model
    7: 8: 0
    8: 100: AcDbPolyline
    9: 90: 4
    10: 70: 0
    11: 43: 0
    12: 38: 0
    13: 39: 0
    14: 10: 0, 0, 0
    15: 40: 0
    16: 41: 0
    17: 42: 0
    18: 10: 20, 0, 0
    19: 40: 0
    20: 41: 0
    21: 42: 0
    22: 10: 20, 10, 0
    23: 40: 0
    24: 41: 0
    25: 42: 0
    26: 10: 0, 10, 0
    27: 40: 0
    28: 41: 0
    29: 42: 0
    30: 210: 0, 0, 1
[VBA/VB/C#]efan2000 13:50:36
命令: (entget (entlast))
((-1 . ) (0 . "LWPOLYLINE") (330 . ) (5 .
"87") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 . "0") (100 .
"AcDbPolyline") (90 . 4) (70 . 0) (43 . 0.0) (38 . 0.0) (39 . 0.0) (10 0.0 0.0)
(40 . 0.0) (41 . 0.0) (42 . 0.0) (10 20.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0)
(10 20.0 10.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (10 0.0 10.0) (40 . 0.0) (41 .
0.0) (42 . 0.0) (210 0.0 0.0 1.0))
[VB&.NET]ppyyff 13:52:46
你这干嘛用
[VBA/VB/C#]efan2000 13:53:18
获取实体的组码
[VB&.NET]ppyyff 13:54:15
组吗一般查一下就行了
[VBA/VB/C#]efan2000 13:54:39
Dim o As AcadObject
Set o = ThisDrawing.ObjectIdToObject(2129988856)
Debug.Print "ObjectName: " & o.ObjectName
输出:
ObjectName: AcDbBlockTableRecord
VBA里有的没有这个属性,查不到。
[VB&.NET]ppyyff 13:55:26
这个 是啥 2129989240
是句柄吗
[VBA/VB/C#]efan2000 13:55:59
不是,ObjectId
[VB&.NET]ppyyff 13:56:06
就是这个线的 ID
[VBA/VB/C#]efan2000 13:57:03
0: -1: 2129989240
2129989240是ObjectId
3: 5: 87
这里的87是句柄Handle。
[VB&.NET]ppyyff 13:57:44
是不是每个图的ObjectId是唯一的
每次打开时都是一样的
是不是每个图的每个实体 ObjectId是唯一的
[VBA/VB/C#]efan2000 13:58:55
2: 330: 2129988856
330是OwnerId,这里其实就是模型空间的ObjectId。
[VBA/VB/C#]efan2000 13:59:41
整个CAD,ObjectId是唯一的。一张图里,句柄是唯一的。
[VBA/VB/C#]efan2000 14:00:23
ObjectId每次打开图时是变化的,只有Handle不变。
[VB&.NET]ppyyff 14:01:34
每个实体Handle唯一吧
[VBA/VB/C#]efan2000 14:02:14
是的,只对该图唯一,其它图纸里可能存在一样的。
[VB&.NET]ppyyff 14:03:34
这样我能不能图形的中需要更改数据实体的Handle给与Excel中数据对应,当EXCEl数据更改了,我再Updata一下,让CAD中实体也发生变化?
VBA-华仔 14:03:59
可以
[VB&.NET]ppyyff 14:04:05
还有Handle是自动生成还是手动指定
清风明月名字897 14:04:20
请问,VLA这些函数的帮助说明在哪里查?
即VBA如何转换成LISP?
VBA-华仔 14:04:26
自动
[VBA/VB/C#]efan2000 14:04:34
当然可以了,Handle、ObjectId都是自动生成的,
[VB&.NET]ppyyff 14:04:49
VBA如何转换成LISP差别很大
为啥要转换
清风明月名字897 14:07:30
LISP好用些
[VB&.NET]ppyyff 14:08:03
LISP繁琐一些
 楼主| 发表于 2013-9-30 16:27:40 | 显示全部楼层
有声 16:27:40
哪位有文本数字分类求和的插件,
 楼主| 发表于 2013-9-30 16:42:41 | 显示全部楼层
VBA-华仔 16:42:41
如何分类的?
 楼主| 发表于 2013-9-30 17:48:37 | 显示全部楼层
? Peter 17:48:37
大家好
我想问一下,
什么软件,可以转样条啊,
我要编程
[mccad]mccad 17:49:15
转成什么
转成直线段吗?
? Peter 17:49:44
转成圆弧和直线组成的
[mccad]mccad 17:50:22
用VBA有点难度,用LISP中的曲线类可能还好
? Peter 17:50:35
怎么用
[mccad]mccad 17:50:38
或者将文件转成WMF文件再插入试试
要编程
? Peter 17:50:49
那个全是直线
搞出来的
[mccad]mccad 17:51:19
LISP中的曲线类可以按照一定的曲线距离取点
? Peter 17:51:43
怎么用啊,
[mccad]mccad 17:51:45
然后你就可以计算前后两点的位置及曲率来计算是用直线还是弧线来画
? Peter 17:51:47
精度高吗
怎么画,
有没有这种软件啊
[mccad]mccad 17:52:14
精度很高,取到的点一定是在线上,可按照曲率来看取多长
论坛可能会有,你搜索一下
? Peter 17:52:46
今天我有一个这种图,30000多个样条孔一会就转完了
GMT+8, 2025-4-28 21:31 , Processed in 0.303405 second(s), 26 queries , Gzip On.
